imx8mp: Linux crashes during boot when the M7 core was already started by U-Boot
6,070 次查看
morix
Hello everybody,
I am working at running both A53 and M7 on an i.MX8M Plus at the same time.
Yocto-compiled Linux runs on top of A53 cores, while at the moment I am simply running MCUXpresso's hello_world demo on M7 (compiled for using TCM only).
I have configured remoteproc on Linux, and now I am perfectly able to start/stop M7 from Linux console, deploying to M7 the ELF of hello_world demo. And both (A53 and M7) work perfectly fine.
Now I am managing to fire the execution of M7 from U-Boot.
Even in this case everything is fine and I am able to start the M7 from U-Boot (deploying to M7 the BIN of hello_world demo). The problem arises when then I attempt to start Linux on A53s. The operating system crashes during boot with the following message:
[    2.914112] remoteproc remoteproc0: imx-rproc is available
[    2.923854] remoteproc remoteproc0: attaching to imx-rproc
[    2.929418] Unable to handle kernel paging request at virtual address ffff80000a264fff
[    2.937347] Mem abort info:
[    2.940154]   ESR = 0x0000000096000007
[    2.943920]   EC = 0x25: DABT (current EL), IL = 32 bits
[    2.947769] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    2.949239]   SET = 0, FnV = 0
[    2.959338]   EA = 0, S1PTW = 0
[    2.962476]   FSC = 0x07: level 3 translation fault
[    2.967354] Data abort info:
[    2.970230]   ISV = 0, ISS = 0x00000007
[    2.974066]   CM = 0, WnR = 0
[    2.977035] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000041d89000
[    2.983737] [ffff80000a264fff] pgd=1000000074eee003, p4d=1000000074eee003, pud=1000000074eed003, pmd=10000000444ef003, pte=0000000000000000
[    2.996274] Internal error: Oops: 0000000096000007 [#1] PREEMPT SMP
[    3.002539] Modules linked in:
[    3.005592] CPU: 2 PID: 8 Comm: kworker/u8:0 Not tainted 6.1.55+g97604c995a86 #1
[    3.012986] Hardware name: AESYS 2319A (DT)
[    3.016976] mmc1: host does not support reading read-only switch, assuming write-enable
[    3.017166] Workqueue: events_unbound deferred_probe_work_func
[    3.030991] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    3.037950] pc : rproc_handle_resources.constprop.0+0x8c/0x164
[    3.043786] lr : rproc_boot+0x304/0x580
[    3.047621] sp : ffff800009fab9f0
[    3.050931] x29: ffff800009fab9f0 x28: ffff000024d53a98 x27: ffff8000098bb780
[    3.050978] mmc1: new ultra high speed SDR104 SDHC card at address 0001
[    3.058068] x26: 0000000000000006 x25: ffffffffffffffff x24: ffff80000a265000
[    3.058074] x23: ffff000004a1c038
[    3.065096] mmcblk1: mmc1:0001 SD32G 28.9 GiB
[    3.071809]  x22: 0000000000000000 x21: ffff800009e1a2f0
[    3.071814] x20: ffff000004a1c000 x19: 0000000000000000 x18: 0000000000000006
[    3.071820] x17: 000000040044ffff x16: ffff000024cfc7e0 x15: ffffffffffffffff
[    3.071827] x14: fff7ffffffefffff x13: ffffffffffffffff
[    3.076558]  mmcblk1: p1 p2 p3 p4
[    3.079574]  x12: fff7ffffffefffff
[    3.079577] x11: ffffffffffffffff x10: ffffffffffffffff x9 : ffffffffffffffff
[    3.079584] x8 : ffffffffffffffff x7 : ffffffffffffffff x6 : ffffffffffffffff
[    3.125331] x5 : ffff000004b33000 x4 : ffff80000a265400 x3 : 00000000000003fd
[    3.132466] x2 : 00000000ffffffff x1 : ffff80000a265003 x0 : ffff80000a265000
[    3.139602] Call trace:
[    3.142045]  rproc_handle_resources.constprop.0+0x8c/0x164
[    3.147532]  rproc_boot+0x304/0x580
[    3.151019]  rproc_add+0xd0/0x170
[    3.154332]  imx_rproc_probe+0x464/0x5b0
[    3.158254]  platform_probe+0x68/0xc0
[    3.161915]  really_probe+0xbc/0x2dc
[    3.165490]  __driver_probe_device+0x78/0x114
[    3.169847]  driver_probe_device+0xd8/0x15c
[    3.174030]  __device_attach_driver+0xb8/0x134
[    3.178473]  bus_for_each_drv+0x80/0xdc
[    3.182308]  __device_attach+0xa0/0x1a0
[    3.186144]  device_initial_probe+0x14/0x20
[    3.190327]  bus_probe_device+0x98/0xa0
[    3.194162]  deferred_probe_work_func+0x80/0xc0
[    3.198693]  process_one_work+0x1d4/0x330
[    3.202702]  worker_thread+0x224/0x42c
[    3.206450]  kthread+0x108/0x10c
[    3.209676]  ret_from_fork+0x10/0x20
[    3.213253] Code: 128002b3 913f6021 97ffb5f6 1400002f (b8796b00)
[    3.219345] ---[ end trace 0000000000000000 ]---
I just suspect some troubles with memory reservation/mapping... but why does it happen only when M7 is started from U-Boot, and not if M7 is started from remoteproc?
