iMX8qxpc0mek Android15 Automotive facing issue while flashing
Ram2
Hi NXP Team,
We are trying to use Android15 Automotive bring up in iMX8qxpC0mek
Since its custom board , not an EVK
================ Boot logs============
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 02 2026 - 12:31:04 +0530)
Normal Boot
Trying to boot from MMC1
MMC: block number 0x4000 exceeds max(0x2000)
Failed to read rpmbkeyblob.Authentication key not yet programmed
Booting from bootloader_a...
UU
boot args 0x*** 0x*** 0x*** 0x0
SCFW: 00000***
SECO-FW: 00000***
initializing trusty (Project: imx8qxp, Build: [email protected], Built: 13:48:55 Aug 12 2025)
hwsecure: 22: hwsecure init.
INFO: trusty/user/app/secretkeeper/lib.rs:258 Secretkeeper TA startup, on: 'com.android.trusty.secretkeeper.authgraph', 'com.android.trusty.secretkeeper', 'com.android.trusty.secretkeeper.bootloader'
Core: 248 devices, 27 uclasses, devicetree: separate
Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07!
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
[*]-Video Link 0dc0_power_domain [32] not owned by curr partition
sc_pm_set_resource_power_mode: resource:32 mode:3: res:4
Error: dc0_power_domain Power up failed! (error = -13)
probe video device failed, ret -5
[0] dpu@56180000, video
[1] lvds-channel@0, display
[2] panel, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW 654907b6, SECO-FW c9de51c0, IMX-MKIMAGE 4c2e5b25, ATF automot
- U-Boot 2025.04-g1fb4ea4fd9e4-dirty
flash target is MMC:0
Net: No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
INFO Initializing Trusty IPC device
INFO Initializing Trusty Hardware Crypto client
INFO Initializing RPMB storage proxy service
rpmb_proxy.c:279: ERROR proxy_handle_rpmb: rpmb_storage_send failed: 7
failed to read rpmb write counter
ss: init_rpmb_fs: bad static rpmb size, 2048
ss: storage_service_init: block_device_tipc_init failed (-1)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
Verifying slot _a ...
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:902: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
verify FAIL, state: UNLOCK
boot 'boot_a' still
Kernel load addr 0x80280000 size 38883 KiB
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
keymaster.c:684: ERROR Keymaster TIPC client not initialized!
boota: set boot patch level failed.
secretkeeper.c:58: ERROR send_header_only_request: SecretKeeper client not initialized
secretkeeper.c:121: ERROR In secretkeeper_get_identity: failed (-1) to send request to Secretkeeper.
secretkeeper.c:150: ERROR Failed to get secretkeeper key (err = -1)!
kernel @ 80280000 (40566784)
ramdisk @ fc000000 (23203478)
fdt @ 82ab0400 (145053)
Moving Image from 0x80280000 to 0x80400000, end=0x82ab0000
## Flattened Device Tree blob at 82ab0400
Booting using the fdt blob at 0x82ab0400
Working FDT set to 82ab0400
Using Device Tree in place at 0000000082ab0400, end 0000000082ad6a9c
/bus@59000000/dma-controller@591f0000, 41740
/bus@59000000/dma-controller@599f0000, 42872
/bus@5a000000/dma-controller@5a1f0000, 62280
/bus@5a000000/dma-controller@5a9f0000, 62784
Starting kernel ...
Ram2
Hi @Zhiming_Liu
We didnt finish the DDR calibration , Can you please help with steps for DDR calibration
Is there any generic steps or tool is required
Zhiming_Liu
Hi @Ram2
Please refer this knowledge base. Need to get new timing.c from tool and then replace it in uboot.
i.MX 8/8X Family DDR Tools Release
Zhiming
Zhiming_Liu
Hi @Ram2
If you are using custom board, did you modify the source code referring the difference?
Here is bootlog on MEK board with flash command: .\uuu_imx_android_flash.bat -f imx8qxp -e -u c0
U-Boot SPL 2025.04-g6bf602d3b5ab (Sep 16 2025 - 19:00:07 +0200)
Normal Boot
Magic is incorrect.
