RT1052的SDRAM的IPTXDAT寄存器的配置问题
300 次查看
FromCH0
NXP技术支持:
      您好!
      以下是NXP官方RT1052的SDK中的.ini文件中的SDRAM初始化部分:
FUNC void _sdr_Init(void)
// Config IOMUX
_WDWORD(0x401F8014, 0x00000000);
_WDWORD(0x401F8018, 0x00000000);
_WDWORD(0x401F801C, 0x00000000);
_WDWORD(0x401F8020, 0x00000000);
_WDWORD(0x401F8024, 0x00000000);
_WDWORD(0x401F8028, 0x00000000);
_WDWORD(0x401F802C, 0x00000000);
_WDWORD(0x401F8030, 0x00000000);
_WDWORD(0x401F8034, 0x00000000);
_WDWORD(0x401F8038, 0x00000000);
_WDWORD(0x401F803C, 0x00000000);
_WDWORD(0x401F8040, 0x00000000);
_WDWORD(0x401F8044, 0x00000000);
_WDWORD(0x401F8048, 0x00000000);
_WDWORD(0x401F804C, 0x00000000);
_WDWORD(0x401F8050, 0x00000000);
_WDWORD(0x401F8054, 0x00000000);
_WDWORD(0x401F8058, 0x00000000);
_WDWORD(0x401F805C, 0x00000000);
_WDWORD(0x401F8060, 0x00000000);
_WDWORD(0x401F8064, 0x00000000);
_WDWORD(0x401F8068, 0x00000000);
_WDWORD(0x401F806C, 0x00000000);
_WDWORD(0x401F8070, 0x00000000);
_WDWORD(0x401F8074, 0x00000000);
_WDWORD(0x401F8078, 0x00000000);
_WDWORD(0x401F807C, 0x00000000);
_WDWORD(0x401F8080, 0x00000000);
_WDWORD(0x401F8084, 0x00000000);
_WDWORD(0x401F8088, 0x00000000);
_WDWORD(0x401F808C, 0x00000000);
_WDWORD(0x401F8090, 0x00000000);
_WDWORD(0x401F8094, 0x00000000);
_WDWORD(0x401F8098, 0x00000000);
_WDWORD(0x401F809C, 0x00000000);
_WDWORD(0x401F80A0, 0x00000000);
_WDWORD(0x401F80A4, 0x00000000);
_WDWORD(0x401F80A8, 0x00000000);
_WDWORD(0x401F80AC, 0x00000000);
_WDWORD(0x401F80B0, 0x00000010); // EMC_39, DQS PIN, enable SION
// PAD ctrl
// drive strength = 0x7 to increase drive strength
// otherwise the data7 bit may fail.
_WDWORD(0x401F8204, 0x000110F9);
_WDWORD(0x401F8208, 0x000110F9);
_WDWORD(0x401F820C, 0x000110F9);
_WDWORD(0x401F8210, 0x000110F9);
_WDWORD(0x401F8214, 0x000110F9);
_WDWORD(0x401F8218, 0x000110F9);
_WDWORD(0x401F821C, 0x000110F9);
_WDWORD(0x401F8220, 0x000110F9);
_WDWORD(0x401F8224, 0x000110F9);
_WDWORD(0x401F8228, 0x000110F9);
_WDWORD(0x401F822C, 0x000110F9);
_WDWORD(0x401F8230, 0x000110F9);
_WDWORD(0x401F8234, 0x000110F9);
_WDWORD(0x401F8238, 0x000110F9);
_WDWORD(0x401F823C, 0x000110F9);
_WDWORD(0x401F8240, 0x000110F9);
_WDWORD(0x401F8244, 0x000110F9);
_WDWORD(0x401F8248, 0x000110F9);
_WDWORD(0x401F824C, 0x000110F9);
_WDWORD(0x401F8250, 0x000110F9);
_WDWORD(0x401F8254, 0x000110F9);
_WDWORD(0x401F8258, 0x000110F9);
_WDWORD(0x401F825C, 0x000110F9);
_WDWORD(0x401F8260, 0x000110F9);
_WDWORD(0x401F8264, 0x000110F9);
_WDWORD(0x401F8268, 0x000110F9);
_WDWORD(0x401F826C, 0x000110F9);
_WDWORD(0x401F8270, 0x000110F9);
_WDWORD(0x401F8274, 0x000110F9);
_WDWORD(0x401F8278, 0x000110F9);
_WDWORD(0x401F827C, 0x000110F9);
_WDWORD(0x401F8280, 0x000110F9);
_WDWORD(0x401F8284, 0x000110F9);
_WDWORD(0x401F8288, 0x000110F9);
_WDWORD(0x401F828C, 0x000110F9);
_WDWORD(0x401F8290, 0x000110F9);
_WDWORD(0x401F8294, 0x000110F9);
_WDWORD(0x401F8298, 0x000110F9);
_WDWORD(0x401F829C, 0x000110F9);
_WDWORD(0x401F82A0, 0x000110F9);
// Config SDR Controller Registers/
_WDWORD(0x402F0000,0x10000004); // MCR
_WDWORD(0x402F0008,0x00000081); // BMCR0
_WDWORD(0x402F000C,0x00000081); // BMCR1
_WDWORD(0x402F0010,0x8000001B); // BR0, 32MB
_WDWORD(0x402F0040,0x00000F07); // SDRAMCR0
_WDWORD(0x402F0044,0x00652922); // SDRAMCR1
_WDWORD(0x402F0048,0x00010920); // SDRAMCR2
_WDWORD(0x402F004C,0x50210A08); // SDRAMCR3
_WDWORD(0x402F0090,0x80000000); // IPCR0
_WDWORD(0x402F0094,0x00000002); // IPCR1
_WDWORD(0x402F0098,0x00000000); // IPCR2
_WDWORD(0x402F009C,0xA55A000F); // IPCMD, SD_CC_IPREA
SDRAM_WaitIpCmdDone();
_WDWORD(0x402F009C,0xA55A000C); // SD_CC_IAF
_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
_WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS
_WDWORD(0x402F004C,0x08080A01 ); // enable sdram self refresh again after initialization done.
