BOOTCFG pin active high or low
2,409 次查看
wilco_work
Hello all,
I'm using the K82FN256 and want to use the BOOTCFG0 pin for booting. Is this BOOTCFG0 active HIGH or active LOW (asserted by logic 1 or 0)?
Kin regards
标记 (2)
2,293 次查看
victorjimenez
Hello Jan,
Based on the following table of the reference manual.
We can know that the pin is active high, asserted by logic 1.
Hope it helps!
Victor.
2,294 次查看
victorjimenez
Hello Jan,
Hope it helps!
Victor.
2,293 次查看
wilco_work
Hi Victor,
Thank you! Apparently putting a high value at the pin will result in a 1 at the register. I missed that point.
Kind regards
