Strange behaviour of the Advanced Programming Options
pascalschröer
Contributor V
Hi at all,
At the moment I'm writing my bachelor thesis about gas analystics. My company told me to take the Kinetis MK10DX128VLH7 MCU
for this project. I haven't found any evaluation board with this specific MCU. So I had the idea to take the FRDM K20D50M board and change
the processor, to simulate my ressources. Well, this idea works and I can program and debug my software! But now, I would like to
save some data in the internal eeprom and flash. So I need to change some settings in the Advanced Programming Options of the CW.
I'm using CW1.6 and there is the following screen:
So now the problem:
All times, when I change only one parameter of these settings for example the "Preserve Memory range" or the checkbox
"Preserve Partitioning for the device",I can't debug my program anymore. I get the following error message:
So I tried to reset the settings but that doesn't fix the error message! I have to delete the whole project and
reimport it, to be able to debug the device.
Does anyone has got an idea why I can't change these settings? b.t.w there is the same problem when I'm using CW1.4
Thanks for your help!
Pascal
pascalschröer
Contributor V
I have found a working way:
Insert the following text to the launch data:
<stringAttributekey="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ALTERNATIVE_ALGORITHM_PATH" value=""/>
<stringAttributekey="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_AUTO_SYNC" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_CURRENT_ALGORITHM_INDEX" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_CUSTOM_TRIM" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_DOTRIM" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_DO_PRESERVE_PARTITIONING" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ENABLE_FLASH_PROGRAMMING_DIALOG" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ERASE_PROGRAM_WITHOUT_ASKING" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_NGS_TRIM_OVERRIDE_REFERENCE_FREQUENCY" value="3276800"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PARTITION_PARAM" value="13314"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_ACTIVE" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_END" value="268451839"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_START" value="268435456"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_ACTIVE" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_END" value="335545343"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_START" value="335544320"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_ACTIVE" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_END" value="3"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_START" value="0"/>
Now the device will not be partition anymore and you can add the preserve ranges!
Pascal
pascalschröer
Contributor V
It seems that there is a problem only with the MK10/20DX128VLH7 series. With an other
MK10DX128VLH5 and MK20DX128VLH5 there is no problem...
trytohelp
Hi Pascal,
Unfortunately I don't have the MK10/20DX128VLH7 devices.
I've performed some tests with TWR-K20D72M (PK20DX256VLL7) and changing Advanced programming options, will not introduce issues.
According to the SR 1-1707246201, the problem has been reproduced by a colleague.
If you need more assistance, let me know.
Pascal
pascalschröer
Contributor V
Okay, thanks for your help.
Let's see what your colleagues say.
Please keep me up to date!
Pascal
pascalschröer
Contributor V
Pascal
trytohelp
Hi Pascal,
Thanks for info.
I will share it with colleague working on SR.
Pascal
pascalschröer
Contributor V
did you fix he problem?? Now, I can use the advanced program settings :smileywink:
Pascal
trytohelp
Hi Pascal,
Sorry for the delay of my answer.
I was in contact with colleague working on this issue through the SR 1-1707246201.
According to the info I've found it seems we were not able to reproduce the behavior on our side.
Colleague proposed you (June 2014) to use the KDS.
What's new ?
KDS V3.0 is the last version released in May 2015
CW for MCU v10.6.4 was released in May 2015 too and a new patch MCU V10.6.5 was released 2 days ago.
Can I suggest you to install both versions and check if the problem has been solved ?
Pascal
Freescale Technical Support
pascalschröer
Contributor V
The problem is fixed! There aren't any problems anymore!
Thanks for your help.
Pascal
trytohelp
Hi Pascal,
I've some problem to check it.
Please can I ask you to create a SR for this problem ?
Put in the subject "For Pascal" or give me the SR#.
Pascal
