imx-mkimage: imx8mp: allow to override the BL32 base address
1,158 次查看
Fathi_Boudra
I've opened a pull request to fix imx-mkimage: https://github.com/nxp-imx/imx-mkimage/pull/3
Similarly to the imx8mm platform, allow to override the tee load address (BL32). It allows to use imx-mkimage for other i.MX8M Plus based boards. For instance, the hardcoded value doesn't work out for Toradex imx8mp-verdin SoM which comes in 1, 2, 4 and 8 GiB versions.
Can you take the patch into consideration?
Thanks.
1,067 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You've received the mailing list in the support ticket,
1,127 次查看
Fathi_Boudra
In addition to the github project pull request, the post on i.MX forums, I've now created a support ticket.
1,068 次查看
JosephAtNXP