我查了官方的RM(参考手册),然后,还是不理解“_WDWORD(0x402F00A0,0x00000030); // IPTXDAT”这个语句中,为何要把0x402F00A0这一寄存器的数据配置成x00000030。事实上,RM中,这部分描述很少。网上有种说法,说这是为了配置成“0011 = CAS Latency = 3个时钟周期”,对吗?
谢谢!
237 次查看
mayliu1
Hi @FromCH0 ,
Thank you so much for your interest in our products and for using our community.
"_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
 _WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS" is used to write the mode register inside the SDRAM memory.
To init one SDRAM, we need to configure the mode register inside the SDRAM memory, below is an example of mode register in the SDRAM. It configured Latency mode, burst type, burst length and etc..
So 0x00000030 corresponds to the configuration value of the mode register inside the SDRAM. It configured the CAS latency to 3 and burst length to 1.
Wish it helps you
Best Regards
May Liu
238 次查看
mayliu1
Hi @FromCH0 ,
Wish it helps you
Best Regards
May Liu
231 次查看
FromCH0
感谢!
%3CLINGO-SUB%20id%3D%22lingo-sub-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E6%82%A8%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E4%BB%A5%E4%B8%8B%E6%98%AFNXP%E5%AE%98%E6%96%B9RT1052%E7%9A%84SDK%E4%B8%AD%E7%9A%84.ini%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84SDRAM%E5%88%9D%E5%A7%8B%E5%8C%96%E9%83%A8%E5%88%86%EF%BC%9A%3C%2FP%3E%3CP%3EFUNC%20void%20_sdr_Init(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F%2F%20Config%20IOMUX%3CBR%20%2F%3E_WDWORD(0x401F8014%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8018%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F801C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8020%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8024%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8028%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F802C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8030%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8034%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8038%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F803C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8040%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8044%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8048%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F804C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8050%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8054%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8058%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F805C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8060%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8064%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8068%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F806C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8070%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8074%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8078%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F807C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8080%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8084%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8088%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F808C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8090%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8094%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F8098%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F809C%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F80A0%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F80A4%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F80A8%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F80AC%2C%200x00000000)%3B%3CBR%20%2F%3E_WDWORD(0x401F80B0%2C%200x00000010)%3B%20%2F%2F%20EMC_39%2C%20DQS%20PIN%2C%20enable%20SION%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20PAD%20ctrl%3CBR%20%2F%3E%2F%2F%20drive%20strength%20%3D%200x7%20to%20increase%20drive%20strength%3CBR%20%2F%3E%2F%2F%20otherwise%20the%20data7%20bit%20may%20fail.%3CBR%20%2F%3E_WDWORD(0x401F8204%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8208%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F820C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8210%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8214%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8218%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F821C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8220%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8224%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8228%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F822C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8230%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8234%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8238%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F823C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8240%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8244%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8248%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F824C