FTM CnV Update Problem
Jana_muralidharan
So, I was trying to change the value of CnV based on the data's bit value
but the output stays in the initial wrote value but not changing
since I am just getting started in this MicroController MKE02Z64VLC4,
I don't know which step i am wrong, Please tell me which line is missing
#include "MKE02Z4.h"
#define FTM_MOD     24      // 25 ticks → 1.25us @ 20MHz
#define TICKS_0      7
#define TICKS_1     14
void FTM_Init(void)
    SIM->SCGC |= SIM_SCGC_FTM2_MASK;
    FTM2->MODE = FTM_MODE_WPDIS_MASK | FTM_MODE_FTMEN_MASK;
    FTM2->CNTIN = 0;
    FTM2->CNT   = 0;
    FTM2->MOD   = FTM_MOD;
    FTM2->CONTROLS[0].CnSC =
        FTM_CnSC_MSB_MASK |
        FTM_CnSC_ELSB_MASK;
    FTM2->CONTROLS[0].CnV = TICKS_0;
    /* ENABLE CHANNEL OUTPUT (CRITICAL) */
    FTM2->OUTMASK &= ~(1 << 0);
    /* Initial load */
    *(volatile __UINT32_TYPE__ *)0x4003A098 = 0x0021;
    FTM2->SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
    *(volatile __UINT32_TYPE__ *)0x4003A064 = 0x00;
static inline void wait_ftm_period(void)
    while(!(FTM2->SC & FTM_SC_TOF_MASK));
    FTM2->SC &= ~FTM_SC_TOF_MASK;
uint32_t word = 0x5555;
int main(void)
    FTM_Init();
    while (1)
        for(int i = 0; i < 16; i++)
            if (word & (1UL << i))
                *(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_1;
            else
            	*(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_0;
            /* ARM reload for next PWM cycle */
            /* WAIT ONE PWM PERIOD */
            wait_ftm_period();
Celeste_Liu
No, your understanding is wrong. I did a test, please see the result:
1) with the correct 0x0200=LDOK:
2) with the wrong 0x0020=LDOK:
I’m afraid you’ve mixed up byte order and bit numbering. For a 32-bit register, the documentation refers to fields by bit (bit0 is the least significant, bit31 the most significant). LDOK = bit9 has nothing to do with which byte it’s in.
Hope it helps.
Celeste
Celeste_Liu
Hello @Jana_muralidharan ,
Thanks for your post.
When FTMEN = 1 (which you have already set), the main registers of the FTM (including CnV, MOD, CNTIN, etc.) are write-buffered; the actual registers are only updated when a synchronization/load event is triggered. Otherwise, the new values will remain in the buffer, and the channel will continue using the old initialized values. Please see the description in RM:
Please modify the code below to set LDOK=1 to enable the load:
            *(volatile __UINT32_TYPE__ *)0x4003A098 = 0x0201;//0x0200=LDOK, 0x0001=CH0SEL
Hope it helps.
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
Jana_muralidharan
If possible can you please explain the flow of how the PWM starts to generate please
Celeste_Liu
For this question, you can refer to our SDK demos for a deeper understanding.
Select Board | MCUXpresso SDK Builder
Celeste
Jana_muralidharan
But isn't it be like this since in that register at the third byte from the left that is MSB has the LDOK not in the second right so it is the only possible thing  right
0x0020=LDOK, 0x0001=CH0SEL
Isn't that right from my point of view I guess
And Thank you for replying my post 🙇🏼‍
And please clarify this doubt of mine too please..
Celeste_Liu
Hope it helps.
