PN7150 NFC Controller on i.MX8M mini evk running Yocto
This documents describes how to add the NFC support to i.MX8M mini evk running Yocto.
Hardware setup:
The i.MX8M mini evk (see i.MX 8M Mini Evaluation Kit | NXP) featuring Raspberry Pi compliant connector, the OM5578/RPI PN7150 demo kit can be used to perform this porting (see NFC Development Kits for Arduino and more|NXP). However a small modification must be done because some of the signals required by PN7150 are not mapped to i.MX8M mini expansion connector pins.
OM5578 IRQ signal must be mapped to Raspberry Pi connector pin #19 and OM5578 IRQ signal must be mapped to Raspberry Pi connector pin #21.
See below a picture of the modification:
Then, the two boards can fit together as shown in the picture below:
Quick start using demo image:
The demo image including support for PN7150, is based on i.MX Linux 4.14.78_1.0.0 BSP software release (see i.MX Software | NXP).
Related documentation can be downloaded from here: https://www.nxp.com/webapp/Download?colCode=L4.14.78_1.0.0_LINUX_DOCS.
Just flash the demo image (downloaded from here: https://www.nxp.com/lgfiles/updates/NFC/LINUX_L4-14-78_IMAGE_MX8MMEVK.zip) following guidelines from i.MX_Linux_User's_Guide document (part of L4.14.78_1.0.0_LINUX Documentation package mentioned above).
Then in a terminal you can run the demo application included in the image executing the command:
   # nfcDemoApp poll
Approaching the NFC tag, provided as reference in the OM5578 demo kit, to the NFC Antenna will trigger such display:
Adding PN7150 support to imx-linux-sumo release:
Pre-condition is to have L4.14.78_1.0.0 release installed and already built as described in i.MX Yocto Project User's Guide (part of L4.14.78_1.0.0_LINUX Documentation package mentioned above) :
    $ repo init -u https://source.codeaurora.org/external/imx/imx-manifest  -b imx-linux-sumo -m imx-4.14.78-1.0.0_ga.xml
    $ repo sync
    $ MACHINE=imx8mmevk DISTRO=fsl-imx-xwayland source fsl-setup-release.sh -b build_dir
    $ bitbake fsl-image-validation-imx
Then to add PN7150 support to your imx-linux-sumo environment, follow below step by step guidelines:
    $ git clone https://github.com/NXPNFCLinux/meta-nxp-nfc.git
  • Define hardware connection between CPU and PN7150 in device-tree adding the following lines to file build_dir/tmp/work-shared/imx8mmevk/kernel-source/arch/arm64/boot/dts/freescale/fsl-imx8mm-evk.dts:
@@ -227,6 +227,8 @@
                        fsl,pins = <
                                MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL                  0x400001c3
                                MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA                  0x400001c3
+                               MX8MM_IOMUXC_ECSPI2_MOSI_GPIO5_IO11             0x41
+                               MX8MM_IOMUXC_ECSPI2_MISO_GPIO5_IO12             0x41
@@ -747,6 +749,13 @@
        pinctrl-0 = <&pinctrl_i2c3>;
        status = "okay";
+       pn54x: pn54x@28 {
+               compatible ="nxp,pn547";
+               reg = <0x28>;
+               interrupt-gpios = <&gpio5 11 0>;
+               enable-gpios = <&gpio5 12 0>;
        pca6416: gpio@20 {
                compatible = "ti,tca6416";
                reg = <0x20>;
  • Add the meta-nxp-nfc layer to the build definition updating file build_dir/conf/bblayers.conf with:
BBLAYERS += " ${BSPDIR}/sources/meta-nxp-nfc"
  • Add the meta-nxp-nfc layer components to the image definition updating file build_dir/conf/local.conf with:
IMAGE_INSTALL_append = " kernel-module-nxp-pn5xx nxp-nfc-bin "
  • Re-build the linux kernel:
    $ bitbake -f -c compile linux-imx && bitbake -f -c deploy linux-imx
  • Build meta-nxp-nfc layer:
    $ bitbake nxp-nfc
  • Re-build the complete image to include the modifications:
Then you can flash the updated image to your i.MX8M mini evk and run the demo application as described in above "Quick start using demo image" chapter.
Reference:
This porting have been done (demo image and instructions) following guidelines provided in AN11679_PN71xx_Linux_Software_Stack_Integration_Guidelines document.
