State initial pin
State initial pin
998件の閲覧回数
mattcaill
I would like to know how is the pin (high, low, Z,...) when the soft is not running?
Only when the alimentation is on.
921件の閲覧回数
DavidS
Hi Matthieu,
Please find your Kinetis device Reference Manual.  Example: http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf?fasp=1&WT_TYPE...
The Signal Multiplexing and Signal Description chapter will should how each pin is configured by Default.
In general GPIO pins are disabled so High Impedance.  Analog pins are enabled.
David
