iMX8qxpc0mek Android15 Automotive facing issue while flashing
2,435件の閲覧回数
Ram2
Hi NXP Team,
We are trying to use Android15 Automotive bring up in iMX8qxpC0mek
Since its custom board , not an EVK
================ Boot logs============
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 02 2026 - 12:31:04 +0530)
Normal Boot
Trying to boot from MMC1
MMC: block number 0x4000 exceeds max(0x2000)
Failed to read rpmbkeyblob.Authentication key not yet programmed
Booting from bootloader_a...
UU
boot args 0x*** 0x*** 0x*** 0x0
SCFW: 00000***
SECO-FW: 00000***
initializing trusty (Project: imx8qxp, Build: [email protected], Built: 13:48:55 Aug 12 2025)
hwsecure: 22: hwsecure init.
INFO: trusty/user/app/secretkeeper/lib.rs:258 Secretkeeper TA startup, on: 'com.android.trusty.secretkeeper.authgraph', 'com.android.trusty.secretkeeper', 'com.android.trusty.secretkeeper.bootloader'
Core: 248 devices, 27 uclasses, devicetree: separate
Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07!
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
[*]-Video Link 0dc0_power_domain [32] not owned by curr partition
sc_pm_set_resource_power_mode: resource:32 mode:3: res:4
Error: dc0_power_domain Power up failed! (error = -13)
probe video device failed, ret -5
[0] dpu@56180000, video
[1] lvds-channel@0, display
[2] panel, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW 654907b6, SECO-FW c9de51c0, IMX-MKIMAGE 4c2e5b25, ATF automot
- U-Boot 2025.04-g1fb4ea4fd9e4-dirty
flash target is MMC:0
Net: No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
INFO Initializing Trusty IPC device
INFO Initializing Trusty Hardware Crypto client
INFO Initializing RPMB storage proxy service
rpmb_proxy.c:279: ERROR proxy_handle_rpmb: rpmb_storage_send failed: 7
failed to read rpmb write counter
ss: init_rpmb_fs: bad static rpmb size, 2048
ss: storage_service_init: block_device_tipc_init failed (-1)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
Verifying slot _a ...
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:902: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
verify FAIL, state: UNLOCK
boot 'boot_a' still
Kernel load addr 0x80280000 size 38883 KiB
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
keymaster.c:684: ERROR Keymaster TIPC client not initialized!
boota: set boot patch level failed.
secretkeeper.c:58: ERROR send_header_only_request: SecretKeeper client not initialized
secretkeeper.c:121: ERROR In secretkeeper_get_identity: failed (-1) to send request to Secretkeeper.
secretkeeper.c:150: ERROR Failed to get secretkeeper key (err = -1)!
kernel @ 80280000 (40566784)
ramdisk @ fc000000 (23203478)
fdt @ 82ab0400 (145053)
Moving Image from 0x80280000 to 0x80400000, end=0x82ab0000
## Flattened Device Tree blob at 82ab0400
Booting using the fdt blob at 0x82ab0400
Working FDT set to 82ab0400
Using Device Tree in place at 0000000082ab0400, end 0000000082ad6a9c
/bus@59000000/dma-controller@591f0000, 41740
/bus@59000000/dma-controller@599f0000, 42872
/bus@5a000000/dma-controller@5a1f0000, 62280
/bus@5a000000/dma-controller@5a9f0000, 62784
Starting kernel ...
6 返答(返信)
2,223件の閲覧回数
Ram2
Hi @Zhiming_Liu
We didnt finish the DDR calibration , Can you please help with steps for DDR calibration
Is there any generic steps or tool is required
2,220件の閲覧回数
Zhiming_Liu
Hi @Ram2
Please refer this knowledge base. Need to get new timing.c from tool and then replace it in uboot.
i.MX 8/8X Family DDR Tools Release
Zhiming
2,317件の閲覧回数
Zhiming_Liu
Hi @Ram2
If you are using custom board, did you modify the source code referring the difference?
Here is bootlog on MEK board with flash command: .\uuu_imx_android_flash.bat -f imx8qxp -e -u c0
U-Boot SPL 2025.04-g6bf602d3b5ab (Sep 16 2025 - 19:00:07 +0200)
Normal Boot
Magic is incorrect.
Error validating A/B metadata from disk.