The relevant portion of Linux DTS is the following:
&resmem {
  m7_reserved: m7@75000000 {
    no-map;
    reg = <0 0x75000000 0 0x1000000>;
  m7_vdev0vring0: vdev0vring0@74ff8000 {
    reg = <0 0x74ff8000 0 0x8000>;
    no-map;
  m7_vdev0vring1: vdev0vring1@74ff0000 {
    reg = <0 0x74ff0000 0 0x8000>;
    no-map;
  m7_vdevbuffer: vdevbuffer@74ef0000 {
    compatible = "shared-dma-pool";
    reg = <0 0x74ef0000 0 0x100000>;
    no-map;
  m7_rsc_table: rsc-table@74eef000 {
    reg = <0 0x74eef000 0 0x1000>;
    no-map;
  m7_itcm: m7-itcm@0x7e0000 {
    reg = <0 0x7e0000 0 0x20000>;
    no-map;
  m7_dtcm: m7-dtcm@0x800000 {
    reg = <0 0x800000 0 0x20000>;
    no-map;
  imx8mp-cm7 {
    compatible = "fsl,imx8mp-cm7";
    rsc-da = <0x74ff8000>;
    clocks = <&clk IMX8MP_CLK_M7_DIV>;
    clock-names = "core";
    mbox-names = "tx", "rx", "rxdb";
    mboxes = <&mu 0 1
      &mu 1 1
      &mu 3 1>;
    memory-region = <&m7_vdevbuffer>, <&m7_vdev0vring0>, <&m7_vdev0vring1>, <&m7_rsc_table>, <&m7_itcm>, <&m7_dtcm>;
    status = "okay";
    fsl,startup-delay-ms = <500>;
    fsl,auto-boot;
* ATTENTION: M7 may use IPs like below
* UART4
&uart4 {
  status = "disabled";
Any ideas?
Thanks + regards.
5,981 次查看
morix
Hello Harvey021,
thanks for your feedback.
I just found a viable solution: it turned out that:
  • vdev0vring0 and vdev0vring1 were swapped;
  • rsc-da must point to the base of vdev0ring0;
  • I had to modify M7's hello world source code in order to make sure that is exposes a resource table at the memory location pointed out by m7_rsc_table (so basically I replace the empty_rsc_table.c (and correspondent header) with the attached rsc_table.c (and correspondent header) and I also modified board.h (see attached file).
6,026 次查看
Harvey021
Try to run #mw 0x550ff000 0 4 to clear the garbage resource table area before running bootaux.
