FRDM-K82F
FRDM-K82F
14,891件の閲覧回数
kentachang_melt
I am interesting to FRDM-K82F and buy it. but I try to use KDS 3.0.0 create a new project, and then I have problem.
please let me know How to create and program the FRDM-K82F and then debug my project ?
Kenta
10 返答(返信)
14,308件の閲覧回数
Hello Kenta,
Please check the computer management , if it show the "mbed serial port" like this :
when you debug , please select the "GDB OpenOCD Debugging" :
if PE , select the "GDB PEMicro " , if Jlink , please select "GDB SEGGER J-Link".
You can also refer to this DOC to know more about the three debug methods :
Summary of FRDM-K22F debug interface
If still can not work , please take a screenshot about the PC management and show it to me .
Hope it helps
Alice Yang
14,308件の閲覧回数
kentachang_melt
Hi Yang,
Can I use the Kinetis Design Studio 3.0.0 to route my firmware ? And download firmware into FRDM-K82F by USB Multilink , and then debug it ?
Kenta
14,308件の閲覧回数
Hi Kenta,
What about your firmware?
The firmware i mentioned is the bootloader for debug , and only need one usb cable .
Please take a picture about  how your board link to PC and the configuration of KDS debugger,
that i can clearly know your meaning.
And please also tell me which debug method do you want to use , or your aim , thank !
Alice
14,300件の閲覧回数
kentachang_melt
Hello Alice,
Is there any update for me?
Kenta
14,300件の閲覧回数
Hello  Kenta,
I have test it use the MULTILINK , it can work well .
- Please first change the bootloader  of the board , for  example , you can change it to jlink
use the "JLink_OpenSDA_V2_1.bin" .
- then connect the board ,debugger to PC :
then check the PC management , whether have the USB Multilink:
Then configure the debug configuration as this :
Then it can download well :
Hope it helps
Alice Yang
14,300件の閲覧回数
kentachang_melt
Hi Alice,
1) Can I create a project (Kinetis Design Studio 3.0.0) for FRDM-K82F ?
2) Can you send a example project of FRDM-K82F for me ? I want to learn it use MULTILINK.
I hope to understand : my FRDM-K82F can work well, and then I can create a new firmware project.
Please …
Kenta
14,300件の閲覧回数
Oh Kenta ,  you have not project ? So how do you test it before ?
Please download the KSDK2.0 project for FRDM-K82, then you can use it on KDS3.0.
About the detail method to download please refer to :
https://community.freescale.com/docs/DOC-329662
Hope it helps
Alice
14,300件の閲覧回数
kentachang_melt
Hi Alice,
the KSDK2.0 project is download, But I can’t use it on KDS 3.0.
Kenta
14,300件の閲覧回数
Hello Kenta,
Pleas select the  SDK folder ,  it is the path of SDK_2.0_FRDM-K82F on you PC.
please refer to the video i mentioned last time : https://community.freescale.com/docs/DOC-329662
in this thread , there is the detail massage about how to use it .
Hope it helps you
Alice
14,300件の閲覧回数
kentachang_melt
Hi Alice,
I hope to program the FRDM-K82F by USB Multilink (SWD port).
The picture is attached.
May I have something wrong.
Kenta