Resetting and writing new A/B metadata to disk.
UU
SCFW: 00000***
SECO-FW: 00000***
Core:  262 devices, 31 uclasses, devicetree: separate
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - U-Boot 2025.04-g6bf602d3b5ab
Net:   eth0: ethernet@5b040000 [PRIME]Could not get PHY for FEC1: addr 1
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
ramdisk  @ fc000000 (23201967)
fdt      @ 82ab0400 (129950)
   Using Device Tree in place at 0000000082ab0400, end 0000000082ad2f9d
/bus@59000000/dma-controller@591f0000, 36432
/bus@59000000/dma-controller@599f0000, 37564
/bus@5a000000/dma-controller@5a1f0000, 54600
/bus@5a000000/dma-controller@5a9f0000, 55104
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd042]
[    0.000000][    T0] Linux version 6.12.23-android16-5-maybe-dirty-4k (kleaf@build-host) (Android (12833971, +pgo, +bolt, +lto, +mlgo, based on r536225) clang version 19.0.1 (https://android.googlesource.com/toolchain/llvm-project b3a530ec6537146650e42be89f1089e9a3588460), LLD 19.0.1) #1 SMP PREEMPT Thu Jan  1 00:00:00 UTC 1970
[    0.000000][    T0] KASLR enabled
[    0.000000][    T0] Machine model: Freescale i.MX8QXP MEK
[    0.000000][    T0] Malformed early option 'earlycon'
[    0.000000][    T0] Enabling dynamic shadow call stack
[    0.000000][    T0] efi: UEFI not found.
Zhiming
2,434件の閲覧回数
Ram2
Facing above issue while flashing , can help what could be the issue
2,303件の閲覧回数
Ram2
Hi @Zhiming_Liu
We are using same flashing command
sudo ./uuu_imx_android_flash.sh -f imx8qxp -a -u c0 -e -c0
Still I see below error
hwcrypto.c:94: ERROR hwcrypto_do_tipc: HWCRYPTO TIPC client not initialized
ramdisk @ fc000000 (23203479)
Starting kernel ...
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 03 2026 - 12:58:24 +0530)
Normal Boot
Load or verify bootloader_b fail, setting unbootable..
No bootable slots found, try to boot into recovery mode...
Error: -38
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
We have done pin muxing changes w.r.t to custom board
タグ(1)
2,248件の閲覧回数
Zhiming_Liu
Hi @Ram2
Did you finish the DDR calibration?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8qxpc0mek%20Android15%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%AD%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%83%81%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%3CBR%20%2F%3EiMX8qxpC0mek%E3%81%A7Android15%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFEVK%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AA%E3%81%AE%E3%81%A7%3CBR%20%2F%3E%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EU-Boot%20SPL%202025.04-g1fb4ea4fd9e4-%E3%83%80%E3%83%BC%E3%83%86%E3%82%A3(2026%E5%B9%B41%E6%9C%882%E6%97%A5%20-%2012%3A31%3A04%20%2B0530)%3CBR%20%2F%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3EMMC1%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EMMC%3A%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%200x4000%20%E3%81%8C%E6%9C%80%E5%A4%A7%E5%80%A4%20(0x2000)%20%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Erpmbkeyblob%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%8C%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ebootloader_a%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%81%86%E3%81%86%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E5%BC%95%E6%95%B0%200x***%200x***%200x***%200x0%3CBR%20%2F%3E%20SCFW%3A%2000000***%3CBR%20%2F%3E%20SECO-FW%3A%2000000***%3CBR%20%2F%3E%E4%BF%A1%E9%A0%BC%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3A%20imx8qxp%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%3A%20nxa16252%40lsv05559.swis.nl-cdc01.nxp.com-1%E3%80%81%E4%BD%9C%E6%88%90%E6%97%A5%E6%99%82%3A%202025%E5%B9%B48%E6%9C%8812%E6%97%A5%2013%3A48%3A55%3CBR%20%2F%3E%20hwsecure%3A%2022%3A%20hwsecure%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20trusty%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fapp%2Fsecretkeeper%2Flib.rs%3A258Secretkeeper%20TA%20%E3%81%AE%E8%B5%B7%E5%8B%95%3A%20'com.android.trusty.secretkeeper.authgraph''com.android.trusty.secretkeeper'%2C%E3%80%8Ccom.android.trusty.secretkeeper.bootloader%E3%80%8D%3CBR%20%2F%3E%E3%82%B3%E3%82%A2%3A%20248%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8127uclass%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%3A%20%E5%80%8B%E5%88%A5%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E5%8F%A4%E3%81%84%E3%80%8Cu-boot%E3%80%81dm-%E3%80%8D%E3%82%BF%E3%82%B0%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%822023.07%20%E3%81%BE%E3%81%A7%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20MMC%3A%20FSL_SDHC%3A%200%E3%80%81FSL_SDHC%3A%201%3CBR%20%2F%3E%20MMC%E3%81%8B%E3%82%89%E7%92%B0%E5%A2%83%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD...%20MMC(0)%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%20***%20%E8%AD%A6%E5%91%8A%20-%20CRC%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B*%5D-%E3%83%93%E3%83%87%E3%82%AA%E3%83%AA%E3%83%B3%E3%82%AF%200dc0_power_domain%20%5B32%5D%20%E3%81%AFcurr%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%89%80%E6%9C%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esc_pm_set_resource_power_mode%3A%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A32%20%E3%83%A2%E3%83%BC%E3%83%89%3A3%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A6%3A4%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20dc0_power_domain%20%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E3%82%A8%E3%83%A9%E3%83%BC%20%3D%20-13)%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%BB%E3%82%8A%E5%80%A4%20-5%3C%2FP%3E%3CP%3E%5B0%5D%20dpu%4056180000%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%3CBR%20%2F%3E%5B1%5D%20lvds-channel%400%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3CBR%20%2F%3E%5B2%5D%20%E3%83%91%E3%83%8D%E3%83%AB%E3%80%81%E3%83%91%E3%83%8D%E3%83%AB%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%83%85%E5%A0%B1%3A%3CBR%20%2F%3E%20-%20SCFW%20654907b6%E3%80%81SECO-FW%20c9de51c0%E3%80%81IMX-MKIMAGE%204c2e5b25%E3%80%81ATF%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%88%3CBR%20%2F%3E-%20U-Boot%202025.04-g1fb4ea4fd9e4-%E3%83%80%E3%83%BC%E3%83%86%E3%82%A3%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AFMMC%3A0%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%20Trusty%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E4%BF%A1%E9%A0%BC%E3%81%A7%E3%81%8D%E3%82%8B%20API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%203%20(%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%9F%203)%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%20Trusty%20IPC%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%20Trusty%20Hardware%20Crypto%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EINFO%20RPMB%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%20%E3%83%97%E3%83%AD%E3%82%AD%E3%82%B7%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%E3%82%A8%E3%83%A9%E3%83%BC%20proxy_handle_rpmb%3A%20rpmb_storage_send%20%E5%A4%B1%E6%95%97%3A%207%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%E3%82%A8%E3%83%A9%E3%83%BC%20proxy_handle_rpmb%3A%20rpmb_storage_send%20%E5%A4%B1%E6%95%97%3A%207%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%E3%82%A8%E3%83%A9%E3%83%BC%20proxy_handle_rpmb%3A%20rpmb_storage_send%20%E5%A4%B1%E6%95%97%3A%207%3CBR%20%2F%3E%20rpmb%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Erpmb_proxy.c%3A279%3A%E3%82%A8%E3%83%A9%E3%83%BC%20proxy_handle_rpmb%3A%20rpmb_storage_send%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%207%3CBR%20%2F%3E%20ss%3A%20init_rpmb_fs%3A%20%E4%B8%8D%E6%AD%A3%E3%81%AA%E9%9D%99%E7%9A%84%20rpmb%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%812048%3CBR%20%2F%3E%20ss%3A%20storage_service_init%3A%20block_device_tipc_init%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-1)%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%3A%20%E9%80%9A%E5%B8%B8%3CBR%20%2F%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%200%3CBR%20%2F%3E%20avb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88_a%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20avb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Efsl_validate_vbmeta_public_key_rpmb%3A%20%E5%85%AC%E9%96%8B%E9%8D%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3Eavb_slot_verify.c%3A902%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20vbmeta_a%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E7%BD%B2%E5%90%8D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E5%85%AC%E9%96%8B%E3%82%AD%E3%83%BC%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20Trusty%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC!%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20Trusty%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC!%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20Trusty%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC!