Debug external MKV10Z16VLC7 target with FRDM-KV11Z
2,515 次查看
vijayvaidya
1. Can FRDM-KV11Z board be used to debug MKV10Z16VLC7 based external target board.
2. What steps we need to follow. We are not able to conclude this from the information given in User Guide of FRDM-        KV11Z.
3. Any pointers for this will be most appreciated,
Thanks in advance,
Vijay Vaidya
标记 (1)
2,414 次查看
diego_charles
Hello, Vijay
Here is a nice tutorial from MCU on eclipse that may help you. The KL43 is used as debugger
but the process must work on other FRDM boards.
https://mcuoneclipse.com/2015/08/19/using-the-freescale-freedom-frdm-kl43z-to-debug-other-boards/
You will need to modify certain pins related to SDA interface on the board, details are contained in the tutorial.
On the other hand, have you checked out the LPC Link 2 debugger and programmer?
https://www.nxp.com/design/microcontrollers-developer-resources/lpc-microcontroller-utilities/lpc-li...
 I recommend you for the long term this handfull external debugger.
Diego
2,415 次查看
diego_charles
Hello, Vijay
Diego
2,414 次查看
vijayvaidya
Hello Diego,
Thanks a lot for your suggestions,
Vijay Vaidya
