The program can not be loaded into the MCU
1,463 次查看
增强祝
The program can not be loaded into the MCU. However, it worked normally last days.
标记 (1)
1,332 次查看
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
1,332 次查看
增强祝
Thanks for your response.
The problem has been solved.The reason is that the wire connecting the PC and MCU is broken.
Best wishes!
