State initial pin
State initial pin
985 次查看
mattcaill
I would like to know how is the pin (high, low, Z,...) when the soft is not running?
Only when the alimentation is on.
908 次查看
DavidS
Hi Matthieu,
Please find your Kinetis device Reference Manual.  Example: http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf?fasp=1&WT_TYPE...
The Signal Multiplexing and Signal Description chapter will should how each pin is configured by Default.
In general GPIO pins are disabled so High Impedance.  Analog pins are enabled.
David
