Controlling a pin with GPIO and Output compare
2,410件の閲覧回数
therealfreegeek
Board - FRDMK64
KSDK - 1.3
KDS - 3 with all the updates
I tried to set up the GPIO driver for PTD0 and the FTM output compare driver for  FTM3 Ch0 on PTD0 but PE says there is a conflict and will not allow it.
It this expected behaviour?
Cheers
Jim
3 返答(返信)
2,246件の閲覧回数
Hello Ernest,
Does your project is about KSDK ?
If yes, you can refer to the  attached method to share PTD0 pin.
Hope it helps
Alice
2,246件の閲覧回数
therealfreegeek
Hi Alice, yes KDSK 1.3, I will try your suggestion.
Jim
2,246件の閲覧回数
Hi Jim,
Ok, hope it helps , waiting your result , if have any question about it , please contact
me without any hesitate.
Alice
