MKL25Z: VrefH input current?
2,024 次查看
frankvanhooft
What's the input current drawn by the VREFH pin on the MKL25Z128 processor?  I can find total current draw of the ADC, but cannot find the input current of the reference pin in the datasheet. We're using a shunt reference, so this is an important number.
Thanks a lot.
标记 (3)
1,724 次查看
apanecatl
Senior Contributor II
The power consumption of the VrefH input ha snot been characterized apart from the whole ADC module however the figure is taken into consideration to obtain the ADC module power consumption.
1,725 次查看
apanecatl
