FlexCAN messaging on KEAZ64 Board
GarrettMJ
I am wondering if there is a way to get FlexCAN working on the a KEAZ64 board as I am trying to port over some J1939 CAN code that is setup for a FlexCAN module to a KEAZ board. I am unfortunately not able to get this to work and can't find anything saying this is even possible. Any advice would be extremely helpful.
RaRo
Hello @GarrettMJ,
Unfortunately, there is not an example about the KEAZ64 board and compatibility with J1939. Nevertheless, it could be useful to take a look to the following information:
Best regards, Raul.
GarrettMJ
Hi Raul, thank you for the support. Is there any sample code for MSCAN that is able to show it sending and receiving multiple CAN messages? I can only find the Test_Case code for the driver that allows for either 1 message to be sent or 1 message to be received. Any sample code to polling for messages and the sending of multiple messages would be highly appreciated.
RaRo
Hello @GarrettMJ,
Sadly, the only example of KEA's MSCAN is the Test_Case you mention. Nonetheless, might be helpful to check the following information:
Sorry for any inconvenient this may cause you.
Best regards, Raul.