%3CLINGO-SUB%20id%3D%22lingo-sub-1125177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7150%20NFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC(i.MX8M%20mini%20evk%E4%B8%8A%E3%80%81Yocto)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20class%3D%22%22%3E%3CH1%20id%3D%22toc-hId-382482157%22%20id%3D%22toc-hId-1303292172%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81Yocto%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%20mini%20evk%E3%81%ABNFC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1073043631%22%20id%3D%22toc-hId-1993853646%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%EF%BC%9A%3C%2FH2%3E%3CP%3Ei.MX8M%20mini%20evk%20(%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fsupport%252Fdeveloper-resources%252Fsoftware-development-tools%252Fi.mx-developer-resources%252Fevaluation-kit-for-the-i.mx-8m-mini-applications-processor%253A8MMINILPD4-EVK%22%20target%3D%22_blank%22%3Ei.MX%208M%20Mini%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%20%7CNXP%3C%2FA%3E)%E3%81%AFRaspberry%20Pi%E6%BA%96%E6%8B%A0%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81OM5578%20%2F%20RPI%20PN7150%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fproducts%252Fidentification-and-security%252Fnfc%252Fnfc-reader-ics%252Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%253AOM5578%22%20target%3D%22_blank%22%3EArduino%E7%94%A8%E3%81%AENFC%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%81%AA%E3%81%A9%7CNXP)%E3%81%A7%E3%81%99%3C%2FA%3E%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81PN7150%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%8Ci.MX8M%E3%83%9F%E3%83%8B%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%B0%8F%E3%81%95%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOM5578%20IRQ%20%E4%BF%A1%E5%8F%B7%E3%81%AF%20Raspberry%20Pi%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20%E3%83%94%E3%83%B3%20%2319%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81OM5578%20IRQ%20%E4%BF%A1%E5%8F%B7%E3%81%AF%20Raspberry%20Pi%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20%E3%83%94%E3%83%B3%20%2321%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F73038i0A62FF9D9D95D2FB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.jpg%22%20alt%3D%22pastedImage_12.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E5%8F%8E%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F73039i1F2EC70BB0AEF108%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.jpg%22%20alt%3D%22pastedImage_14.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--734410832%22%20id%3D%22toc-hId-186399183%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1753102001%22%20id%3D%22toc-hId--1621055280%22%3E%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3A%3C%2FH2%3E%3CP%3EPN7150%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%83%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81i.MX%20Linux%204.14.78_1.0.0%20BSP%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fsupport%252Fdeveloper-resources%252Fsoftware-development-tools%252Fi.mx-developer-resources%252Fi.mx-software-and-development-tool%253AIMX_SW%22%20target%3D%22_blank%22%3Ei.MX%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%7CNXP%3C%2FA%3E%E3%81%AE)%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL4.14.78_1.0.0_LINUX_DOCS%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL4.14.78_1.0.0_LINUX_DOCS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL4.14.78_1.0.0_LINUX_DOCS%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fdocs%252Fen%252Fsupporting-information%252Fandroid_p9.0.0_1.0.0-ga_docs.zip%22%20target%3D%22_blank%22%3E.%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99(%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FNFC%2FLINUX_L4-14-78_IMAGE_MX8MMEVK.zip%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FNFC%2FLINUX_L4-14-78_IMAGE_MX8MMEVK.zip%3C%2FA%3E%3C%2FSPAN%3E)i.MX_Linux_User%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88(L4.14.78_1.0.0_LINUX%E3%81%AE%E4%B8%80%E9%83%A8)%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%86s_Guide%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%23%20nfcDemoApp%20poll%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3EOM5578%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E5%8F%82%E7%85%A7%E3%81%A8%E3%81%97%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BNFC%E3%82%BF%E3%82%B0%E3%82%92NFC%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A1%A8%E7%A4%BA%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F73016i688CAD49BCFA550B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture%20du%202019-03-27%2014-47-02.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture%20du%202019-03-27%2014-47-02.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F73020iD31DBE3D1F86B29A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture%20du%202019-03-27%2014-47-02.png%22%20alt%3D%22Capture%20du%202019-03-27%2014-47-02.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20id%3D%22toc-hId--54352462%22%20id%3D%22toc-hId-866457553%22%3EPN7150%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%20imx-linux-sumo%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E8%BF%BD%E5%8A%A0%3A%3C%2FH2%3E%3CP%3EL4.14.78_1.0.