Harvey
5,982 次查看
morix
Hello Harvey021,
%3CLINGO-SUB%20id%3D%22lingo-sub-1866084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%EF%BC%9A%E5%BD%93%20M7%20%E6%A0%B8%E5%BF%83%E5%B7%B2%E7%94%B1%20U-Boot%20%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8CLinux%20%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%20i.MX8M%20Plus%20%E4%B8%8A%E5%90%8C%E6%97%B6%E8%BF%90%E8%A1%8C%20A53%20%E5%92%8C%20M7%E3%80%82%3C%2FP%3E%3CP%3EYocto%20%E7%BC%96%E8%AF%91%E7%9A%84%20Linux%20%E5%9C%A8%20A53%20%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E8%80%8C%E7%9B%AE%E5%89%8D%E6%88%91%E5%8F%AA%E6%98%AF%E5%9C%A8%20M7%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20MCUXpresso%20%E7%9A%84%20hello_world%20%E6%BC%94%E7%A4%BA%EF%BC%88%E4%BB%85%E4%B8%BA%E4%BD%BF%E7%94%A8%20TCM%20%E8%80%8C%E7%BC%96%E8%AF%91%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%20Linux%20%E4%B8%8A%E9%85%8D%E7%BD%AE%E4%BA%86%20remoteproc%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E5%AE%8C%E5%85%A8%E8%83%BD%E5%A4%9F%E4%BB%8E%20Linux%20%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%90%AF%E5%8A%A8%2F%E5%81%9C%E6%AD%A2%20M7%EF%BC%8C%E5%B9%B6%E5%B0%86%20hello_world%20%E6%BC%94%E7%A4%BA%E7%9A%84%20ELF%20%E9%83%A8%E7%BD%B2%E5%88%B0%20M7%E3%80%82%E5%B9%B6%E4%B8%94%E4%B8%A4%E8%80%85%EF%BC%88A53%20%E5%92%8C%20M7%EF%BC%89%E9%83%BD%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%AD%A3%E5%9C%A8%E8%AE%BE%E6%B3%95%E4%BB%8E%20U-Boot%20%E5%90%AF%E5%8A%A8%20M7%20%E7%9A%84%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E4%BB%8E%20U-Boot%20%E5%90%AF%E5%8A%A8%20M7%EF%BC%88%E5%B0%86%20hello_world%20%E6%BC%94%E7%A4%BA%E7%9A%84%20BIN%20%E9%83%A8%E7%BD%B2%E5%88%B0%20M7%EF%BC%89%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20A53s%20%E4%B8%8A%E5%90%AF%E5%8A%A8%20Linux%20%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%B4%A9%E6%BA%83%E5%B9%B6%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.914112%5Dremoteproc%20remoteproc0%3Aimx%20rproc%E5%8F%AF%E7%94%A8%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.923854%5Dremoteproc%20remoteproc0%3A%E8%BF%9E%E6%8E%A5%E5%88%B0imx%20rproc%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.929418%5D%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80ffff80000a264fff%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E5%88%86%E9%A1%B5%E8%AF%B7%E6%B1%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.937347%5DMem%E4%B8%AD%E6%AD%A2%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.940154%5DESR%3D0x0000000096000007%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.943920%5D%20EC%20%3D%200x25%EF%BC%9ADABT%EF%BC%88%E5%BD%93%E5%89%8DEL%EF%BC%89%EF%BC%8CIL%20%3D%2032%E4%BD%8D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.947769%5Dmmc1%3A30b50000.mmc%5B30b50000.mmc%5D%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%BF%E7%94%A8ADMA%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.949239%5D%E8%AE%BE%E7%BD%AE%3D%200%EF%BC%8CFnV%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.959338%5DEA%20%3D%200%EF%BC%8CS1PTW%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.962476%5DFSC%3D0x07%3A3%E7%BA%A7%E7%BF%BB%E8%AF%91%E6%95%85%E9%9A%9C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.967354%5D%E6%95%B0%E6%8D%AE%E4%B8%AD%E6%AD%A2%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.970230%5DISV%EF%BC%9D0%EF%BC%8C%E5%9B%BD%E9%99%85%E7%A9%BA%E9%97%B4%E7%AB%99%EF%BC%9D0x00000007%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.974066%5D%E5%8E%98%E7%B1%B3%EF%BC%9D0%EF%BC%8CWNR%EF%BC%9D0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.977035%5D%E4%BA%A4%E6%8D%A2%E5%99%A8pgtable%3A4k%E9%A1%B5%EF%BC%8C48%E4%BD%8DVA%EF%BC%8Cpgdp%3D0000000041d89000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.983737%5D%5Bffff80000a264fff%5Dpgd%3D1000000074eee003%EF%BC%8Cp4d%3D1000000074eee003%EF%BC%8Cpud%3D1000000074eed003%EF%BC%8Cpmd%3D10000000444ef003%EF%BC%8Cpte%3D000000000000000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B2.996274%5D%20%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E5%93%8E%E5%91%80%EF%BC%9A0000000096000007%20%5B%231%5D%20PREEMPT%20SMP%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.002539%5D%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.005592%5D%20CPU%EF%BC%9A2%20PID%EF%BC%9A8%20%E9%80%9A%E4%BF%A1%EF%BC%9Akworker%2Fu8%EF%BC%9A0%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