meta-updater Integration
4,562件の閲覧回数
mkent813
I am  trying to integrate meta-updater layer to fsl-imx--xwayland for imx6ulevk machine. I have followed the steps here:
https://docs.ota.here.com/ota-client/latest/add-ota-functonality-existing-yocto-project.html
However, trying to bitbake a recipe of the meta-updater layer (e.g. "bitbake aktualizr") gives me compilation error related to "coreutils". The log of the errors and my local.conf file are attached.
Any help would be appreciated.
Thank you
3 返答(返信)
3,949件の閲覧回数
kingdekong
Hi mkent813
Have you integrate meta-updater to fsl-imx--xwayland for imx6ulevk machine succesfully?
if succes, could you please tell how to do?
Best wishes
3,830件の閲覧回数
jhnw
You can use our aktualizr-lite implementation with your i.mx projects.
Check out https://github.com/foundriesio/aktualizr-lite
Main product website: www.foundries.io
Docs: https://docs.foundries.io/latest/reference-manual/ota/aktualizr-lite.html
-J
4,551件の閲覧回数
Bio_TICFSL
Hello mkent813,
You must change your recipe to build your configuration, also you must change the fsl-imx-xwayland to nxp-xwayland, please check the yocto user guide:
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
