Interfacing MC33771C with MC33665 Isolated Network High-Speed Transceiver
D_K
I am working on a BMS (Battery Management System) project and planning to use the MC33771C battery cell controller. I came across the MC33665 isolated network high-speed transceiver and wanted to confirm:
Is it possible to interface the MC33771C with the MC33665 ?
If yes, could you please share any reference designs, application notes, or configuration guidelines for this setup?
Thanks in advance for your support.
Deepu Kumar Shah
guoweisun
1:Is it possible to interface the MC33771C with the MC33665 ?
【gw】Yes.
2:If yes, could you please share any reference designs, application notes, or configuration guidelines for this setup?
[gw]We have the connection diagram showing below:
