Ground of float unused RTC pins?
robsouthworth
We aren’t going to use the Real Time Clock module in the MK20DX256VLL7. How do I connect the following pins:
1) VBAT (pin 30)
2) XTAL32 (pin 28)
3) EXTAL32 (pin 29)
Do I ground these pins or leave them unconnected?
apanecatl
Senior Contributor II
You can leave VBAT floating, same goes for XTAL32 and EXTAL32, you can also leave the XTAL pins grounded.
apanecatl