%206.1.55%2Bg97604c995a86%20%231%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.012986%5D%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AAESYS%202319A%EF%BC%88DT%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.016976%5Dmmc1%3A%E4%B8%BB%E6%9C%BA%E4%B8%8D%E6%94%AF%E6%8C%81%E8%AF%BB%E5%8F%96%E5%8F%AA%E8%AF%BB%E5%BC%80%E5%85%B3%EF%BC%8C%E5%81%87%E8%AE%BE%E5%86%99%E5%90%AF%E7%94%A8%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.017166%5D%E5%B7%A5%E4%BD%9C%E9%98%9F%E5%88%97%EF%BC%9A%E4%BA%8B%E4%BB%B6_%E6%9C%AA%E7%BB%91%E5%AE%9A%E7%9A%84%E5%BB%B6%E8%BF%9F_%E6%8E%A2%E6%B5%8B_%E5%B7%A5%E4%BD%9C_%E5%87%BD%E6%95%B0%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.030991%5Dpstate%EF%BC%9A00000005%EF%BC%88nzcv%20daif-PAN-UAO-TCO-DIT-SSBS%20BTYPE%3D--%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.037950%5Dpc%3Arproc_handle_resources.constprop.0%2B0x8c%2F0x164%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.043786%5Dlr%3Arproc_boot%2B0x304%2F0x580%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.047621%5Dsp%EF%BC%9Affff800009fab9f0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.050931%5Dx29%EF%BC%9Affff800009fab9f0%20x28%EF%BC%9Affff000024d53a98%20x27%EF%BC%9Affff8000098bb780%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.050978%5Dmmc1%3A%E5%9C%B0%E5%9D%800001%E7%9A%84%E6%96%B0%E5%9E%8B%E8%B6%85%E9%AB%98%E9%80%9FSDR104%20SDHC%E5%8D%A1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.058068%5Dx26%3A000000000000006%20x25%3Affffffffffffffff%20x24%3Affff80000a265000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.058074%5Dx23%3Affff000004a1c038%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.065096%5Dmmcblk1%EF%BC%9Ammc1%EF%BC%9A0001%20SD32G%2028.9%20GiB%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.071809%5Dx22%3A000000000000000%20x21%3Affff800009e1a2f0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.071814%5Dx20%3Affff000004a1c000%20x19%3A0000000000000000%20x18%3A0000000000000006%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.071820%5Dx17%3A000000040044ffff%20x16%3Affff000024cfc7e0%20x15%3Affffffffffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.071827%5Dx14%3Afff7ffffffffffff%20x13%3Affffffffffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.076558%5Dmmcblk1%3Ap1%20p2%20p3%20p4%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.079574%5Dx12%3Afff7ffffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.079577%5Dx11%EF%BC%9Affffffffffffffffx10%EF%BC%9Affffffffffffffffx9%EF%BC%9Affffffffffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.079584%5Dx8%EF%BC%9Affffffffffffffffx7%EF%BC%9Affffffffffffffffx6%EF%BC%9Affffffffffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.125331%5Dx5%3Affff000004b33000%20x4%3Affff80000a265400%20x3%3A00000000000003fd%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.132466%5Dx2%3A00000000ffffffff%20x1%3Affff80000a265003%20x0%3Affff80000a265000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.139602%5D%E5%91%BC%E5%8F%AB%E8%B7%9F%E8%B8%AA%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.142045%5Drproc_handle_resources.constprop.0%2B0x8c%2F0x164%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.147532%5Drproc_boot%2B0x304%2F0x580%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.151019%5Drproc_add%2B0xd0%2F0x170%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.154332%5Dimx_rproc_%E6%8E%A2%E9%92%88%2B0x464%2F0x5b0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.158254%5D%E5%B9%B3%E5%8F%B0%E6%8E%A2%E6%B5%8B%2B0x68%2F0xc0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.161915%5D%E7%9C%9F%E6%AD%A3%E6%8E%A2%E6%B5%8B%2B0xbc%2F0x2dc%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.165490%5D__driver_probe_device%2B0x78%2F0x114%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.169847%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E8%AE%BE%E5%A4%87%2B0xd8%2F0x15c%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.174030%5D%20__%E8%AE%BE%E5%A4%87%E8%BF%9E%E6%8E%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2B0xb8%2F0x134%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.178473%5D%E6%AF%8F%E4%B8%AA_drv%E7%9A%84%E6%80%BB%E7%BA%BF%2B0x80%2F0xdc%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.182308%5D__%E8%AE%BE%E5%A4%87_%E8%BF%9E%E6%8E%A5%2B0xa0%2F0x1a0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.