RT1052的SDRAM的IPTXDAT寄存器的配置问题
FromCH0
NXP技术支持:
      您好!
      以下是NXP官方RT1052的SDK中的.ini文件中的SDRAM初始化部分:
FUNC void _sdr_Init(void)
// Config IOMUX
_WDWORD(0x401F8014, 0x00000000);
_WDWORD(0x401F8018, 0x00000000);
_WDWORD(0x401F801C, 0x00000000);
_WDWORD(0x401F8020, 0x00000000);
_WDWORD(0x401F8024, 0x00000000);
_WDWORD(0x401F8028, 0x00000000);
_WDWORD(0x401F802C, 0x00000000);
_WDWORD(0x401F8030, 0x00000000);
_WDWORD(0x401F8034, 0x00000000);
_WDWORD(0x401F8038, 0x00000000);
_WDWORD(0x401F803C, 0x00000000);
_WDWORD(0x401F8040, 0x00000000);
_WDWORD(0x401F8044, 0x00000000);
_WDWORD(0x401F8048, 0x00000000);
_WDWORD(0x401F804C, 0x00000000);
_WDWORD(0x401F8050, 0x00000000);
_WDWORD(0x401F8054, 0x00000000);
_WDWORD(0x401F8058, 0x00000000);
_WDWORD(0x401F805C, 0x00000000);
_WDWORD(0x401F8060, 0x00000000);
_WDWORD(0x401F8064, 0x00000000);
_WDWORD(0x401F8068, 0x00000000);
_WDWORD(0x401F806C, 0x00000000);
_WDWORD(0x401F8070, 0x00000000);
_WDWORD(0x401F8074, 0x00000000);
_WDWORD(0x401F8078, 0x00000000);
_WDWORD(0x401F807C, 0x00000000);
_WDWORD(0x401F8080, 0x00000000);
_WDWORD(0x401F8084, 0x00000000);
_WDWORD(0x401F8088, 0x00000000);
_WDWORD(0x401F808C, 0x00000000);
_WDWORD(0x401F8090, 0x00000000);
_WDWORD(0x401F8094, 0x00000000);
_WDWORD(0x401F8098, 0x00000000);
_WDWORD(0x401F809C, 0x00000000);
_WDWORD(0x401F80A0, 0x00000000);
_WDWORD(0x401F80A4, 0x00000000);
_WDWORD(0x401F80A8, 0x00000000);
_WDWORD(0x401F80AC, 0x00000000);
_WDWORD(0x401F80B0, 0x00000010); // EMC_39, DQS PIN, enable SION
// PAD ctrl
// drive strength = 0x7 to increase drive strength
// otherwise the data7 bit may fail.
_WDWORD(0x401F8204, 0x000110F9);
_WDWORD(0x401F8208, 0x000110F9);
_WDWORD(0x401F820C, 0x000110F9);
_WDWORD(0x401F8210, 0x000110F9);
_WDWORD(0x401F8214, 0x000110F9);
_WDWORD(0x401F8218, 0x000110F9);
_WDWORD(0x401F821C, 0x000110F9);
_WDWORD(0x401F8220, 0x000110F9);
_WDWORD(0x401F8224, 0x000110F9);
_WDWORD(0x401F8228, 0x000110F9);
_WDWORD(0x401F822C, 0x000110F9);
_WDWORD(0x401F8230, 0x000110F9);
_WDWORD(0x401F8234, 0x000110F9);
_WDWORD(0x401F8238, 0x000110F9);
_WDWORD(0x401F823C, 0x000110F9);
_WDWORD(0x401F8240, 0x000110F9);
_WDWORD(0x401F8244, 0x000110F9);
_WDWORD(0x401F8248, 0x000110F9);
_WDWORD(0x401F824C, 0x000110F9);
_WDWORD(0x401F8250, 0x000110F9);
_WDWORD(0x401F8254, 0x000110F9);
_WDWORD(0x401F8258, 0x000110F9);
_WDWORD(0x401F825C, 0x000110F9);
_WDWORD(0x401F8260, 0x000110F9);
_WDWORD(0x401F8264, 0x000110F9);
_WDWORD(0x401F8268, 0x000110F9);
_WDWORD(0x401F826C, 0x000110F9);
_WDWORD(0x401F8270, 0x000110F9);
_WDWORD(0x401F8274, 0x000110F9);
_WDWORD(0x401F8278, 0x000110F9);
_WDWORD(0x401F827C, 0x000110F9);
_WDWORD(0x401F8280, 0x000110F9);
_WDWORD(0x401F8284, 0x000110F9);
_WDWORD(0x401F8288, 0x000110F9);
_WDWORD(0x401F828C, 0x000110F9);
_WDWORD(0x401F8290, 0x000110F9);
_WDWORD(0x401F8294, 0x000110F9);
_WDWORD(0x401F8298, 0x000110F9);
_WDWORD(0x401F829C, 0x000110F9);
_WDWORD(0x401F82A0, 0x000110F9);
// Config SDR Controller Registers/
_WDWORD(0x402F0000,0x10000004); // MCR
_WDWORD(0x402F0008,0x00000081); // BMCR0
_WDWORD(0x402F000C,0x00000081); // BMCR1
_WDWORD(0x402F0010,0x8000001B); // BR0, 32MB
_WDWORD(0x402F0040,0x00000F07); // SDRAMCR0
_WDWORD(0x402F0044,0x00652922); // SDRAMCR1
_WDWORD(0x402F0048,0x00010920); // SDRAMCR2
_WDWORD(0x402F004C,0x50210A08); // SDRAMCR3
_WDWORD(0x402F0090,0x80000000); // IPCR0
_WDWORD(0x402F0094,0x00000002); // IPCR1
_WDWORD(0x402F0098,0x00000000); // IPCR2
_WDWORD(0x402F009C,0xA55A000F); // IPCMD, SD_CC_IPREA
SDRAM_WaitIpCmdDone();
_WDWORD(0x402F009C,0xA55A000C); // SD_CC_IAF
_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
_WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS
_WDWORD(0x402F004C,0x08080A01 ); // enable sdram self refresh again after initialization done.