Celeste
Jana_muralidharan
Thank you, For your answer. i was so dumb found. thank you very much
but I used the built in library's mask but still the same issue but thanks any way for your imediate response
%3CLINGO-SUB%20id%3D%22lingo-sub-2264552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CP%3ESo%2C%20I%20was%20trying%20to%20change%20the%20value%20of%20CnV%20based%20on%20the%20data's%20bit%20value%3C%2FP%3E%3CP%3Ebut%20the%20output%20stays%20in%20the%20initial%20wrote%20value%20but%20not%20changing%3C%2FP%3E%3CP%3Esince%20I%20am%20just%20getting%20started%20in%20this%20MicroController%20MKE02Z64VLC4%2C%3C%2FP%3E%3CP%3EI%20don't%20know%20which%20step%20i%20am%20wrong%2C%20Please%20tell%20me%20which%20line%20is%20missing%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%23include%20%22MKE02Z4.h%22%0A%0A%23define%20FTM_MOD%20%20%20%20%2024%20%20%20%20%20%20%2F%2F%2025%20ticks%20%E2%86%92%201.25us%20%40%2020MHz%0A%23define%20TICKS_0%20%20%20%20%20%207%0A%23define%20TICKS_1%20%20%20%20%2014%0A%0Avoid%20FTM_Init(void)%0A%7B%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_FTM2_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BMODE%20%3D%20FTM_MODE_WPDIS_MASK%20%7C%20FTM_MODE_FTMEN_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCNTIN%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BCNT%20%20%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BMOD%20%20%20%3D%20FTM_MOD%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnSC%20%3D%0A%20%20%20%20%20%20%20%20FTM_CnSC_MSB_MASK%20%7C%0A%20%20%20%20%20%20%20%20FTM_CnSC_ELSB_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnV%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%2F*%20ENABLE%20CHANNEL%20OUTPUT%20(CRITICAL)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BOUTMASK%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%200)%3B%0A%0A%20%20%20%20%2F*%20Initial%20load%20*%2F%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0021%3B%0A%0A%20%20%20%20FTM2-%26gt%3BSC%20%3D%20FTM_SC_CLKS(1)%20%7C%20FTM_SC_PS(0)%3B%0A%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A064%20%3D%200x00%3B%0A%7D%0A%0Astatic%20inline%20void%20wait_ftm_period(void)%0A%7B%0A%20%20%20%20while(!(FTM2-%26gt%3BSC%20%26amp%3B%20FTM_SC_TOF_MASK))%3B%0A%20%20%20%20FTM2-%26gt%3BSC%20%26amp%3B%3D%20~FTM_SC_TOF_MASK%3B%0A%7D%0A%0Auint32_t%20word%20%3D%200x5555%3B%0A%0Aint%20main(void)%0A%7B%0A%20%20%20%20FTM_Init()%3B%0A%0A%20%20%20%20while%20(1)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20for(int%20i%20%3D%200%3B%20i%20%26lt%3B%2016%3B%20i%2B%2B)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(word%20%26amp%3B%20(1UL%20%26lt%3B%26lt%3B%20i))%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_1%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%20%20%20%20%09*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20ARM%20reload%20for%20next%20PWM%20cycle%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0021%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20WAIT%20ONE%20PWM%20PERIOD%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20wait_ftm_period()%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBut%20isn't%20it%20be%20like%20this%20since%20in%20that%20register%20at%20the%20third%20byte%20from%20the%20left%20that%20is%20MSB%20has%20the%20LDOK%20not%20in%20the%20second%20right%20so%20it%20is%20the%20only%20possible%20thing%26nbsp%3B%20right%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E0x0020%3DLDOK%2C%200x0001%3DCH0SEL%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIsn't%20that%20right%20from%20my%20point%20of%20view%20I%20guess%3C%2FP%3E%3CP%3EAnd%20%3CSTRONG%3EThank%20you%3C%2FSTRONG%3E%20%3CSTRONG%3Efor%20replying%20my%20post%20%F0%9F%99%87%F0%9F%8F%BC%E2%80%8D%3CLI-EMOJI%20id%3D%22lia_male-sign%22%20title%3D%22%3Amale_sign%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAnd%20please%20clarify%20this%20doubt%20of%20mine%20too%20please..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EWhen%20FTMEN%20%3D%201%20(which%20you%20have%20already%20set)%2C%20the%20main%20registers%20of%20the%20FTM%20(including%20CnV%2C%20MOD%2C%20CNTIN%2C%20etc.)%20are%20write-buffered%3B%20the%20actual%20registers%20are%20only%20updated%20when%20a%20synchronization%2Fload%20event%20is%20triggered.%20Otherwise%2C%20the%20new%20values%20will%20remain%20in%20the%20buffer%2C%20and%20the%20channel%20will%20continue%20using%20the%20old%20initialized%20values.%20Please%20see%20the%20description%20in%20RM%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766053059160.