186144%5D%E8%AE%BE%E5%A4%87%E5%88%9D%E5%A7%8B%E6%8E%A2%E6%B5%8B%2B0x14%2F0x20%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.190327%5D%E6%80%BB%E7%BA%BF%E6%8E%A2%E6%B5%8B%E8%AE%BE%E5%A4%87%2B0x98%2F0xa0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.194162%5D%E5%BB%B6%E8%BF%9F%E6%8E%A2%E6%B5%8B%E5%B7%A5%E4%BD%9C%E5%87%BD%E6%95%B0%2B0x80%2F0xc0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.198693%5D%E8%BF%9B%E7%A8%8B_one_%E5%B7%A5%E4%BD%9C%2B0x1d4%2F0x330%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.202702%5D%E5%B7%A5%E4%BD%9C%E7%BA%BF%E7%A8%8B%2B0x224%2F0x42c%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.206450%5Dkthread%2B0x108%2F0x10c%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.209676%5D%E4%BB%8E_fork%2B0x10%2F0x20%E8%BF%94%E5%9B%9E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.213253%5D%E4%BB%A3%E7%A0%81%EF%BC%9A128002b3%20913f6021%2097ffb5f6%201400002f%EF%BC%88b8796b00%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B3.219345%5D%20---%5B%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%200000000000000000%5D---%3C%2FFONT%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%AA%E6%98%AF%E6%80%80%E7%96%91%E5%86%85%E5%AD%98%E9%A2%84%E7%95%99%2F%E6%98%A0%E5%B0%84%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98......%E4%BD%86%E4%B8%BA%E4%BB%80%E4%B9%88%E5%8F%AA%E6%9C%89%E5%BD%93%20M7%20%E4%BB%8E%20U-Boot%20%E5%90%AF%E5%8A%A8%E6%97%B6%E6%89%8D%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%8C%E8%80%8C%E5%BD%93%20M7%20%E4%BB%8E%20remoteproc%20%E5%90%AF%E5%8A%A8%E6%97%B6%E5%88%99%E4%B8%8D%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELinux%20DTS%20%E7%9A%84%E7%9B%B8%E5%85%B3%E9%83%A8%E5%88%86%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26amp%3Bresmem%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Em7_reserved%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Em7%4075000000%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%B3%A8%E5%86%8C%3D%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x75000000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x1000000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Em7_vdev0vring0%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Evdev0vring0%4074ff8000%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x74ff8000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x8000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Em7_vdev0vring1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Evdev0vring1%4074ff0000%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%B3%A8%E5%86%8C%3D%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x74ff0000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x8000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20m7_vdevbuffer%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Evdevbuffer%4074ef0000%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%E5%85%B1%E4%BA%AB%20DMA%20%E6%B1%A0%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%B3%A8%E5%86%8C%3D%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x74ef0000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x100000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20m7_rsc_table%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Ersc-table%4074eef000%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x74eef000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x1000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Em7_itcm%3C%2FSPAN%3E%20%3CSPAN%3E%3A%20m7-itcm%40%3C%2FSPAN%3E%20%3CSPAN%3E0x7e0000%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x7e0000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x20000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20m7_dtcm%3C%2FSPAN%3E%3CSPAN%3E%3A%20m7-dtcm%40%3C%2FSPAN%3E%3CSPAN%3E0x800000%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%B3%A8%E5%86%8C%3D%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x800000%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E0x20000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no-map%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20imx8mp-cm7%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9Cfsl%EF%BC%8Cimx8mp-cm7%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rsc-da%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0x74ff8000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%97%B6%E9%92%9F%3D%