K53 : Power-Up Sequence about 5v tolerant GPIO
已解决
跳至解决方案
2,011 次查看
koichisakagami
Dear community,
I have a question about power-up sequence for 5v tolerant GPIO .
Device is Kinetis K50.
[Question]
When VDD power is not turned on ,
Is it possible to add a 5v input voltage to the 5v tolerant GPIO ?
Koichi Sakagami
1 解答
1,800 次查看
Hui_Ma
5 volt tolerant digital I/O pins are internally clamped to VSS through a ESD protection diode. There is no diode to VDD.
There is no problem to apply 5V input voltage on those pins when VDD without power up.
Wish it helps.
best regards
Ma Hui
在原帖中查看解决方案
2 回复数
1,801 次查看
Hui_Ma
Wish it helps.
best regards
Ma Hui
1,800 次查看
koichisakagami
Dear Ma Hui san,
Thank you for your reply.
I got it .
Koichi Sakagami
