How to Change MCU with MCUXpresso
Recently I found some customers have a bit of problem when porting project from one MCU to another, so this article using simple steps demonstrates how to change MCU with MCUXpresso. There is also a video demonstrated the detail steps in attachment.
Pay attention, as MCUXpresso User Guide says: All projects are associated with a particular MCU at creation time. The target MCU determines the project memory layout, startup code, LinkServer flash driver, libraries, supporting sources,launch configuration options etc. etc. so changing a project’s associated MCU should not be undertaken unless you have a total grasp of the consequence of this change. Therefore rather than changing a project’s associated MCU, it is strongly recommended that instead a new project is generated for the desired MCU and this new project is edited as required.
However, on occasion it may be expedient to reset a project’s MCU (and associated SDK) and this can be achieved as follows. For example, changing lpc55s69 to lpc55s06, we need install SDKs for lpc55s69 and lpc55s06 before all the below steps.
1 - Change MCU & Package
1.1 – Change MCU
Right click “MCU” under Project tree, choose “Edit MCU”
Uncheck ”Preserve memory configuration”(it is checked by default)->choose LPC55S06->there is a warning, choose Yes.
We can see the Memory details changed to lpc55s06, then click ”Apply and close”.
1.2 – Change Package
2 - Change Compiler Definitions
In Properties view->Settings->MCU Compiler ->Preprocessor, change the definition for CPU from LPC55S69JBD100 to LPC55S06JBD64 as below:
3 – Change/add SDK driver for LPC55s06
Selected project, then click ”Manage SDK components”, choose the drivers our application used, for example, clock, power, usart.
Click “OK”, then click “Yes” to update.
Delete LPC55S69 device related files:
Add “system_LPC55S06.c” and “system_LPC55S06.h” files:
4 - Change startup file.
Delete LPC55s69 startup files, add “startup_lpc55s06.c”, we can find the startup file in any SDK demo.
5 - Change board related files.
Refer to our own new board, change files under “board” folder, for example pins, uart number, here directly copy from SDK demo for LPCxpresso55s06 board.
6 - Test the project  function with new board
Build project until no compile error, download and run it, result as below.
Comments
Thanks for providing these instructions.
I my opinion: at least for switching the MCU to a compatible model within an mcu family (e.g., same device but with more memory), this process should be made a lot easier.
Also, whenever possible, keep the selected SDK components, see the "SDK components" issue here: also: https://community.nxp.com/t5/MCUXpresso-IDE/quot-Manage-SDK-Components-quot-stops-working-after-swit...
%3CLINGO-SUB%20id%3D%22lingo-sub-1314209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20Change%20MCU%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1314209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3ERecently%20I%20found%20some%20customers%20have%20a%20bit%20of%20problem%20when%20porting%20project%20from%20one%20MCU%20to%20another%2C%20so%20this%20article%20using%20simple%20steps%20demonstrates%20how%20to%20change%20MCU%20with%20MCUXpresso.%20There%20is%20also%20a%20video%20demonstrated%20the%20detail%20steps%20in%20attachment.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3E%3CSTRONG%3EPay%20attention%3C%2FSTRONG%3E%2C%20as%20MCUXpresso%20User%20Guide%20says%3A%20All%20projects%20are%20associated%20with%20a%20particular%20MCU%20at%20creation%20time.%20The%20target%20MCU%20determines%20the%20project%20memory%20layout%2C%20startup%20code%2C%20LinkServer%20flash%20driver%2C%20libraries%2C%20supporting%20sources%2Claunch%20configuration%20options%20etc.%20etc.%20so%20changing%20a%20project%E2%80%99s%20associated%20MCU%20should%20not%20be%20undertaken%20unless%20you%20have%20a%20total%20grasp%20of%20the%20consequence%20of%20this%20change.%20Therefore%20rather%20than%20changing%20a%20project%E2%80%99s%20associated%20MCU%2C%20it%20is%20strongly%20recommended%20that%20instead%20a%20new%20project%20is%20generated%20for%20the%20desired%20MCU%20and%20this%20new%20project%20is%20edited%20as%20required.%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3EHowever%2C%20on%20occasion%20it%20may%20be%20expedient%20to%20reset%20a%20project%E2%80%99s%20MCU%20(and%20associated%20SDK)%20and%20this%20can%20be%20achieved%20as%20follows.%20For%20example%2C%20changing%20lpc55s69%20to%20lpc55s06%2C%20we%20need%20install%20SDKs%20for%20lpc55s69%20and%20lpc55s06%20before%20all%20the%20below%20steps.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E1%20-%20Change%20MCU%20%26amp%3B%20Package%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.1%20%E2%80%93%20Change%20MCU%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-justify%22%20style%3D%22text-align%20%3A%20justify%3B%22%20style%3D%22text-align%20%3A%20justify%3B%22%3ERight%20click%20%E2%80%9CMCU%E2%80%9D%20under%20Project%20tree%2C%20choose%20%E2%80%9CEdit%20MCU%E2%80%9D%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1627442238840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1627442238840.png%22%20style%3D%22width%3A%20344px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151035i9C63FC9D0CEC815E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1627442238840.png%22%20alt%3D%22Alice_Yang_0-1627442238840.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_0-1627442238840.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EUncheck%20%E2%80%9DPreserve%20memory%20configuration%E2%80%9D%3C%2FSTRONG%3E(it%20is%20checked%20by%20default)-%26gt%3Bchoose%20LPC55S06-%26gt%3Bthere%20is%20a%20warning%2C%20choose%20Yes.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_1-1627442319505.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_1-1627442319505.png%22%20style%3D%22width%3A%20365px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151036i4316DCD6BA02B7F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_1-1627442319505.png%22%20alt%3D%22Alice_Yang_1-1627442319505.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_1-1627442319505.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWe%20can%20see%20the%20Memory%20details%20changed%20to%20lpc55s06%2C%20then%20click%20%E2%80%9DApply%20and%20close%E2%80%9D.%3C%2FP%3E%0A%3CP%3E1.2%20%E2%80%93%20Change%20Package%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_2-1627442363050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_2-1627442363050.png%22%20style%3D%22width%3A%20319px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151037i16FE49EA56D2E08A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_2-1627442363050.png%22%20alt%3D%22Alice_Yang_2-1627442363050.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_2-1627442363050.