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bclk%3C%2FSPAN%3E%20%3CSPAN%3EIMX8MP_CLK_M7_DIV%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E6%97%B6%E9%92%9F%E5%90%8D%E7%A7%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%E6%A0%B8%E5%BF%83%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Embox%20%E5%90%8D%E7%A7%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9Ctx%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9Crx%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9Crxdb%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mboxes%20%3D%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%CE%BC%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%CE%BC%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%CE%BC%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%20%3D%20%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_vdevbuffer%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%E3%80%81%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_vdev0vring0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%E3%80%81%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_vdev0vring1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%E3%80%81%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_rsc_table%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%E3%80%81%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_itcm%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%E3%80%81%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bm7_dtcm%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9Fms%3D%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fsl%2Cauto-boot%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%2F*%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E*%20%E6%B3%A8%E6%84%8F%EF%BC%9AM7%20%E5%8F%AF%E8%83%BD%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%20IP%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E*%20UART4%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26amp%3Buart4%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%9C%E5%B7%B2%E7%A6%81%E7%94%A8%E2%80%9D%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%2B%E9%97%AE%E5%80%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1866084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8mp%EF%BC%9A%E5%BD%93%20M7%20%E6%A0%B8%E5%BF%83%E5%B7%B2%E7%94%B1%20U-Boot%20%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8CLinux%20%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Harvey021%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8F%AF%E8%A1%8C%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E4%BA%8B%E5%AE%9E%E8%AF%81%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Evdev0vring0%20%E5%92%8C%20vdev0vring1%20%E8%A2%AB%E4%BA%A4%E6%8D%A2%EF%BC%9B%3C%2FLI%3E%3CLI%3Ersc-da%20%E5%BF%85%E9%A1%BB%E6%8C%87%E5%90%91%20vdev0ring0%20%E7%9A%84%E5%9F%BA%E5%9D%80%EF%BC%9B%3C%2FLI%3E%3CLI%3E%E6%88%91%E5%BF%85%E9%A1%BB%E4%BF%AE%E6%94%B9%20M7%20%E7%9A%84%20hello%20world%20%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%E5%AE%83%E5%9C%A8%20m7_rsc_table%20%E6%8C%87%E5%90%91%E7%9A%84%E5%86%85%E5%AD%98%E4%BD%8D%E7%BD%AE%E5%85%AC%E5%BC%80%E4%B8%80%E4%B8%AA%E8%B5%84%E6%BA%90%E8%A1%A8%EF%BC%88%E6%89%80%E4%BB%A5%E5%9F%BA%E6%9C%AC%E4%B8%8A%E6%88%91%E6%9B%BF%E6%8D%A2%E4%BA%86%20empty_rsc_table.c%EF%BC%88%E5%92%8C%E7%9B%B8%E5%BA%94%E7%9A%84%E6%A0%87%E9%A2%98%EF%BC%89%E4%BB%A5%E5%8F%8A%E9%99%84%E5%8A%A0%E7%9A%84%20rsc_table.c%EF%BC%88%E5%92%8C%E7%9B%B8%E5%BA%94%E7%9A%84%E6%A0%87%E9%A2%98%EF%BC%89%E5%B9%B6%E4%B8%94%E6%88%91%E8%BF%98%E4%BF%AE%E6%94%B9%E4%BA%86%20board.h%EF%BC%88%E8%A7%81%E9%99%84%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1867942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8mp%EF%BC%9A%E5%BD%93%20M7%20%E6%A0%B8%E5%BF%83%E5%B7%B2%E7%94%B1%20U-Boot%20%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8CLinux%20%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1867942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%3CSPAN%20class%3D%22fontstyle0%22%3E%E8%BF%90%E8%A1%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22fontstyle2%22%3E%23mw%200x550ff000%200%204%EF%BC%8C%3C%2FSPAN%3E%E5%9C%A8%E8%BF%90%E8%A1%8Cbootaux%E4%B9%8B%E5%89%8D%3CSPAN%20class%3D%22fontstyle0%22%3E%E6%B8%85%E9%99%A4%E5%9E%83%E5%9C%BE%E8%B5%84%E6%BA%90%E8%A1%A8%E5%8C%BA%E5%9F%9F%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E