Error validating A/B metadata from disk.
Resetting and writing new A/B metadata to disk.
UU
SCFW: 00000***
SECO-FW: 00000***
Core:  262 devices, 31 uclasses, devicetree: separate
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - U-Boot 2025.04-g6bf602d3b5ab
Net:   eth0: ethernet@5b040000 [PRIME]Could not get PHY for FEC1: addr 1
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
ramdisk  @ fc000000 (23201967)
fdt      @ 82ab0400 (129950)
   Using Device Tree in place at 0000000082ab0400, end 0000000082ad2f9d
/bus@59000000/dma-controller@591f0000, 36432
/bus@59000000/dma-controller@599f0000, 37564
/bus@5a000000/dma-controller@5a1f0000, 54600
/bus@5a000000/dma-controller@5a9f0000, 55104
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd042]
[    0.000000][    T0] Linux version 6.12.23-android16-5-maybe-dirty-4k (kleaf@build-host) (Android (12833971, +pgo, +bolt, +lto, +mlgo, based on r536225) clang version 19.0.1 (https://android.googlesource.com/toolchain/llvm-project b3a530ec6537146650e42be89f1089e9a3588460), LLD 19.0.1) #1 SMP PREEMPT Thu Jan  1 00:00:00 UTC 1970
[    0.000000][    T0] KASLR enabled
[    0.000000][    T0] Machine model: Freescale i.MX8QXP MEK
[    0.000000][    T0] Malformed early option 'earlycon'
[    0.000000][    T0] Enabling dynamic shadow call stack
[    0.000000][    T0] efi: UEFI not found.
Zhiming
Ram2
Facing above issue while flashing , can help what could be the issue
Ram2
Hi @Zhiming_Liu
We are using same flashing command
sudo ./uuu_imx_android_flash.sh -f imx8qxp -a -u c0 -e -c0
Still I see below error
hwcrypto.c:94: ERROR hwcrypto_do_tipc: HWCRYPTO TIPC client not initialized
ramdisk @ fc000000 (23203479)
Starting kernel ...
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 03 2026 - 12:58:24 +0530)
Normal Boot
Load or verify bootloader_b fail, setting unbootable..
No bootable slots found, try to boot into recovery mode...
Error: -38
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
We have done pin muxing changes w.r.t to custom board
Zhiming_Liu
Hi @Ram2
Did you finish the DDR calibration?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20Team%2C%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20are%20trying%20to%20use%20Android15%20Automotive%20bring%20up%20in%20iMX8qxpC0mek%26nbsp%3B%3C%2FP%3E%3CP%3ESince%20its%20custom%20board%20%2C%20not%20an%20EVK%3CBR%20%2F%3E%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20Boot%20logs%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EU-Boot%20SPL%202025.04-g1fb4ea4fd9e4-dirty%20(Jan%2002%202026%20-%2012%3A31%3A04%20%2B0530)%3CBR%20%2F%3ENormal%20Boot%3CBR%20%2F%3ETrying%20to%20boot%20from%20MMC1%3CBR%20%2F%3EMMC%3A%20block%20number%200x4000%20exceeds%20max(0x2000)%3CBR%20%2F%3EFailed%20to%20read%20rpmbkeyblob.Authentication%20key%20not%20yet%20programmed%3CBR%20%2F%3EBooting%20from%20bootloader_a...%3CBR%20%2F%3EUU%3CBR%20%2F%3Eboot%20args%200x***%200x***%200x***%200x0%3CBR%20%2F%3ESCFW%3A%2000000***%3CBR%20%2F%3ESECO-FW%3A%2000000***%3CBR%20%2F%3Einitializing%20trusty%20(Project%3A%20imx8qxp%2C%20Build%3A%20nxa16252%40lsv05559.swis.nl-cdc01.nxp.com-1%2C%20Built%3A%2013%3A48%3A55%20Aug%2012%202025)%3CBR%20%2F%3Ehwsecure%3A%2022%3A%20hwsecure%20init.