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370610i063A80731C689BF1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766053059160.png%22%20alt%3D%22Celeste_Liu_0-1766053059160.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766053104360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370611i09D13549561BFEAD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_1-1766053104360.png%22%20alt%3D%22Celeste_Liu_1-1766053104360.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_2-1766053261449.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370612i5478B9E90B975095%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_2-1766053261449.png%22%20alt%3D%22Celeste_Liu_2-1766053261449.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20modify%20the%20code%20below%20to%20set%26nbsp%3BLDOK%3D1%20to%20enable%20the%20load%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20ARM%20reload%20for%20next%20PWM%20cycle%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0201%3B%2F%2F0x0200%3DLDOK%2C%200x0001%3DCH0SEL%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_3-1766053941711.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370614iF55EF724F5BB784D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_3-1766053941711.png%22%20alt%3D%22Celeste_Liu_3-1766053941711.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20it%20helps.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3ECeleste%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3CBR%20%2F%3E------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIf%20possible%20can%20you%20please%20explain%20the%20flow%20of%20how%20the%20PWM%20starts%20to%20generate%20please%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20your%20understanding%20is%20wrong.%20I%20did%20a%20test%2C%20please%20see%20the%20result%3A%3CBR%20%2F%3E1)%20with%20the%20correct%26nbsp%3B%3CSTRONG%3E%3CEM%3E0x02%3C%2FEM%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CEM%3E0%3C%2FEM%3E%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E0%3DLDOK%3A%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766139388647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370774iE84456B91C0DFE63%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766139388647.png%22%20alt%3D%22Celeste_Liu_0-1766139388647.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2)%20with%20the%20wrong%26nbsp%3B%3CSTRONG%3E%3CEM%3E0x0%3C%2FEM%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CEM%3E0%3C%2FEM%3E%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E2%3C%2FEM%3E%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E0%3DLDOK%3A%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_1-1766139442165.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370775i7B7C7FAA2146D27E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_1-1766139442165.png%22%20alt%3D%22Celeste_Liu_1-1766139442165.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%E2%80%99m%20afraid%20you%E2%80%99ve%20mixed%20up%20byte%20order%20and%20bit%20numbering.%20For%20a%2032-bit%20register%2C%20the%20documentation%20refers%20to%20fields%20by%20bit%20(bit0%20is%20the%20least%20significant%2C%20bit31%20the%20most%20significant).%20LDOK%20%3D%20bit9%20has%20nothing%20to%20do%20with%20which%20byte%20it%E2%80%99s%20in.%3C%2FP%3E%0A%3CP%3EHope%20it%20helps.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3ECeleste%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%2C%20For%20your%20answer.%20i%20was%20so%20dumb%20found.%20thank%20you%20very%20much%3CBR%20%2F%3E%3CBR%20%2F%3Ebut%20I%20used%20the%20built%20in%20library's%20mask%20but%20still%20the%20same%20issue%20but%20thanks%20any%20way%20for%20your%20imediate%20response%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20this%20question%2C%20you%20can%20refer%20to%20our%20SDK%20demos%20for%20a%20deeper%20understanding.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fselect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESelect%20Board%20%7C%20MCUXpresso%20SDK%20Builder%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1766140071913.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1766140071913.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370778iD85EE5D01A956C47%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1766140071913.png%22%20alt%3D%22Celeste_Liu_0-1766140071913.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3ECeleste%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
