Strange behaviour of the Advanced Programming Options
6,022 次查看
pascalschröer
Hi at all,
At the moment I'm writing my bachelor thesis about gas analystics. My company told me to take the Kinetis MK10DX128VLH7 MCU
for this project. I haven't found any evaluation board with this specific MCU. So I had the idea to take the FRDM K20D50M board and change
the processor, to simulate my ressources. Well, this idea works and I can program and debug my software! But now, I would like to
save some data in the internal eeprom and flash. So I need to change some settings in the Advanced Programming Options of the CW.
I'm using CW1.6 and there is the following screen:
So now the problem:
All times, when I change only one parameter of these settings for example the "Preserve Memory range" or the checkbox
"Preserve Partitioning for the device",I can't debug my program anymore. I get the following error message:
So I tried to reset the settings but that doesn't fix the error message! I have to delete the whole project and
reimport it, to be able to debug the device.
Does anyone has got an idea why I can't change these settings? b.t.w there is the same problem when I'm using CW1.4
Thanks for your help!
Pascal
5,462 次查看
pascalschröer
I have found a working way:
Insert the following text to the launch data:
<stringAttributekey="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ALTERNATIVE_ALGORITHM_PATH" value=""/>
<stringAttributekey="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_AUTO_SYNC" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_CURRENT_ALGORITHM_INDEX" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_CUSTOM_TRIM" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_DOTRIM" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_DO_PRESERVE_PARTITIONING" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ENABLE_FLASH_PROGRAMMING_DIALOG" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_ERASE_PROGRAM_WITHOUT_ASKING" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_NGS_TRIM_OVERRIDE_REFERENCE_FREQUENCY" value="3276800"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PARTITION_PARAM" value="13314"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_ACTIVE" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_END" value="268451839"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE1_START" value="268435456"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_ACTIVE" value="1"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_END" value="335545343"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE2_START" value="335544320"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_ACTIVE" value="0"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_END" value="3"/>
<stringAttribute key="com.pemicro.mcu.debug.connections.pne.arm.PEDEBUG_PRESERVE3_START" value="0"/>
Now the device will not be partition anymore and you can add the preserve ranges!
Pascal
9 回复数
5,462 次查看
pascalschröer
It seems that there is a problem only with the MK10/20DX128VLH7 series. With an other
MK10DX128VLH5 and MK20DX128VLH5 there is no problem...
5,462 次查看
trytohelp
Hi Pascal,
Unfortunately I don't have the MK10/20DX128VLH7 devices.
I've performed some tests with TWR-K20D72M (PK20DX256VLL7) and changing Advanced programming options, will not introduce issues.
According to the SR 1-1707246201, the problem has been reproduced by a colleague.
If you need more assistance, let me know.
Pascal
5,462 次查看
pascalschröer
Okay, thanks for your help.
Let's see what your colleagues say.
Please keep me up to date!
Pascal
5,462 次查看
pascalschröer
Pascal
5,462 次查看
trytohelp
Hi Pascal,
Thanks for info.
I will share it with colleague working on SR.
Pascal
5,462 次查看
pascalschröer
did you fix he problem?? Now, I can use the advanced program settings :smileywink:
Pascal
5,462 次查看
trytohelp
Hi Pascal,
Sorry for the delay of my answer.
I was in contact with colleague working on this issue through the SR 1-1707246201.
According to the info I've found it seems we were not able to reproduce the behavior on our side.
Colleague proposed you (June 2014) to use the KDS.
What's new ?
KDS V3.0 is the last version released in May 2015
CW for MCU v10.6.4 was released in May 2015 too and a new patch MCU V10.6.5 was released 2 days ago.
Can I suggest you to install both versions and check if the problem has been solved ?
Pascal
Freescale Technical Support
5,462 次查看
pascalschröer
The problem is fixed! There aren't any problems anymore!
Thanks for your help.
Pascal
5,462 次查看
trytohelp
Hi Pascal,
I've some problem to check it.
Please can I ask you to create a SR for this problem ?
Put in the subject "For Pascal" or give me the SR#.
Pascal
