RT1052的SDRAM的IPTXDAT寄存器的配置问题
311件の閲覧回数
FromCH0
NXP技术支持:
      您好!
      以下是NXP官方RT1052的SDK中的.ini文件中的SDRAM初始化部分:
FUNC void _sdr_Init(void)
// Config IOMUX
_WDWORD(0x401F8014, 0x00000000);
_WDWORD(0x401F8018, 0x00000000);
_WDWORD(0x401F801C, 0x00000000);
_WDWORD(0x401F8020, 0x00000000);
_WDWORD(0x401F8024, 0x00000000);
_WDWORD(0x401F8028, 0x00000000);
_WDWORD(0x401F802C, 0x00000000);
_WDWORD(0x401F8030, 0x00000000);
_WDWORD(0x401F8034, 0x00000000);
_WDWORD(0x401F8038, 0x00000000);
_WDWORD(0x401F803C, 0x00000000);
_WDWORD(0x401F8040, 0x00000000);
_WDWORD(0x401F8044, 0x00000000);
_WDWORD(0x401F8048, 0x00000000);
_WDWORD(0x401F804C, 0x00000000);
_WDWORD(0x401F8050, 0x00000000);
_WDWORD(0x401F8054, 0x00000000);
_WDWORD(0x401F8058, 0x00000000);
_WDWORD(0x401F805C, 0x00000000);
_WDWORD(0x401F8060, 0x00000000);
_WDWORD(0x401F8064, 0x00000000);
_WDWORD(0x401F8068, 0x00000000);
_WDWORD(0x401F806C, 0x00000000);
_WDWORD(0x401F8070, 0x00000000);
_WDWORD(0x401F8074, 0x00000000);
_WDWORD(0x401F8078, 0x00000000);
_WDWORD(0x401F807C, 0x00000000);
_WDWORD(0x401F8080, 0x00000000);
_WDWORD(0x401F8084, 0x00000000);
_WDWORD(0x401F8088, 0x00000000);
_WDWORD(0x401F808C, 0x00000000);
_WDWORD(0x401F8090, 0x00000000);
_WDWORD(0x401F8094, 0x00000000);
_WDWORD(0x401F8098, 0x00000000);
_WDWORD(0x401F809C, 0x00000000);
_WDWORD(0x401F80A0, 0x00000000);
_WDWORD(0x401F80A4, 0x00000000);
_WDWORD(0x401F80A8, 0x00000000);
_WDWORD(0x401F80AC, 0x00000000);
_WDWORD(0x401F80B0, 0x00000010); // EMC_39, DQS PIN, enable SION
// PAD ctrl
// drive strength = 0x7 to increase drive strength
// otherwise the data7 bit may fail.
_WDWORD(0x401F8204, 0x000110F9);
_WDWORD(0x401F8208, 0x000110F9);
_WDWORD(0x401F820C, 0x000110F9);
_WDWORD(0x401F8210, 0x000110F9);
_WDWORD(0x401F8214, 0x000110F9);
_WDWORD(0x401F8218, 0x000110F9);
_WDWORD(0x401F821C, 0x000110F9);
_WDWORD(0x401F8220, 0x000110F9);
_WDWORD(0x401F8224, 0x000110F9);
_WDWORD(0x401F8228, 0x000110F9);
_WDWORD(0x401F822C, 0x000110F9);
_WDWORD(0x401F8230, 0x000110F9);
_WDWORD(0x401F8234, 0x000110F9);
_WDWORD(0x401F8238, 0x000110F9);
_WDWORD(0x401F823C, 0x000110F9);
_WDWORD(0x401F8240, 0x000110F9);
_WDWORD(0x401F8244, 0x000110F9);
_WDWORD(0x401F8248, 0x000110F9);
_WDWORD(0x401F824C, 0x000110F9);
_WDWORD(0x401F8250, 0x000110F9);
_WDWORD(0x401F8254, 0x000110F9);
_WDWORD(0x401F8258, 0x000110F9);
_WDWORD(0x401F825C, 0x000110F9);
_WDWORD(0x401F8260, 0x000110F9);
_WDWORD(0x401F8264, 0x000110F9);
_WDWORD(0x401F8268, 0x000110F9);
_WDWORD(0x401F826C, 0x000110F9);
_WDWORD(0x401F8270, 0x000110F9);
_WDWORD(0x401F8274, 0x000110F9);
_WDWORD(0x401F8278, 0x000110F9);
_WDWORD(0x401F827C, 0x000110F9);
_WDWORD(0x401F8280, 0x000110F9);
_WDWORD(0x401F8284, 0x000110F9);
_WDWORD(0x401F8288, 0x000110F9);
_WDWORD(0x401F828C, 0x000110F9);
_WDWORD(0x401F8290, 0x000110F9);
_WDWORD(0x401F8294, 0x000110F9);
_WDWORD(0x401F8298, 0x000110F9);
_WDWORD(0x401F829C, 0x000110F9);
_WDWORD(0x401F82A0, 0x000110F9);
// Config SDR Controller Registers/
_WDWORD(0x402F0000,0x10000004); // MCR
_WDWORD(0x402F0008,0x00000081); // BMCR0
_WDWORD(0x402F000C,0x00000081); // BMCR1
_WDWORD(0x402F0010,0x8000001B); // BR0, 32MB
_WDWORD(0x402F0040,0x00000F07); // SDRAMCR0
_WDWORD(0x402F0044,0x00652922); // SDRAMCR1
_WDWORD(0x402F0048,0x00010920); // SDRAMCR2
_WDWORD(0x402F004C,0x50210A08); // SDRAMCR3
_WDWORD(0x402F0090,0x80000000); // IPCR0
_WDWORD(0x402F0094,0x00000002); // IPCR1
_WDWORD(0x402F0098,0x00000000); // IPCR2
_WDWORD(0x402F009C,0xA55A000F); // IPCMD, SD_CC_IPREA
SDRAM_WaitIpCmdDone();
_WDWORD(0x402F009C,0xA55A000C); // SD_CC_IAF
_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
_WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS
_WDWORD(0x402F004C,0x08080A01 ); // enable sdram self refresh again after initialization done.
我查了官方的RM(参考手册),然后,还是不理解“_WDWORD(0x402F00A0,0x00000030); // IPTXDAT”这个语句中,为何要把0x402F00A0这一寄存器的数据配置成x00000030。事实上,RM中,这部分描述很少。网上有种说法,说这是为了配置成“0011 = CAS Latency = 3个时钟周期”,对吗?
谢谢!
248件の閲覧回数
mayliu1
Hi @FromCH0 ,
Thank you so much for your interest in our products and for using our community.
"_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
 _WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS" is used to write the mode register inside the SDRAM memory.
To init one SDRAM, we need to configure the mode register inside the SDRAM memory, below is an example of mode register in the SDRAM. It configured Latency mode, burst type, burst length and etc..
So 0x00000030 corresponds to the configuration value of the mode register inside the SDRAM. It configured the CAS latency to 3 and burst length to 1.
Wish it helps you
Best Regards
May Liu
249件の閲覧回数
mayliu1
Hi @FromCH0 ,
Wish it helps you
Best Regards
May Liu
242件の閲覧回数
FromCH0
感谢!
