imx-mkimage: imx8mp: allow to override the BL32 base address
Fathi_Boudra
I've opened a pull request to fix imx-mkimage: https://github.com/nxp-imx/imx-mkimage/pull/3
Similarly to the imx8mm platform, allow to override the tee load address (BL32). It allows to use imx-mkimage for other i.MX8M Plus based boards. For instance, the hardcoded value doesn't work out for Toradex imx8mp-verdin SoM which comes in 1, 2, 4 and 8 GiB versions.
Can you take the patch into consideration?
Thanks.
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You've received the mailing list in the support ticket,
Fathi_Boudra
In addition to the github project pull request, the post on i.MX forums, I've now created a support ticket.
JosephAtNXP
