Configuration file for LS1012ARDB
2,042 次查看
nattapongsungch
Hi i'm working on LS1012ARDB with codeWarrior for recovery and program QSPI.
I downloaded CodeWarrior for QorIQ LS Series, ARMv8 ISA v11.2 and already updated by inside (Help -> check for update).
So ,I cannot find LS1012ARDB on Target connection.
Thank you
Nattapong
1,751 次查看
addiyi
Check for Updates is not working property. It will not update plug-ins that add support for LS1012. Please use Help > Install New Software instead, and select ARMv8 Eclipse Update Site - http://freescale.com/lgfiles/updates/Eclipse/11.2.0/com.freescale.armv8_win as update site in Work with field.
Adrian
1,752 次查看
addiyi
Adrian
1,751 次查看
justinjonas
The update site for this is down. Do you know if it will be back up soon?
1,751 次查看
nattapongsungch
Thank you , It's work.
