Console output CodeWarrior S12ZVC
2,099 次查看
christinar
Hello together,
I use the S912ZCV19 microcontroller and would like to make an output with printf(). If I include the "stdio.h" it still shows an error. I don´t use Processor Expert.
How can I print basic stuff on the console?
3 回复数
1,940 次查看
ZhangJennie
For CW for S12Z, printf() is not possible since there is NO "standard output" in embedded system. User has to implement their own "pseudo" prinf() function, i.e. to format the output in memory and then print out through SCI.
Jennie Zhang
1,940 次查看
christinar
Thank you very much
1,940 次查看
ZhangJennie
You are welcome!
Jennie Zhang
