The program can not be loaded into the MCU
2,011件の閲覧回数
增强祝
The program can not be loaded into the MCU. However, it worked normally last days.
タグ(1)
1,880件の閲覧回数
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
1,880件の閲覧回数
增强祝
Thanks for your response.
The problem has been solved.The reason is that the wire connecting the PC and MCU is broken.
Best wishes!
