I've opened a pull request to fix imx-mkimage: https://github.com/nxp-imx/imx-mkimage/pull/3
Similarly to the imx8mm platform, allow to override the tee load address (BL32). It allows to use imx-mkimage for other i.MX8M Plus based boards. For instance, the hardcoded value doesn't work out for Toradex imx8mp-verdin SoM which comes in 1, 2, 4 and 8 GiB versions.
Can you take the patch into consideration?
Thanks.
Solved! Go to Solution.
Thank you for your interest in NXP Semiconductor products,
You've received the mailing list in the support ticket,