我查了官方的RM(参考手册),然后,还是不理解“_WDWORD(0x402F00A0,0x00000030); // IPTXDAT”这个语句中,为何要把0x402F00A0这一寄存器的数据配置成x00000030。事实上,RM中,这部分描述很少。网上有种说法,说这是为了配置成“0011 = CAS Latency = 3个时钟周期”,对吗?
谢谢!
mayliu1
Hi @FromCH0 ,
Thank you so much for your interest in our products and for using our community.
"_WDWORD(0x402F00A0,0x00000030); // IPTXDAT
 _WDWORD(0x402F009C,0xA55A000A); // SD_CC_IMS" is used to write the mode register inside the SDRAM memory.
To init one SDRAM, we need to configure the mode register inside the SDRAM memory, below is an example of mode register in the SDRAM. It configured Latency mode, burst type, burst length and etc..
So 0x00000030 corresponds to the configuration value of the mode register inside the SDRAM. It configured the CAS latency to 3 and burst length to 1.
Wish it helps you
Best Regards
May Liu
mayliu1
Hi @FromCH0 ,
Wish it helps you
Best Regards
May Liu
FromCH0
感谢!
%3CLINGO-SUB%20id%3D%22lingo-sub-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EConfiguration%20issues%20with%20the%20IPTXDAT%20register%20of%20the%20RT1052's%20SDRAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349956%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%20Technical%20Support%3A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20Hello!%3C%2FP%3E%3CP%3E%20%20%20%20%20%20Below%20is%20the%20SDRAM%20initialization%20section%20from%20the%20.ini%20file%20in%20the%20official%20NXP%20RT1052%20SDK%3A%3C%2FP%3E%3CP%3EFUNC%20void%20_sdr_Init(void)%20%3CBR%20%2F%3E%7B%20%3CBR%20%2F%3E%2F%2F%20Config%20IOMUX%20%3CBR%20%2F%3E_WDWORD(0x401F8014%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8018%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F801C%2C%200x00000000)%20%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8020%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8024%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8028%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F802C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_%20WDWORD(0x401F8030%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8034%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8038%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F803C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD%20(0x401F8040%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8044%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8048%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F804C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8050%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8054%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8058%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F805C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8060%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8064%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8068%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F806C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8070%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8074%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8078%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F807C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8080%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8084%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8088%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F808C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8090%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8094%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8098%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F809C%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F80A0%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F80A4%2C%200x00000000)%3B%20_WDWORD(%20%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F80A8%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F80AC%2C%200x00000000)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F80B0%2C%200x00000010)%3B%20%2F%2F%20EMC_39%2C%20DQS%20PIN%2C%20enable%20SION%20%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20PAD%20ctrl%20%3CBR%20%2F%3E%2F%2F%20drive%20strength%20%3D%200x7%20to%20increase%20drive%20strength%20%3CBR%20%2F%3E%2F%2F%20otherwise%20the%20data7%20bit%20may%20fail.%20%3CBR%20%2F%3E_WDWORD(0x401F8204%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8208%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F820C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8210%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_%20WDWORD(0x401F8214%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8218%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F821C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8220%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD%20(0x401F8224%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8228%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F822C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8230%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8234%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8238%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