FTM CnV Update Problem
3,761件の閲覧回数
Jana_muralidharan
So, I was trying to change the value of CnV based on the data's bit value
but the output stays in the initial wrote value but not changing
since I am just getting started in this MicroController MKE02Z64VLC4,
I don't know which step i am wrong, Please tell me which line is missing
#include "MKE02Z4.h"
#define FTM_MOD     24      // 25 ticks → 1.25us @ 20MHz
#define TICKS_0      7
#define TICKS_1     14
void FTM_Init(void)
    SIM->SCGC |= SIM_SCGC_FTM2_MASK;
    FTM2->MODE = FTM_MODE_WPDIS_MASK | FTM_MODE_FTMEN_MASK;
    FTM2->CNTIN = 0;
    FTM2->CNT   = 0;
    FTM2->MOD   = FTM_MOD;
    FTM2->CONTROLS[0].CnSC =
        FTM_CnSC_MSB_MASK |
        FTM_CnSC_ELSB_MASK;
    FTM2->CONTROLS[0].CnV = TICKS_0;
    /* ENABLE CHANNEL OUTPUT (CRITICAL) */
    FTM2->OUTMASK &= ~(1 << 0);
    /* Initial load */
    *(volatile __UINT32_TYPE__ *)0x4003A098 = 0x0021;
    FTM2->SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
    *(volatile __UINT32_TYPE__ *)0x4003A064 = 0x00;
static inline void wait_ftm_period(void)
    while(!(FTM2->SC & FTM_SC_TOF_MASK));
    FTM2->SC &= ~FTM_SC_TOF_MASK;
uint32_t word = 0x5555;
int main(void)
    FTM_Init();
    while (1)
        for(int i = 0; i < 16; i++)
            if (word & (1UL << i))
                *(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_1;
            else
            	*(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_0;
            /* ARM reload for next PWM cycle */
            /* WAIT ONE PWM PERIOD */
            wait_ftm_period();
3,650件の閲覧回数
Celeste_Liu
No, your understanding is wrong. I did a test, please see the result:
1) with the correct 0x0200=LDOK:
2) with the wrong 0x0020=LDOK:
I’m afraid you’ve mixed up byte order and bit numbering. For a 32-bit register, the documentation refers to fields by bit (bit0 is the least significant, bit31 the most significant). LDOK = bit9 has nothing to do with which byte it’s in.
Hope it helps.
Celeste
6 返答(返信)
3,732件の閲覧回数
Celeste_Liu
Hello @Jana_muralidharan ,
Thanks for your post.
When FTMEN = 1 (which you have already set), the main registers of the FTM (including CnV, MOD, CNTIN, etc.) are write-buffered; the actual registers are only updated when a synchronization/load event is triggered. Otherwise, the new values will remain in the buffer, and the channel will continue using the old initialized values. Please see the description in RM:
Please modify the code below to set LDOK=1 to enable the load:
            *(volatile __UINT32_TYPE__ *)0x4003A098 = 0x0201;//0x0200=LDOK, 0x0001=CH0SEL
Hope it helps.
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
3,698件の閲覧回数
Jana_muralidharan
If possible can you please explain the flow of how the PWM starts to generate please
3,649件の閲覧回数
Celeste_Liu
For this question, you can refer to our SDK demos for a deeper understanding.
Select Board | MCUXpresso SDK Builder
Celeste
3,699件の閲覧回数
Jana_muralidharan
But isn't it be like this since in that register at the third byte from the left that is MSB has the LDOK not in the second right so it is the only possible thing  right
0x0020=LDOK, 0x0001=CH0SEL
Isn't that right from my point of view I guess
And Thank you for replying my post 🙇🏼‍
And please clarify this doubt of mine too please..
3,650件の閲覧回数
Celeste_Liu
Hope it helps.
Celeste
3,641件の閲覧回数
Jana_muralidharan
Thank you, For your answer. i was so dumb found. thank you very much
but I used the built in library's mask but still the same issue but thanks any way for your imediate response
%3CLINGO-SUB%20id%3D%22lingo-sub-2264552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFTM%20CnV%20%E6%9B%B4%E6%96%B0%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CP%3ESO%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E5%80%A4%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6CnV%E3%81%AE%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E5%80%A4%E3%81%AE%E3%81%BE%E3%81%BE%E5%A4%89%E5%8C%96%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%93%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9MKE02Z64VLC4%E3%82%92%E4%BD%BF%E3%81%84%E5%A7%8B%E3%82%81%E3%81%9F%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%AE%E8%A1%8C%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23include%20%22MKE02Z4.h%22%0A%0A%23define%20FTM_MOD%20%20%20%20%2024%20%20%20%20%20%20%2F%2F%2025%20ticks%20%E2%86%92%201.25us%20%40%2020MHz%0A%23define%20TICKS_0%20%20%20%20%20%207%0A%23define%20TICKS_1%20%20%20%20%2014%0A%0Avoid%20FTM_Init(void)%0A%7B%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_FTM2_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BMODE%20%3D%20FTM_MODE_WPDIS_MASK%20%7C%20FTM_MODE_FTMEN_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCNTIN%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BCNT%20%20%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BMOD%20%20%20%3D%20FTM_MOD%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnSC%20%3D%0A%20%20%20%20%20%20%20%20FTM_CnSC_MSB_MASK%20%7C%0A%20%20%20%20%20%20%20%20FTM_CnSC_ELSB_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnV%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%2F*%20ENABLE%20CHANNEL%20OUTPUT%20(CRITICAL)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BOUTMASK%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%200)%3B%0A%0A%20%20%20%20%2F*%20Initial%20load%20*%2F%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0021%3B%0A%0A%20%20%20%20FTM2-%26gt%3BSC%20%3D%20FTM_SC_CLKS(1)%20%7C%20FTM_SC_PS(0)%3B%0A%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A064%20%3D%200x00%3B%0A%7D%0A%0Astatic%20inline%20void%20wait_ftm_period(void)%0A%7B%0A%20%20%20%20while(!