MKV31F128VLH10 and SDK
2,754 次查看
andreasruetten
I have updatetd the last sdk for the kinetis ...
After this i can't choose the MCU anymore.
The only MCU i can choose is MKV31F512 !!
So what do i wrong ??
MCUXpresso IDE v11.3.0 [Build 5222] [2021-01-11]
SDK 2.9.0
2,726 次查看
andreasruetten
Hi Sebastion,
i solved the prom to my self ...
2,727 次查看
andreasruetten
Hi Sebastion,
2,737 次查看
Sebastian_Del_Rio
Hi Andreas, I hope you're doing well!
Could you please let me know if you are still experiencing this issue? If you try using another workspace, are you able to open other SDKs?
Sebastián