%3CLINGO-SUB%20id%3D%22lingo-sub-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERT1052%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BSDRAM%E3%81%AEIPTXDAT%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81NXP%E5%85%AC%E5%BC%8FRT1052%20SDK%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B.ini%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AESDRAM%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFUNC%20void%20_sdr_Init(void)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3E%2F%2F%20IOMUX%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E_WDWORD(0x401F8014%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8018%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F801C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8020%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8024%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8028%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F802C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8030%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8034%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8038%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F803C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8040%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8044%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8048%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F804C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8050%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8054%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8058%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F805C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8060%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8064%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8068%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F806C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8070%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8074%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8078%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F807C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8080%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8084%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8088%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F808C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8090%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8094%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8098%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F809C%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F80A0%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F80A4%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F80A8%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F80AC%2C%200x00000000)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F80B0%2C%200x00000010)%3B%20%2F%2F%20EMC_39%E3%80%81DQS%20PIN%E3%80%81SION%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20%E3%83%91%E3%83%83%E3%83%89%20Ctrl%3CBR%20%2F%3E%20%2F%2F%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E5%BC%B7%E5%BA%A6%20%3D%200x7%20%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E5%BC%B7%E5%BA%A6%E3%82%92%E4%B8%8A%E3%81%92%E3%82%8B%3CBR%20%2F%3E%2F%2F%20%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81data7%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E_WDWORD(0x401F8204%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8208%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F820C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8210%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8214%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8218%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F821C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8220%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8224%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8228%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F822C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8230%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8234%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8238%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F823C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8240%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8244%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8248%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F824C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8250%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8254%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8258%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F825C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8260%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8264%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8268%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F826C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8270%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