%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E6%A4%9C%E8%A8%BC%E5%A4%B1%E6%95%97%E3%80%81%E7%8A%B6%E6%85%8B%3A%20UNLOCK%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%20'boot_a'%20%E3%81%AF%E3%81%BE%E3%81%A0%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x80280000%20%E3%82%B5%E3%82%A4%E3%82%BA%2038883%20KiB%3CBR%20%2F%3E%20avb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E3%82%AD%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AE%E5%85%AC%E9%96%8B%E9%8D%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC.c%3A318%3A%E3%82%A8%E3%83%A9%E3%83%BC%20Keymaster%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC.c%3A684%3A%E3%82%A8%E3%83%A9%E3%83%BC%20Keymaster%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3Eboota%3A%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%83%81%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eavb.c%3A86%3A%E3%82%A8%E3%83%A9%E3%83%BC%20avb_do_tipc%3A%20AVB%20TIPC%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%B7%E3%83%BC%E3%82%AF%E3%83%AC%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC.c%3A58%3AERROR%20send_header_only_request%3A%20SecretKeeper%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%B7%E3%83%BC%E3%82%AF%E3%83%AC%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC.c%3A121%3Asecretkeeper_get_identity%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81Secretkeeper%20%E3%81%B8%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-1)%E3%80%82%3CBR%20%2F%3E%E3%82%B7%E3%83%BC%E3%82%AF%E3%83%AC%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC.c%3A150%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Secretkeeper%20%E3%82%AD%E3%83%BC%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(err%20%3D%20-1)%E3%80%82%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%40%2080280000%20(40566784)%3CBR%20%2F%3E%20RAM%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%20%40%20fc000000%20(23203478)%3CBR%20%2F%3E%20fdt%20%40%2082ab0400%20(145053)%3CBR%20%2F%3E%200x80280000%20%E3%81%8B%E3%82%89%200x80400000%20%E3%81%B8%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E7%A7%BB%E5%8B%95%E3%80%81%E7%B5%82%E4%BA%86%3D0x82ab0000%3CBR%20%2F%3E%20%23%23%2082ab0400%20%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20blob%3CBR%20%2F%3E%200x82ab0400%E3%81%AEfdt%20blob%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AEFDT%E3%82%9282ab0400%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E0000000082ab0400%E3%80%81%E7%B5%82%E4%BA%86%200000000082ad6a9c%20%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AEFDT%E3%82%9282ab0400%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%2F%E3%83%90%E3%82%B9%4059000000%2FDMA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%40591f0000%2C%2041740%3CBR%20%2F%3E%20%2F%E3%83%90%E3%82%B9%4059000000%2FDMA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%40599f0000%2C%2042872%3CBR%20%2F%3E%20%2F%E3%83%90%E3%82%B9%405a000000%2FDMA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%405a1f0000%2C%2062280%3CBR%20%2F%3E%20%2F%E3%83%90%E3%82%B9%405a000000%2FDMA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%405a1f0000%2C%2062280%3CBR%20%2F%3E%20%2F%E3%83%90%E3%82%B9%405a000000%2FDMA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%405a9f0000%2C%2062784%3CBR%20%2F%3E%20dc0_power_domain%20%5B32%5D%20%E3%81%AF%20curr%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%89%80%E6%9C%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3CBR%20%2F%3Esc_pm_set_resource_power_mode%3A%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A32%20%E3%83%A2%E3%83%BC%E3%83%89%3A3%3A%20%E8%A7%A3%E5%83%8F%E5%BA%A6%3A4%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20dc0_power_domain%20%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E3%82%A8%E3%83%A9%E3%83%BC%20%3D%20-13)%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%BB%E3%82%8A%E5%80%A4%20-5%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%AD%E3%81%AB%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%3CBR%20%2F%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E3%83%8A%E3%83%AC%E3%83%83%E3%82%B8%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82c%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81uboot%20%E3%81%A7%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-8-8X-Family-DDR-Tools-Release%2Fta-p%2F1121519%22%20target%3D%22_blank%22%3Ei.MX%208%2F8X%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20DDR%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20DDR%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%BE%E3%81%A0%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82DDR%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%84%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20DDR%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
