RT1051 PWM Capture Counter Stop
coderick
您好,最近在做关于RT1051的FlexPWM捕获项目时,遇到了计时器无法正常启动的问题,将分频代码去掉或者设为1分频时,Counter可以正常运行,但是设置2分频或更高的分频时Counter就停止了,这是什么原因?
void Capture_config(void)
    pwm_input_capture_param_t pwm_input_capture;
    gpio_pin_config_t PWM_pin_config;
    //初始化输入捕获管脚
    IOMUXC_SetPinMux(PWM2_PWMA03_IOMUXC, 0U);                             //设置外部引脚的复用功能
    IOMUXC_SetPinConfig(PWM2_PWMA03_IOMUXC, PWMC_INPUT_PAD_CONFIG_DATA);     //设置引脚的 pad 属性
    PWM_pin_config.direction = kGPIO_DigitalInput;
    PWM_pin_config.interruptMode = kGPIO_NoIntmode;
    GPIO_PinInit(PWM2_PWMA03_GPIO, PWM2_PWMA03_GPIO_PIN, &PWM_pin_config);
    //初始化输入捕获配置参数
    pwm_input_capture.captureInputSel = false;
    pwm_input_capture.edge0 = kPWM_RisingEdge;
    //pwm_input_capture.edge1 = kPWM_FallingEdge;
    pwm_input_capture.enableOneShotCapture = false;
    //pwm_input_capture.edgeCompareValue = 10;  //当captureInputSel为FALSE时,此处设值无意义
    pwm_input_capture.fifoWatermark = 0;
    PWM_SetupInputCapture(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_PwmA, &pwm_input_capture);
    //开启捕获中断
    //set_IRQn_Priority(PWM2_3_IRQn,Group4_PreemptPriority_0, Group4_SubPriority_0);//设置中断优先级
    //PWM_EnableInterrupts(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_CaptureA0InterruptEnable| kPWM_CaptureA1InterruptEnable );
    PWM_EnableInterrupts(PI_PWM_BASEADDR, kPWM_Module_3, kPWM_CaptureA0InterruptEnable );
    EnableIRQ(PWM2_3_IRQn);
* @brief  初始化 PWM  配置参数
* @retval 无
void PWM_config(void)
    pwm_config_t pwmConfig;//定义pwm 配置结构体
    PWM_Deinit(PI_PWM_BASEADDR, kPWM_Module_3);
    /*设置AHB总线时钟和IP总线时钟*/
    CLOCK_SetDiv(kCLOCK_IpgDiv, 0x3); /* Set IPG PODF to 3, divede by 4 */
    /*设置pwm 错误输入为高电平,表示没有错误,只有当pwm 没有错误输入或者禁止错误检测才能正常输出pwm波*/
    XBARA_Init(XBARA1);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault0);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault1);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault2);
    XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault3);
    PWM_GetDefaultConfig(&pwmConfig);
    pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle; //新值在上一个pwm周期输出结束之后加载到缓冲寄存器中
    pwmConfig.pairOperation = kPWM_Independent;      // 工作在独立模式
    pwmConfig.clockSource = kPWM_BusClock;
    pwmConfig.enableDebugMode = true;                // 使能DebugMode
    pwmConfig.prescale = kPWM_Prescale_Divide_128;    //1320000000/128/65535=16Hz=PWM最小频率
    //初始化 PWM 并且判断初始化是否成功
    if (PWM_Init(PI_PWM_BASEADDR, kPWM_Module_3, &pwmConfig) == kStatus_Fail)
        PRINTF("PWM initialization failed\n");
    Capture_config();
    PWM_SetPwmLdok(PI_PWM_BASEADDR,kPWM_Control_Module_3 , true);
    PWM_StartTimer(PI_PWM_BASEADDR, kPWM_Control_Module_3 );
Tags (2)
Gavin_Jia
Hi @coderick ,
Thanks for your interest in NXP MIMXRT series!
Did you set BOARD_PWM_BASEADDR->SM[3].VAL1 & INIT in your project? If VAL1 is still 0, it will cause a problem.