8274%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8278%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F827C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8280%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8284%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8288%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F828C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8290%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8294%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F8298%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F829C%2C%200x000110F9)%3B%3CBR%20%2F%3E%20_WDWORD(0x401F82A0%2C%200x000110F9)%3B%3C%2FP%3E%3CP%3E%2F%2F%20SDR%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%2F%3CBR%20%2F%3E%20_WDWORD(0x402F0000%2C0x10000004)%3B%20%2F%2FMCR%3CBR%20%2F%3E%20_WDWORD(0x402F0008%2C0x00000081)%3B%20%2F%2F%20BMCR0%3CBR%20%2F%3E%20_WDWORD(0x402F000C%2C0x00000081)%3B%20%2F%2F%20BMCR1%3CBR%20%2F%3E%20_WDWORD(0x402F0010%2C0x8000001B)%3B%20%2F%2F%20BR0%E3%80%8132MB%3CBR%20%2F%3E%3CBR%20%2F%3E%20_WDWORD(0x402F0040%2C0x00000F07)%3B%20%2F%2F%20SDRAMCR0%3CBR%20%2F%3E%20_WDWORD(0x402F0044%2C0x00652922)%3B%20%2F%2F%20SDRAMCR1%3CBR%20%2F%3E%20_WDWORD(0x402F0048%2C0x00010920)%3B%20%2F%2F%20SDRAMCR2%3CBR%20%2F%3E%20_WDWORD(0x402F004C%2C0x50210A08)%3B%20%2F%2F%20SDRAMCR3%3C%2FP%3E%3CP%3E_WDWORD(0x402F0090%2C0x80000000)%3B%20%2F%2F%20IPCR0%3CBR%20%2F%3E%20_WDWORD(0x402F0094%2C0x00000002)%3B%20%2F%2F%20IPCR1%3CBR%20%2F%3E%20_WDWORD(0x402F0098%2C0x00000000)%3B%20%2F%2F%20IPCR2%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000F)%3B%20%2F%2F%20IPCMD%E3%80%81SD_CC_IPREA%3CBR%20%2F%3E%20SDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E%20_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%3CBR%20%2F%3E%20SDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E%20_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%3CBR%20%2F%3E%20SDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E%20_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%3CBR%20%2F%3E%20_WDWORD(0x402F009C%2C0xA55A000A)%3B%20%2F%2F%20SD_CC_IMS%3CBR%20%2F%3E%20SDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E%20_WDWORD(0x402F004C%2C0x08080A01)%3B%20%2F%2F%20%E5%88%9D%E6%9C%9F%E5%8C%96%E5%AE%8C%E4%BA%86%E5%BE%8C%E3%81%ABSDRAM%E3%81%AE%E8%87%AA%E5%B7%B1%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E5%85%AC%E5%BC%8F%E3%81%AE%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%EF%BC%88%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%EF%BC%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%A1%E3%83%B3%E3%83%88%E3%80%8C_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%E3%80%8D%E3%81%A7%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0x402F00A0%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8Cx00000030%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%81%BE%E3%81%A0%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E9%9A%9B%E3%80%81%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%A7%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8C0011%20%3D%20CAS%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%20%3D%203%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%80%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A0%E3%81%A8%E3%81%84%E3%81%86%E8%AA%AC%E3%81%8C%E3%83%8D%E3%83%83%E3%83%88%E4%B8%8A%E3%81%A7%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F191688%22%20target%3D%22_blank%22%3E%40FromCH0%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BC%8A%E7%A4%BE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%94%E9%96%A2%E5%BF%83%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%BE%E3%81%9F%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%22_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%3C%2FP%3E%0A%3CP%3E_WDWORD(0x402F009C%2C0xA55A000A)%3B%20%2F%2F%20SD_CC_IMS%22%20%E3%81%AF%E3%80%81SDRAM%20%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESDRAM%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SDRAM%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81SDRAM%E5%86%85%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%80%81%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%95%B7%E3%81%AA%E3%81%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382732i40F77C9220BE008F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211.png%22%20alt%3D%2211.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%810x00000030%E3%81%AFSDRAM%E5%86%85%E9%83%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E5%80%A4%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CAS%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%923%E3%80%81%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%95%B7%E3%82%921%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%A1%E3%82%A4%E3%83%BB%E3%83%AA%E3%82%A6%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