%3CBR%20%2F%3EINFO%3A%20trusty%2Fuser%2Fapp%2Fsecretkeeper%2Flib.rs%3A258%20Secretkeeper%20TA%20startup%2C%20on%3A%20'com.android.trusty.secretkeeper.authgraph'%2C%20'com.android.trusty.secretkeeper'%2C%20'com.android.trusty.secretkeeper.bootloader'%3CBR%20%2F%3ECore%3A%20248%20devices%2C%2027%20uclasses%2C%20devicetree%3A%20separate%3CBR%20%2F%3EWarning%3A%20Device%20tree%20includes%20old%20'u-boot%2Cdm-'%20tags%3A%20please%20fix%20by%202023.07!%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%3CBR%20%2F%3ELoading%20Environment%20from%20MMC...%20Reading%20from%20MMC(0)...%20***%20Warning%20-%20bad%20CRC%2C%20using%20default%20environment%3C%2FP%3E%3CP%3E%5B*%5D-Video%20Link%200dc0_power_domain%20%5B32%5D%20not%20owned%20by%20curr%20partition%3CBR%20%2F%3Esc_pm_set_resource_power_mode%3A%20resource%3A32%20mode%3A3%3A%20res%3A4%3CBR%20%2F%3EError%3A%20dc0_power_domain%20Power%20up%20failed!%20(error%20%3D%20-13)%3CBR%20%2F%3Eprobe%20video%20device%20failed%2C%20ret%20-5%3C%2FP%3E%3CP%3E%5B0%5D%20dpu%4056180000%2C%20video%3CBR%20%2F%3E%5B1%5D%20lvds-channel%400%2C%20display%3CBR%20%2F%3E%5B2%5D%20panel%2C%20panel%3CBR%20%2F%3EIn%3A%20serial%3CBR%20%2F%3EOut%3A%20serial%3CBR%20%2F%3EErr%3A%20serial%3C%2FP%3E%3CP%3EBuildInfo%3A%3CBR%20%2F%3E-%20SCFW%20654907b6%2C%20SECO-FW%20c9de51c0%2C%20IMX-MKIMAGE%204c2e5b25%2C%20ATF%20automot%3CBR%20%2F%3E-%20U-Boot%202025.04-g1fb4ea4fd9e4-dirty%3C%2FP%3E%3CP%3Eflash%20target%20is%20MMC%3A0%3CBR%20%2F%3ENet%3A%20No%20ethernet%20found.%3CBR%20%2F%3EINFO%20Initializing%20Trusty%20device%3CBR%20%2F%3EINFO%20selected%20trusty%20api%20version%3A%203%20(requested%203)%3CBR%20%2F%3EINFO%20Initializing%20Trusty%20IPC%20device%3CBR%20%2F%3EINFO%20Initializing%20Trusty%20Hardware%20Crypto%20client%3CBR%20%2F%3EINFO%20Initializing%20RPMB%20storage%20proxy%20service%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%20ERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%20ERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%20ERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3Efailed%20to%20read%20rpmb%20write%20counter%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%20ERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3Ess%3A%20init_rpmb_fs%3A%20bad%20static%20rpmb%20size%2C%202048%3CBR%20%2F%3Ess%3A%20storage_service_init%3A%20block_device_tipc_init%20failed%20(-1)%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3EFastboot%3A%20Normal%3CBR%20%2F%3ENormal%20Boot%3CBR%20%2F%3EHit%20any%20key%20to%20stop%20autoboot%3A%200%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3EVerifying%20slot%20_a%20...%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Efsl_validate_vbmeta_public_key_rpmb%3A%20Read%20public%20key%20error%3CBR%20%2F%3Eavb_slot_verify.c%3A902%3A%20ERROR%3A%20vbmeta_a%3A%20Public%20key%20used%20to%20sign%20data%20rejected.