Hello
FlexCAN does not work on NAND binary. (But, goot work on SDCARD binary)
Please see the attached booting log.
'imx6dl-sabreauto-gpmi-weim.dts' file is bellow.
| /* * Copyright (C) 2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ #include "imx6dl-sabreauto.dts" &ecspi1 { /* pin conflict with weim */ status = "disabled"; }; &flexcan1 { /* kyb_16 */ status = "okay"; }; &flexcan2 { /* max7310_c on i2c3 is gone */ status = "disabled"; }; &gpmi { status = "okay"; }; &i2c3 { /* pin conflict with weim */ status = "disabled"; }; &uart3 { /* pin conflict with gpmi and weim */ status = "disabled"; }; &usbh1 { /* max7310_b on i2c3 is gone */ status = "disabled"; }; &usbotg { dr_mode = "peripheral"; status = "disabled"; // _16 }; &weim { pinctrl-assert-gpios = <&gpio5 4 GPIO_ACTIVE_LOW>; status = "okay"; // _16 }; |
Original Attachment has been moved to: 1.booting-log.txt.zip
Original Attachment has been moved to: imx6qdl-sabreauto.dtsi.zip
Original Attachment has been moved to: imx6dl-sabreauto.dts.zip
Original Attachment has been moved to: imx6qdl.dtsi.zip
Solved! Go to Solution.
 igorpadykov
			igorpadykov
		Hi yunbaekim
from log seems flexcan driver is registered ok, no errors.
Could you elaborate how it does not work on NAND, any
errors messages, dmesg output ?
Also had you tried with latest L4.1.15 BSP :
Board Support Packages (35)
L4.1.15_1.0.0_MX6QDLSOLO (REV L4.1.15_1.0.0)
 igorpadykov
			igorpadykov
		Hi yunbaekim
