IMXRT1024 UART Terminal Output Issue in Manual Configuration
2,215 次查看
Lukas_Frank
Senior Contributor I
Hi all,
UART Write and Read operations prints data to terminal screen (serial port configuration) successfully in SDK Pooling Example. But, there is not printing data to terminal screen when I create a project from scratch despite data communication is successfully occur. Why could be my example is not printing to terminal?
Thanks and Regards.
2,210 次查看
jeremyzhou
According to your statement, it seems like the print function doesn't link to UART Write successful, so I was wondering if you can describe the steps you created for a new project in detail.
TIC
2,211 次查看
jeremyzhou
TIC
2,202 次查看
Lukas_Frank
Hi Dear @jeremyzhou,
I will try to link them. Then, I'll turn here again.
Thanks and Regards.