Gavin
Gavin_Jia
Hi @coderick ,
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2196192%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERT1051%20PWM%20Capture%20Counter%20Stop%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196192%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20recently%20when%20I%20was%20doing%20a%20project%20about%20FlexPWM%20capture%20on%20RT1051%2C%20I%20encountered%20a%20problem%20that%20the%20timer%20could%20not%20start%20properly%2C%20when%20I%20remove%20the%20crossover%20code%20or%20set%20it%20to%201%20crossover%20frequency%2C%20Counter%20can%20run%20normally%2C%20but%20when%20I%20set%20it%20to%202%20crossover%20frequency%20or%20higher%20crossover%20frequency%20Counter%20stops%2C%20what%20is%20the%20reason%20for%20this%3F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20Capture_config(void)%0A%7B%0A%20%20%20%20pwm_input_capture_param_t%20pwm_input_capture%3B%0A%20%20%20%20gpio_pin_config_t%20PWM_pin_config%3B%0A%20%20%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E7%AE%A1%E8%84%9A%0A%20%20%20%20IOMUXC_SetPinMux(PWM2_PWMA03_IOMUXC%2C%200U)%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%E8%AE%BE%E7%BD%AE%E5%A4%96%E9%83%A8%E5%BC%95%E8%84%9A%E7%9A%84%E5%A4%8D%E7%94%A8%E5%8A%9F%E8%83%BD%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20IOMUXC_SetPinConfig(PWM2_PWMA03_IOMUXC%2C%20PWMC_INPUT_PAD_CONFIG_DATA)%3B%20%20%20%20%20%2F%2F%E8%AE%BE%E7%BD%AE%E5%BC%95%E8%84%9A%E7%9A%84%20pad%20%E5%B1%9E%E6%80%A7%20%0A%0A%20%20%20%20PWM_pin_config.direction%20%3D%20kGPIO_DigitalInput%3B%0A%20%20%20%20PWM_pin_config.interruptMode%20%3D%20kGPIO_NoIntmode%3B%0A%0A%20%20%20%20GPIO_PinInit(PWM2_PWMA03_GPIO%2C%20PWM2_PWMA03_GPIO_PIN%2C%20%26amp%3BPWM_pin_config)%3B%0A%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%0A%20%20%20%20pwm_input_capture.captureInputSel%20%3D%20false%3B%0A%20%20%20%20pwm_input_capture.edge0%20%3D%20kPWM_RisingEdge%3B%0A%20%20%20%20%2F%2Fpwm_input_capture.edge1%20%3D%20kPWM_FallingEdge%3B%0A%20%20%20%20pwm_input_capture.enableOneShotCapture%20%3D%20false%3B%0A%20%20%20%20%2F%2Fpwm_input_capture.edgeCompareValue%20%3D%2010%3B%20%20%2F%2F%E5%BD%93captureInputSel%E4%B8%BAFALSE%E6%97%B6%EF%BC%8C%E6%AD%A4%E5%A4%84%E8%AE%BE%E5%80%BC%E6%97%A0%E6%84%8F%E4%B9%89%0A%20%20%20%20pwm_input_capture.fifoWatermark%20%3D%200%3B%0A%20%20%20%20PWM_SetupInputCapture(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_PwmA%2C%20%26amp%3Bpwm_input_capture)%3B%0A%0A%20%20%20%20%2F%2F%E5%BC%80%E5%90%AF%E6%8D%95%E8%8E%B7%E4%B8%AD%E6%96%AD%0A%20%20%20%20%2F%2Fset_IRQn_Priority(PWM2_3_IRQn%2CGroup4_PreemptPriority_0%2C%20Group4_SubPriority_0)%3B%2F%2F%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%96%AD%E4%BC%98%E5%85%88%E7%BA%A7%0A%20%20%20%20%2F%2FPWM_EnableInterrupts(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_CaptureA0InterruptEnable%7C%20kPWM_CaptureA1InterruptEnable%20)%3B%0A%20%20%20%20PWM_EnableInterrupts(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_CaptureA0InterruptEnable%20)%3B%0A%20%20%20%20EnableIRQ(PWM2_3_IRQn)%3B%20%20%0A%7D%0A%0A%20%2F**%0A*%20%40brief%20%20%E5%88%9D%E5%A7%8B%E5%8C%96%20PWM%20%20%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%20%0A*%20%40retval%20%E6%97%A0%0A*%2F%0Avoid%20PWM_config(void)%0A%7B%0A%20%20%20%20pwm_config_t%20pwmConfig%3B%2F%2F%E5%AE%9A%E4%B9%89pwm%20%E9%85%8D%E7%BD%AE%E7%BB%93%E6%9E%84%E4%BD%93%0A%0A%20%20%20%20PWM_Deinit(PI_PWM_BASEADDR%2C%20kPWM_Module_3)%3B%0A%20%20%20%20%2F*%E8%AE%BE%E7%BD%AEAHB%E6%80%BB%E7%BA%BF%E6%97%B6%E9%92%9F%E5%92%8CIP%E6%80%BB%E7%BA%BF%E6%97%B6%E9%92%9F*%2F%0A%20%20%20%20CLOCK_SetDiv(kCLOCK_IpgDiv%2C%200x3)%3B%20%2F*%20Set%20IPG%20PODF%20to%203%2C%20divede%20by%204%20*%2F%0A%0A%20%20%20%20%2F*%E8%AE%BE%E7%BD%AEpwm%20%E9%94%99%E8%AF%AF%E8%BE%93%E5%85%A5%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%EF%BC%8C%E8%A1%A8%E7%A4%BA%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%BD%93pwm%20%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E8%BE%93%E5%85%A5%E6%88%96%E8%80%85%E7%A6%81%E6%AD%A2%E9%94%99%E8%AF%AF%E6%A3%80%E6%B5%8B%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BE%93%E5%87%BApwm%E6%B3%A2*%2F%0A%20%20%20%20XBARA_Init(XBARA1)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault0)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault1)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault2)%3B%0A%20%20%20%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault3)%3B%20%0A%20%20%20%20%0A%20%20%20%20PWM_GetDefaultConfig(%26amp%3BpwmConfig)%3B%0A%20%20%20%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadPwmFullCycle%3B%20%2F%2F%E6%96%B0%E5%80%BC%E5%9C%A8%E4%B8%8A%E4%B8%80%E4%B8%AApwm%E5%91%A8%E6%9C%9F%E8%BE%93%E5%87%BA%E7%BB%93%E6%9D%9F%E4%B9%8B%E5%90%8E%E5%8A%A0%E8%BD%BD%E5%88%B0%E7%BC%93%E5%86%B2%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%0A%20%20%20%20pwmConfig.pairOperation%20%3D%20kPWM_Independent%3B%20%20%20%20%20%20%2F%2F%20%E5%B7%A5%E4%BD%9C%E5%9C%A8%E7%8B%AC%E7%AB%8B%E6%A8%A1%E5%BC%8F%0A%20%20%20%20pwmConfig.clockSource%20%3D%20kPWM_BusClock%3B%0A%20%20%20%20pwmConfig.enableDebugMode%20%3D%20true%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20%E4%BD%BF%E8%83%BDDebugMode%20%0A%20%20%20%20pwmConfig.prescale%20%3D%20kPWM_Prescale_Divide_128%3B%20%20%20%20%2F%2F1320000000%2F128%2F65535%3D16Hz%3DPWM%E6%9C%80%E5%B0%8F%E9%A2%91%E7%8E%87%0A%0A%20%20%20%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96%20PWM%20%E5%B9%B6%E4%B8%94%E5%88%A4%E6%96%AD%E5%88%9D%E5%A7%8B%E5%8C%96%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%0A%20%20%20%20if%20(PWM_Init(PI_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%0A%20%20%20%20%7D%0A%20%20%20%20Capture_config()%3B%0A%20%20%20%20PWM_SetPwmLdok(PI_PWM_BASEADDR%2CkPWM_Control_Module_3%20%2C%20true)%3B%20%20%20%0A%20%20%20%20PWM_StartTimer(PI_PWM_BASEADDR%2C%20kPWM_Control_Module_3%20)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2196192%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20105x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1051%20PWM%20Capture%20Counter%20Stop%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232480%22%20target%3D%22_blank%22%3E%40coderick%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20interest%20in%20NXP%20MIMXRT%20series!%3C%2FP%3E%0A%3CP%3EDid%20you%20set%26nbsp%3B%3CSPAN%3EBOARD_PWM_BASEADDR-%26gt%3BSM%5B3%5D.VAL1%20%26amp%3B%20INIT%20in%20your%20project%3F%20If%20VAL1%20is%20still%200%2C%20it%20will%20cause%20a%20problem.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBest%20regards%2C%3CBR%20%2F%3EGavin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