%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Everify%20FAIL%2C%20state%3A%20UNLOCK%3CBR%20%2F%3Eboot%20'boot_a'%20still%3CBR%20%2F%3EKernel%20load%20addr%200x80280000%20size%2038883%20KiB%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3EERROR%20-%20failed%20to%20read%20public%20key%20for%20keymaster%3CBR%20%2F%3Ekeymaster.c%3A318%3A%20ERROR%20Keymaster%20TIPC%20client%20not%20initialized!%3CBR%20%2F%3Ekeymaster.c%3A684%3A%20ERROR%20Keymaster%20TIPC%20client%20not%20initialized!%3CBR%20%2F%3Eboota%3A%20set%20boot%20patch%20level%20failed.%3CBR%20%2F%3Eavb.c%3A86%3A%20ERROR%20avb_do_tipc%3A%20AVB%20TIPC%20client%20not%20initialized%3CBR%20%2F%3Esecretkeeper.c%3A58%3A%20ERROR%20send_header_only_request%3A%20SecretKeeper%20client%20not%20initialized%3CBR%20%2F%3Esecretkeeper.c%3A121%3A%20ERROR%20In%20secretkeeper_get_identity%3A%20failed%20(-1)%20to%20send%20request%20to%20Secretkeeper.%3CBR%20%2F%3Esecretkeeper.c%3A150%3A%20ERROR%20Failed%20to%20get%20secretkeeper%20key%20(err%20%3D%20-1)!%3CBR%20%2F%3Ekernel%20%40%2080280000%20(40566784)%3CBR%20%2F%3Eramdisk%20%40%20fc000000%20(23203478)%3CBR%20%2F%3Efdt%20%40%2082ab0400%20(145053)%3CBR%20%2F%3EMoving%20Image%20from%200x80280000%20to%200x80400000%2C%20end%3D0x82ab0000%3CBR%20%2F%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2082ab0400%3CBR%20%2F%3EBooting%20using%20the%20fdt%20blob%20at%200x82ab0400%3CBR%20%2F%3EWorking%20FDT%20set%20to%2082ab0400%3CBR%20%2F%3EUsing%20Device%20Tree%20in%20place%20at%200000000082ab0400%2C%20end%200000000082ad6a9c%3CBR%20%2F%3EWorking%20FDT%20set%20to%2082ab0400%3CBR%20%2F%3E%2Fbus%4059000000%2Fdma-controller%40591f0000%2C%2041740%3CBR%20%2F%3E%2Fbus%4059000000%2Fdma-controller%40599f0000%2C%2042872%3CBR%20%2F%3E%2Fbus%405a000000%2Fdma-controller%405a1f0000%2C%2062280%3CBR%20%2F%3E%2Fbus%405a000000%2Fdma-controller%405a1f0000%2C%2062280%3CBR%20%2F%3E%2Fbus%405a000000%2Fdma-controller%405a9f0000%2C%2062784%3CBR%20%2F%3Edc0_power_domain%20%5B32%5D%20not%20owned%20by%20curr%20partition%3CBR%20%2F%3Esc_pm_set_resource_power_mode%3A%20resource%3A32%20mode%3A3%3A%20res%3A4%3CBR%20%2F%3EError%3A%20dc0_power_domain%20Power%20up%20failed!%20(error%20%3D%20-13)%3CBR%20%2F%3Eprobe%20video%20device%20failed%2C%20ret%20-5%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFacing%20above%20issue%20while%20flashing%20%2C%20can%20help%20what%20could%20be%20the%20issue%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20didnt%20finish%20the%20DDR%20calibration%20%2C%20Can%20you%20please%20help%20with%20steps%20for%20DDR%20calibration%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20there%20any%20generic%20steps%20or%20tool%20is%20required%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EPlease%20refer%20this%20knowledge%20base.%20Need%20to%20get%20new%20timing.c%20from%20tool%20and%20then%20replace%20it%20in%20uboot.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-8-8X-Family-DDR-Tools-Release%2Fta-p%2F1121519%22%20target%3D%22_blank%22%3Ei.MX%208%2F8X%20Family%20DDR%20Tools%20Release%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EDid%20you%20finish%20the%20DDR%26nbsp%3Bcalibration%3F%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E