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2%20-%20Change%20Compiler%20Definitions%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EIn%20Properties%20view-%26gt%3BSettings-%26gt%3BMCU%20Compiler%20-%26gt%3BPreprocessor%2C%20change%20the%20definition%20for%20CPU%20from%20LPC55S69JBD100%20to%20LPC55S06JBD64%20as%20below%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_3-1627442471807.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_3-1627442471807.png%22%20style%3D%22width%3A%20354px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151038iA784FFFF14FB171C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_3-1627442471807.png%22%20alt%3D%22Alice_Yang_3-1627442471807.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_3-1627442471807.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E3%20%E2%80%93%20Change%2Fadd%20SDK%20driver%20for%20LPC55s06%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ESelected%20project%2C%20then%20click%20%E2%80%9DManage%20SDK%20components%E2%80%9D%2C%20choose%20the%20drivers%20our%20application%20used%2C%20for%20example%2C%20clock%2C%20power%2C%20usart.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_4-1627442521094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_4-1627442521094.png%22%20style%3D%22width%3A%20284px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151039i936DC0951B8C8A88%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_4-1627442521094.png%22%20alt%3D%22Alice_Yang_4-1627442521094.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_4-1627442521094.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_6-1627442556603.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_6-1627442556603.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151041iB1608B44ABF6CDBA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_6-1627442556603.png%22%20alt%3D%22Alice_Yang_6-1627442556603.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_6-1627442556603.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EClick%20%E2%80%9COK%E2%80%9D%2C%20then%20click%20%E2%80%9CYes%E2%80%9D%20to%20update.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_7-1627442569628.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_7-1627442569628.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151042i841D34AAC578BFD7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_7-1627442569628.png%22%20alt%3D%22Alice_Yang_7-1627442569628.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_7-1627442569628.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EDelete%20LPC55S69%20device%20related%20files%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1636704852972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1636704852972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F162031i5368E398D3CA9021%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1636704852972.png%22%20alt%3D%22Alice_Yang_0-1636704852972.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_0-1636704852972.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAdd%20%E2%80%9Csystem_LPC55S06.c%E2%80%9D%20and%20%E2%80%9Csystem_LPC55S06.h%E2%80%9D%20files%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_9-1627442604431.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_9-1627442604431.png%22%20style%3D%22width%3A%20337px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151044i16CCA1DBD4F9BDA8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_9-1627442604431.png%22%20alt%3D%22Alice_Yang_9-1627442604431.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_9-1627442604431.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E4%20-%20Change%20startup%20file.%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EDelete%20LPC55s69%20startup%20files%2C%20add%20%E2%80%9Cstartup_lpc55s06.c%E2%80%9D%2C%20we%20can%20find%20the%20startup%20file%20in%20any%20SDK%20demo.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_10-1627442631217.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_10-1627442631217.png%22%20style%3D%22width%3A%20334px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151045iD54FC5379916B0F7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_10-1627442631217.png%22%20alt%3D%22Alice_Yang_10-1627442631217.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_10-1627442631217.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E5%20-%20Change%20board%20related%20files.%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ERefer%20to%20our%20own%20new%20board%2C%20change%20files%20under%20%E2%80%9Cboard%E2%80%9D%20folder%2C%20for%20example%20pins%2C%20uart%20number%2C%20here%20directly%20copy%20from%20SDK%20demo%20for%20LPCxpresso55s06%20board.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_12-1627442675241.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_12-1627442675241.png%22%20style%3D%22width%3A%20211px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151047i2BA381D359569A4A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_12-1627442675241.png%22%20alt%3D%22Alice_Yang_12-1627442675241.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_12-1627442675241.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E6%20-%20Test%20the%20project%26nbsp%3B%20function%20with%20new%20board%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EBuild%20project%20until%20no%20compile%20error%2C%20download%20and%20run%20it%2C%20result%20as%20below.%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_11-1627442661014.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_11-1627442661014.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F151046i5306BF9F79519D01%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_11-1627442661014.png%22%20alt%3D%22Alice_Yang_11-1627442661014.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_11-1627442661014.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1314209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC51Uxx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC546xx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC54xxx%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1674460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20Change%20MCU%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1674460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20providing%20these%20instructions.%3C%2FP%3E%3CP%3EI%20my%20opinion%3A%20at%20least%20for%20switching%20the%20MCU%20to%20a%20compatible%20model%20within%20an%20mcu%20family%20(e.g.%2C%20same%20device%20but%20with%20more%20memory)%2C%20this%20process%20should%20be%20made%20a%20lot%20easier.%3C%2FP%3E%3CP%3EAlso%2C%20whenever%20possible%2C%20keep%20the%20selected%20SDK%20components%2C%20see%26nbsp%3Bthe%20%22SDK%20components%22%20issue%20here%3A%20also%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2Fquot-Manage-SDK-Components-quot-stops-working-after-switching%2Fm-p%2F1401777%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2Fquot-Manage-SDK-Components-quot-stops-working-after-switching%2Fm-p%2F1401777%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (2/2)
Version history
Last update:
‎11-12-2021 01:17 AM
Updated by:
