FRDM-KL02Z hello_world not printing to console or terminal
1,178件の閲覧回数
CCPoon2022
I am a newbie to micro controller programming. I have successfully compiled the hello world program from the FRDM-KL02Z SDK examples using MCUexpresso, but I can't see any output of PRINTF or get the getchar putchar working. Where can I find the console or terminal for the hello world program?
Many Thanks in advance.
2 返答(返信)
1,149件の閲覧回数
diego_charles
Hi @CCPoon2022
By default latest and most of MCUXPresso SDK releases use the UART console, not the semihosting terminal.
Please check this option to be sure which console is being selected
As Erich said, If you are using Semihosting , you are already in the rigth console.
All the best,
Diego
1,169件の閲覧回数
ErichStyger
Specialist I
If you are using semihosting, then you should see the text on the semihosting console. You have that one open in your screenshot, but not sure what you have selected in the project.
Other than that, you can use the UART to USB-CDC on the FRDM board.
