meta-updater Integration
mkent813
I am  trying to integrate meta-updater layer to fsl-imx--xwayland for imx6ulevk machine. I have followed the steps here:
https://docs.ota.here.com/ota-client/latest/add-ota-functonality-existing-yocto-project.html
However, trying to bitbake a recipe of the meta-updater layer (e.g. "bitbake aktualizr") gives me compilation error related to "coreutils". The log of the errors and my local.conf file are attached.
Any help would be appreciated.
Thank you
kingdekong
Hi mkent813
Have you integrate meta-updater to fsl-imx--xwayland for imx6ulevk machine succesfully?
if succes, could you please tell how to do?
Best wishes
jhnw
You can use our aktualizr-lite implementation with your i.mx projects.
Check out https://github.com/foundriesio/aktualizr-lite
Main product website: www.foundries.io
Docs: https://docs.foundries.io/latest/reference-manual/ota/aktualizr-lite.html
-J
Bio_TICFSL
Hello mkent813,
You must change your recipe to build your configuration, also you must change the fsl-imx-xwayland to nxp-xwayland, please check the yocto user guide:
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