(FTM2-%26gt%3BSC%20%26amp%3B%20FTM_SC_TOF_MASK))%3B%0A%20%20%20%20FTM2-%26gt%3BSC%20%26amp%3B%3D%20~FTM_SC_TOF_MASK%3B%0A%7D%0A%0Auint32_t%20word%20%3D%200x5555%3B%0A%0Aint%20main(void)%0A%7B%0A%20%20%20%20FTM_Init()%3B%0A%0A%20%20%20%20while%20(1)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20for(int%20i%20%3D%200%3B%20i%20%26lt%3B%2016%3B%20i%2B%2B)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(word%20%26amp%3B%20(1UL%20%26lt%3B%26lt%3B%20i))%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_1%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%20%20%20%20%09*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20ARM%20reload%20for%20next%20PWM%20cycle%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0021%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20WAIT%20ONE%20PWM%20PERIOD%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20wait_ftm_period()%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%B7%A6%E3%81%8B%E3%82%893%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8AMSB%E3%81%ABLDOK%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%8F%B3%E3%81%8B%E3%82%892%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E3%81%AFLDOK%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%94%AF%E4%B8%80%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E0x0020%3DLDOK%E3%80%810x0001%3DCH0SEL%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A6%B3%E7%82%B9%E3%81%8B%E3%82%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%3CSTRONG%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CSTRONG%3E%F0%9F%99%87%F0%9F%8F%BC%E2%80%8D%3CLI-EMOJI%20id%3D%22lia_male-sign%22%20title%3D%22%3Amale_sign%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AE%E3%81%93%E3%81%AE%E7%96%91%E5%95%8F%E3%82%82%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%E3%80%81PWM%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%94%9F%E6%88%90%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AE%E6%B5%81%E3%82%8C%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%94%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EFTMEN%20%3D%201%20(%E3%81%99%E3%81%A7%E3%81%AB%E8%A8%AD%E5%AE%9A%E6%B8%88%E3%81%BF)%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FTM%20%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(CnV%E3%80%81MOD%E3%80%81CNTIN%20%E3%81%AA%E3%81%A9%E3%82%92%E5%90%AB%E3%82%80)%20%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E5%90%8C%E6%9C%9F%2F%E3%83%AD%E3%83%BC%E3%83%89%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%AE%E3%81%BF%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%80%A4%E3%81%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E6%AE%8B%E3%82%8A%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E5%8F%A4%E3%81%84%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4%E3%82%92%E4%BD%BF%E3%81%84%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82RM%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370610i063A80731C689BF1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766053059160.png%22%20alt%3D%22Celeste_Liu_0-1766053059160.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370611i09D13549561BFEAD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_1-1766053104360.png%22%20alt%3D%22Celeste_Liu_1-1766053104360.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370612i5478B9E90B975095%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_2-1766053261449.png%22%20alt%3D%22Celeste_Liu_2-1766053261449.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%20LDOK%3D1%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20ARM%20reload%20for%20next%20PWM%20cycle%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0201%3B%2F%2F0x0200%3DLDOK%2C%200x0001%3DCH0SEL%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370614iF55EF724F5BB784D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_3-1766053941711.png%22%20alt%3D%22Celeste_Liu_3-1766053941711.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E----------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%AE%E7%AD%94%E3%81%88%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E6%89%BF%E8%AA%8D%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20----------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3CBR%20%2F%3E%201)%20%E6%AD%A3%E3%81%97%E3%81%84%3CSTRONG%3E%3CEM%3E0x02%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CSTRONG%3E%3CEM%3E0%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E0%3DLDOK%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370774iE84456B91C0DFE63%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766139388647.png%22%20alt%3D%22Celeste_Liu_0-1766139388647.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2)%20%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%3CSTRONG%3E%3CEM%3E0x0%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CSTRONG%3E%3CEM%3E0%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E2%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E0%3DLDOK%3A%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370775i7B7C7FAA2146D27E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_1-1766139442165.png%22%20alt%3D%22Celeste_Liu_1-1766139442165.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%90%E3%82%A4%E3%83%88%E9%A0%86%E5%BA%8F%E3%81%A8%E3%83%93%E3%83%83%E3%83%88%E7%95%AA%E5%8F%B7%E3%82%92%E6%B7%B7%E5%90%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%8232%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%E3%81%94%E3%81%A8%E3%81%AB%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%93%E3%83%83%E3%83%88%200%20%E3%81%8C%E6%9C%80%E4%B8%8B%E4%BD%8D%E3%80%81%E3%83%93%E3%83%83%E3%83%88%2031%20%E3%81%8C%E6%9C%80%E4%B8%8A%E4%BD%8D)%E3%80%82LDOK%20%3D%20bit9%20%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%A9%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFSO%E3%83%90%E3%82%AB%E3%81%A0%E3%81%A8%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E6%B7%B1%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BD%93%E7%A4%BE%E3%81%AESDK%E3%83%87%E3%83%A2%E3%81%AECAN%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fselect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%20%7C%20MCUXpresso%20SDKs%20%E3%83%93%E3%83%AB%E3%83%80%E3%83%BC%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766140071913.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766140071913.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370778iD85EE5D01A956C47%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766140071913.png%22%20alt%3D%22Celeste_Liu_0-1766140071913.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
