P3S0210BQ
P3S0210BQ
JaeHwan
Hi.
I don't know why output voltage drop(VCCP1 & VCCP2 Output voltage : 1.65V).
Using voltage is below.
VCCR : 3.58V
VCCS : 3.3V
VCCE : 3.3V
VCCP1, VCCP2 : 3.3V
1-host : 2-device
host is stm32(Only normal I2C, not I3C)
device is normal eeproms
Thank you.
JaeHwan
Hi. guoweisun!
I solved.
Add 47pF capacitor at Input and output lines.
Thank you.
guoweisun
Could you please help and share with your schematic?
guoweisun
JaeHwan
Hi. guoweisun!
Thank you for your fast answer!
1-host(stm32) has above pull-up value.
guoweisun
For the IIC use case you should add the pull up resistors.
JaeHwan
Hi. guoweisun!
1-host have Pull-up.
guoweisun
On both sides need pull up resistors.
Did you add on both sides?
JaeHwan
Hi, guoweisun!
Yes. add on both sides!
above schematics.
guoweisun
 For the output voltage drop waveform,can you give clear picture again for better analysis?
JaeHwan
Hi.
Thank you.
guoweisun
Can you zoom in your waveform? I need to see the  drop value.
JaeHwan
guoweisun
The input signal is not up to 3.3V.,can you test the input signal disconnect with this P3S0210BQ to confirm whether it's 3.3V signal?
JaeHwan
JaeHwan
Hi. guoweisun!
I solved.
Thank you.