F823C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8240%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8244%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8248%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F824C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8250%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8254%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8258%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F825C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8260%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8264%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8268%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F826C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8270%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8274%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8278%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F827C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8280%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8284%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8288%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F828C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8290%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(%200x401F8294%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F8298%2C%200x000110F9).%20%3CBR%20%2F%3E%20_WDWORD(0x401F829C%2C%200x000110F9)%3B%20%3CBR%20%2F%3E_WDWORD(0x401F82A0%2C%200x000110F9).%3C%2FP%3E%3CP%3E%2F%2F%20Config%20SDR%20Controller%20Registers%2F%20%3CBR%20%2F%3E_WDWORD(0x402F0000%2C0x10000004)%3B%20%2F%2F%20MCR%20%3CBR%20%2F%3E_WDWORD(0x402F0008%2C0x00000081)%3B%20%2F%2F%20BMCR0%20%3CBR%20%2F%3E_WDWORD(0x402F000C%2C%200x00000081)%3B%20%2F%2F%20BMCR1%20%3CBR%20%2F%3E_WDWORD(0x402F0010%2C0x8000001B)%3B%20%2F%2F%20BR0%2C%2032MB%20%3CBR%20%2F%3E%3CBR%20%2F%3E_WDWORD(0x402F0040%2C0x00000F07)%3B%20%2F%2F%20SDRAMCR0%20%3CBR%20%2F%3E_WDWORD(0x402F0044%2C0x00652922%20)%3B%20%2F%2F%20SDRAMCR1%20%3CBR%20%2F%3E_WDWORD(0x402F0048%2C0x00010920)%3B%20%2F%2F%20SDRAMCR2%20%3CBR%20%2F%3E_WDWORD(0x402F004C%2C0x50210A08)%3B%20%2F%2F%20SDRAMCR3%3C%2FP%3E%3CP%3E_WDWORD(0x402F0090%2C0x80000000)%3B%20%2F%2F%20IPCR0%20%3CBR%20%2F%3E_WDWORD(0x402F0094%2C0x00000002)%3B%20%2F%2F%20IPCR1%20%3CBR%20%2F%3E_WDWORD(0x402F0098%2C0x00000000)%3B%20%2F%2F%20IPCR2%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000F)%3B%20%2F%2F%20IPCMD%2C%20SD_CC_IPREA%20%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%20%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%20%3CBR%20%2F%3ESDRAM_%20WaitIpCmdDone()%3B%20%3CBR%20%2F%3E_WDWORD(0x402F009C%2C0xA55A000C)%3B%20%2F%2F%20SD_CC_IAF%20%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%20%3CBR%20%2F%3E_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%20%3CBR%20%2F%3E_WDWORD(%200x402F009C%2C0xA55A000A)%3B%20%2F%2F%20SD_CC_IMS%20%3CBR%20%2F%3ESDRAM_WaitIpCmdDone()%3B%20%3CBR%20%2F%3E_WDWORD(0x402F004C%2C0x08080A01%20)%3B%20%2F%2F%20enable%20sdram%20self%20refresh%20again%20after%20initialization%20done.%20%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3EI%20checked%20the%20official%20RM%20(Reference%20Manual)%2C%20and%20then%2C%20I%20still%20don't%20understand%20why%20the%20register%200x402F00A0%20is%20configured%20to%20x00000030%20in%20the%20statement%20%22_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%22.%20In%20fact%2C%20there%20is%20very%20little%20description%20of%20this%20part%20of%20the%20RM.%20There%20is%20a%20statement%20on%20the%20web%20that%20this%20is%20configured%20as%20%220011%20%3D%20CAS%20Latency%20%3D%203%20clock%20cycles%22%2C%20right%3F%3C%2FP%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352793%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1052%E7%9A%84SDRAM%E7%9A%84IPTXDAT%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F191688%22%20target%3D%22_blank%22%3E%40FromCH0%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CP%3E%22_WDWORD(0x402F00A0%2C0x00000030)%3B%20%2F%2F%20IPTXDAT%3C%2FP%3E%0A%3CP%3E%26nbsp%3B_WDWORD(0x402F009C%2C0xA55A000A)%3B%20%2F%2F%20SD_CC_IMS%22%20is%20used%20to%20write%20the%20mode%20register%20inside%20the%20SDRAM%20memory.%3C%2FP%3E%0A%3CP%3ETo%20init%20one%20SDRAM%2C%20we%20need%20to%20configure%20the%20mode%20register%26nbsp%3Binside%20the%20SDRAM%20memory%2C%20below%20is%20an%20example%20of%20mode%20register%20in%20the%20SDRAM.%20It%20configured%20Latency%20mode%2C%20burst%20type%2C%20burst%20length%20and%20etc..%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382732i40F77C9220BE008F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211.png%22%20alt%3D%2211.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3ESo%26nbsp%3B0x00000030%20corresponds%20to%20the%20configuration%20value%20of%20the%20mode%20register%20inside%20the%20SDRAM.%20It%20configured%20the%20CAS%20latency%20to%203%20and%20burst%20length%20to%201.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EWish%20it%20helps%20you%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMay%20Liu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
