RT1020: ctr_nonce calculation algorithm, when is applied?
249 次查看
mastupristi
Senior Contributor I
I usually compute the ctr_nonce for BEE taking the nonce[127-32], and in the LSW I put address r-shifted by 4.
This is confirmed by documents [redacted] and also by code provided by SDK examples:
I usually use SW key or SW_GP2 key, and this simple algorithm make BEE works well.
However, I found another algorithm, significantly more complex:
[Redacted]
I wonder when this algorithm is used by BEE, and I would like more details on how H7 and H8 are used, because it is not clear from the drawing.
best regards
Max
Note: Some information or images have been removed as they referred to moderated information.
标记 (3)
197 次查看
Sam_Gao
However, I found another algorithm, significantly more complex....
@mastupristi What is your purpose? Please tell me the source of this screenshot, NXP's publicly available information has listed what can be disclosed.
198 次查看
Sam_Gao
