I have updatetd the last sdk for the kinetis ...
After this i can't choose the MCU anymore.
The only MCU i can choose is MKV31F512 !!
So what do i wrong ??
MCUXpresso IDE v11.3.0 [Build 5222] [2021-01-11]
SDK 2.9.0
Solved! Go to Solution.
Hi Sebastion,
i solved the prom to my self ...
Hi Andreas, I hope you're doing well!
Could you please let me know if you are still experiencing this issue? If you try using another workspace, are you able to open other SDKs?
Sebastián