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%20i.MX%20Yocto%20Project%20User's%20Guide%20(L4.14.78_1.0.0_LINUX%20%E3%81%AE%E4%B8%80%E9%83%A8)%20%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8)%20%3A%3C%2FP%3E%3C%2FDIV%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fimx-manifest%26nbsp%3B%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fimx-manifest%20%3C%2FA%3E-b%20imx-linux-sumo%20-m%20imx-4.14.78-1.0.0_ga.xml%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20MACHINE%3Dimx8mmevk%20DISTRO%3Dfsl-imx-xwayland%20%E3%82%BD%E3%83%BC%E3%82%B9%20fsl-setup-release.sh%20-b%20build_dir%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20bitbake%20fsl-image-validation-imx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81PN7150%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%20imx-linux-sumo%20%E7%92%B0%E5%A2%83%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Esources%3C%2FSPAN%3E%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E3%80%81meta-nxp-nfc%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc%22%20title%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%97%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FDIV%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%24%20git%20clone%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc.git%22%20title%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fmeta-nxp-nfc.git%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CDIV%20class%3D%22%22%3E%3CUL%3E%3CLI%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7CPU%E3%81%A8PN7150%E9%96%93%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Ebuild_dir%2Ftmp%2Fwork-shared%2Fimx8mmevk%2Fkernel-source%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-imx8mm-evk.dts%3C%2FSPAN%3E%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FDIV%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23008080%3B%22%3E%40%40%20-227%2C6%20%2B227%2C8%40%40%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20FSL%E3%80%81%E3%83%94%E3%83%B3%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20MX8MM_IOMUXC_I2C3_SCL_I2C3_SCL%200x400001c3%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20MX8MM_IOMUXC_I2C3_SDA_I2C3_SDA%200x400001c3%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%20MX8MM_IOMUXC_ECSPI2_MOSI_GPIO5_IO11%200x41%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%20MX8MM_IOMUXC_ECSPI2_MISO_GPIO5_IO12%200x41%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20%26gt%3B%3B%7D%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23008080%3B%22%3E%40%40%20-747%2C6%20%2B749%2C13%40%40%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c3%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20status%20%3D%20%22%E5%A4%A7%E4%B8%88%E5%A4%AB%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%20PN54X%3A%20pn54x%4028%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%82%E3%82%8A%26lt%3B0x28%26gt%3B%20%3D%22NXP%2CPN547%22%3B%20%2B%20reg%20%3D%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20GPioS%3D%20%26lt%3B%26amp%3BGPIO5%2011%200%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2012%200%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%20color%3A%20%23339966%3B%22%3E%20%2B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20PCA6416%3A%20gpio%4020%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20compatible%20%3D%20%22ti%2Ctca6416%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%20font-size%3A%2013px%3B%22%3E%20reg%20%3D%3B%26lt%3B0x20%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81meta-nxp-nfc%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E5%AE%9A%E7%BE%A9%E6%9B%B4%E6%96%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Ebuild_dir%2Fconf%2Fbblayers.conf%3C%2FSPAN%3E%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EBBLAYERS%20%2B%3D%20%22%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-nxp-nfc%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3Emeta-nxp-nfc%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%AE%9A%E7%BE%A9%E6%9B%B4%E6%96%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3Ebuild_dir%2Fconf%2Flocal.conf%3C%2FSPAN%3E%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20kernel-module-nxp-pn5xx%20nxp-nfc-bin%20%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20bitbake%20-f%20-c%20compile%20linux-imx%20%26amp%3B%26amp%3B%20bitbake%20-f%20-c%20deploy%20linux-imx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3EBuild%20meta-nxp-nfc%20layer%3A%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20bitbake%20nxp-nfc%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20bitbake%20fsl-image-validation-imx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92i.MX8M%20mini%20evk%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%80%8C%E3%83%87%E3%83%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AE%E7%AB%A0%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1861806925%22%20id%3D%22toc-hId--940996910%22%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FH2%3E%3CP%3E%E3%81%93%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%81%AF%E3%80%81%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11697.pdf%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11697.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN11679_PN71xx_Linux_Software_Stack_Integration_Guidelines%3C%2FA%3E%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%81%A8%E6%89%8B%E9%A0%86)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1125177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎03-27-2019 08:38 AM
更新者:
