generate_ota_bootloader_and_program_it_to_flash.sh where to find in SDK_2.7.0_EVK-MIMXRT1060
2,040 次查看
felix1
SDK_2.7.0_EVK-MIMXRT1060, in AWS OTA User Guide.pdf p.46. where to find this shell script?
4 回复数
1,916 次查看
felix1
1) Can your bootloader jump to the application success? If you can success, show me the console log for me to trace the steps.
2) Next, can you use AWS to do OTA? If you can success, maybe you can give me the modified user guide document.
1,916 次查看
jeremyzhou
Hi Felix Shih,
After contacting with the AE team, the AWS OTA User Guide is not 100% suit for the SDK_2.7.0 version, so the AE team suggest the developer refer to the readme file to get started.
TIC
1,916 次查看
felix1
Never mind the AWS in this moment, even I follow the evkmimxrt1060_ota_bootloader, evkmimxrt1060_ota_demo_enet readme, I still fail to run the application.
How to fix it?
1,916 次查看
jeremyzhou
Hi Felix Shih,
Thanks for your reply.
1) How to fix it?
-- I'd like to know what exactly the problem you encounter now, otherwise, I've no idea how to move next.
TIC
