How to Fix This Issue default_isr entered on vector 3 in Codewarrior ,Why ?
1,887 次查看
tholkapiyanv
HI,
    i'm using CW 10.6/ CW 11.0,
    sprintf use for Float point , sprintf function use that time jump to default_isr entered on vector 3 in Codewarrior.
How to fix this problem.
Kindly anyone give me solution.
Thanks & Regards
V. THOLKAPIYAN
1,740 次查看
Hello V.THOLKAPIYAN,
I test the sprintf with a simple proejct , it can work well :
TIC
4 回复数
1,740 次查看
Hello Tholkapiyan V  ,
 To investigate the issure, please tell us the chip you used , and the project .
Alice
1,740 次查看
tholkapiyanv
Hi Alice_Yang ,
     My Project using MK70FN1M0VMJ12 Processor
Thanks & Regards,
V.THOLKAPIYAN
1,741 次查看
TIC
1,740 次查看
tholkapiyanv
Hi Alice_Yang,
          Thanks for your reply.
          i will check again
Thanks & Regards
V.THOLKAPIYAN