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8250%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8254%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8258%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F825C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8260%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8264%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8268%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F826C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8270%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8274%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8278%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F827C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8280%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8284%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8288%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F828C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8290%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8294%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F8298%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F829C%2C%200x000110F9)%3B%3CBR%20%2F%3E_WDWORD(0x401F82A0%2C%200x000110F9)%3B%3C%2FP%3E%3CP%3E%2F%2F%20Config%20SDR%20Controller%20Registers%2F%3CBR%20%2F%3E_WDWORD(0x402F0000%2C0x10000004)%3B%20%2F%2F%20MCR%3CBR%20%2F%3E_WDWORD(0x402F0008%2C0x00000081)%3B%20%2F%2F%20BMCR0%3CBR%20%2F%3E_WDWORD(0x402F000C%2C0x00000081)%3B%20%2F%2F%20BMCR1%3CBR%20%2F%3E_WDWORD(0x402F0010%2C0x8000001B)%3B%20%2F%2F%20BR0%2C%2032MB%3CBR%20%2F%3E%3CBR%20%2F%3E_WDWORD(0x402F0040%2C0x00000F07)%3B%20%2F%2F%20SDRAMCR0%3CBR%20%2F%3E_WDWORD(0x402F0044%2C0x00652922)%3B%20%2F%2F%20SDRAMCR1%3CBR%20%2F%3E_WDWORD(0x402F0048%2C0x00010920)%3B%20%2F%2F%20SDRAMCR2%3CBR%20%2F%3E_WDWORD(0x402F004C%2C0x50210A08)%3B%20%2F%2F%20SDRAMCR3%3C%2FP%3E%3CP%3E_WDWORD(0x402F0090%2C0x80000000)%3B%20%2F%2F%20IPCR0%3CBR%20%2F%3E_WDWORD(0x402F0094%2C0x00000002)%3B%20%2F%2F%20IPCR1%3CBR%20%2F%3E_WDWORD(0x402F0098%2C0x00000000)%3B%20%2F%2F%20IPCR2%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000F)%3B%20%2F%2F%20IPCMD%2C%20SD_CC_IPREA%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000A)%3B%20%2F%2F%20SD_CC_IMS%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%3CBR%20%2F%3E_WDWORD(0x402F004C%2C0x08080A01%20)%3B%20%2F%2F%20enable%20sdram%20self%20refresh%20again%20after%20initialization%20done.%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E6%88%91%E6%9F%A5%E4%BA%86%E5%AE%98%E6%96%B9%E7%9A%84RM%EF%BC%88%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%EF%BC%8C%E8%BF%98%E6%98%AF%E4%B8%8D%E7%90%86%E8%A7%A3%E2%80%9C_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%E2%80%9D%E8%BF%99%E4%B8%AA%E8%AF%AD%E5%8F%A5%E4%B8%AD%EF%BC%8C%E4%B8%BA%E4%BD%95%E8%A6%81%E6%8A%8A0x402F00A0%E8%BF%99%E4%B8%80%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%95%B0%E6%8D%AE%E9%85%8D%E7%BD%AE%E6%88%90x00000030%E3%80%82%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8CRM%E4%B8%AD%EF%BC%8C%E8%BF%99%E9%83%A8%E5%88%86%E6%8F%8F%E8%BF%B0%E5%BE%88%E5%B0%91%E3%80%82%E7%BD%91%E4%B8%8A%E6%9C%89%E7%A7%8D%E8%AF%B4%E6%B3%95%EF%BC%8C%E8%AF%B4%E8%BF%99%E6%98%AF%E4%B8%BA%E4%BA%86%E9%85%8D%E7%BD%AE%E6%88%90%E2%80%9C0011%20%3D%20CAS%20Latency%20%3D%203%E4%B8%AA%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E2%80%9D%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F191688%22%20target%3D%22_blank%22%3E%40FromCH0%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%22_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%3C%2FP%3E%0A%3CP%3E_WDWORD%20(0x402F009C%2C0xa55a000A)%3B%2F%2F%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%22%20%E7%94%A8%E4%BA%8E%E5%9C%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E5%86%85%E5%AD%98%E4%B8%AD%E5%86%99%E5%85%A5%E6%A8%A1%E5%BC%8F%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%80%E4%B8%AA%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E5%AD%98%E5%82%A8%E5%99%A8%E5%86%85%E9%85%8D%E7%BD%AE%E6%A8%A1%E5%BC%8F%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%98%AF%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E4%B8%AD%E7%9A%84%E6%A8%A1%E5%BC%8F%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%E5%AE%83%E5%8F%AF%E9%85%8D%E7%BD%AE%E5%BB%B6%E8%BF%9F%E6%A8%A1%E5%BC%8F%E3%80%81%E7%AA%81%E5%8F%91%E7%B1%BB%E5%9E%8B%E3%80%81%E7%AA%81%E5%8F%91%E9%95%BF%E5%BA%A6%E7%AD%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382732i40F77C9220BE008F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211.png%22%20alt%3D%2211.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C0x00000030%20%E5%AF%B9%E5%BA%94%E4%BA%8E%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E5%86%85%E9%83%A8%E6%A8%A1%E5%BC%8F%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E5%80%BC%E3%80%82%E5%AE%83%E5%B0%86%20CAS%20%E5%BB%B6%E8%BF%9F%E9%85%8D%E7%BD%AE%E4%B8%BA%203%EF%BC%8C%E7%AA%81%E5%8F%91%E9%95%BF%E5%BA%A6%E9%85%8D%E7%BD%AE%E4%B8%BA%201%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%88%98%E6%A2%85%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
