iMX8qxpc0mek Android15 Automotive facing issue while flashing
2,448 次查看
Ram2
Hi NXP Team,
We are trying to use Android15 Automotive bring up in iMX8qxpC0mek
Since its custom board , not an EVK
================ Boot logs============
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 02 2026 - 12:31:04 +0530)
Normal Boot
Trying to boot from MMC1
MMC: block number 0x4000 exceeds max(0x2000)
Failed to read rpmbkeyblob.Authentication key not yet programmed
Booting from bootloader_a...
UU
boot args 0x*** 0x*** 0x*** 0x0
SCFW: 00000***
SECO-FW: 00000***
initializing trusty (Project: imx8qxp, Build: [email protected], Built: 13:48:55 Aug 12 2025)
hwsecure: 22: hwsecure init.
INFO: trusty/user/app/secretkeeper/lib.rs:258 Secretkeeper TA startup, on: 'com.android.trusty.secretkeeper.authgraph', 'com.android.trusty.secretkeeper', 'com.android.trusty.secretkeeper.bootloader'
Core: 248 devices, 27 uclasses, devicetree: separate
Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07!
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
[*]-Video Link 0dc0_power_domain [32] not owned by curr partition
sc_pm_set_resource_power_mode: resource:32 mode:3: res:4
Error: dc0_power_domain Power up failed! (error = -13)
probe video device failed, ret -5
[0] dpu@56180000, video
[1] lvds-channel@0, display
[2] panel, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW 654907b6, SECO-FW c9de51c0, IMX-MKIMAGE 4c2e5b25, ATF automot
- U-Boot 2025.04-g1fb4ea4fd9e4-dirty
flash target is MMC:0
Net: No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
INFO Initializing Trusty IPC device
INFO Initializing Trusty Hardware Crypto client
INFO Initializing RPMB storage proxy service
rpmb_proxy.c:279: ERROR proxy_handle_rpmb: rpmb_storage_send failed: 7
failed to read rpmb write counter
ss: init_rpmb_fs: bad static rpmb size, 2048
ss: storage_service_init: block_device_tipc_init failed (-1)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
Verifying slot _a ...
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:902: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
verify FAIL, state: UNLOCK
boot 'boot_a' still
Kernel load addr 0x80280000 size 38883 KiB
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
keymaster.c:684: ERROR Keymaster TIPC client not initialized!
boota: set boot patch level failed.
secretkeeper.c:58: ERROR send_header_only_request: SecretKeeper client not initialized
secretkeeper.c:121: ERROR In secretkeeper_get_identity: failed (-1) to send request to Secretkeeper.
secretkeeper.c:150: ERROR Failed to get secretkeeper key (err = -1)!
kernel @ 80280000 (40566784)
ramdisk @ fc000000 (23203478)
fdt @ 82ab0400 (145053)
Moving Image from 0x80280000 to 0x80400000, end=0x82ab0000
## Flattened Device Tree blob at 82ab0400
Booting using the fdt blob at 0x82ab0400
Working FDT set to 82ab0400
Using Device Tree in place at 0000000082ab0400, end 0000000082ad6a9c
/bus@59000000/dma-controller@591f0000, 41740
/bus@59000000/dma-controller@599f0000, 42872
/bus@5a000000/dma-controller@5a1f0000, 62280
/bus@5a000000/dma-controller@5a9f0000, 62784
Starting kernel ...
6 回复数
2,236 次查看
Ram2
Hi @Zhiming_Liu
We didnt finish the DDR calibration , Can you please help with steps for DDR calibration
Is there any generic steps or tool is required
2,233 次查看
Zhiming_Liu
Hi @Ram2
Please refer this knowledge base. Need to get new timing.c from tool and then replace it in uboot.
i.MX 8/8X Family DDR Tools Release
Zhiming
2,330 次查看
Zhiming_Liu
Hi @Ram2
If you are using custom board, did you modify the source code referring the difference?
Here is bootlog on MEK board with flash command: .\uuu_imx_android_flash.bat -f imx8qxp -e -u c0
U-Boot SPL 2025.04-g6bf602d3b5ab (Sep 16 2025 - 19:00:07 +0200)
Normal Boot
Magic is incorrect.
Error validating A/B metadata from disk.
Resetting and writing new A/B metadata to disk.
UU
SCFW: 00000***
SECO-FW: 00000***
Core:  262 devices, 31 uclasses, devicetree: separate
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - U-Boot 2025.04-g6bf602d3b5ab
Net:   eth0: ethernet@5b040000 [PRIME]Could not get PHY for FEC1: addr 1
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
ramdisk  @ fc000000 (23201967)
fdt      @ 82ab0400 (129950)
   Using Device Tree in place at 0000000082ab0400, end 0000000082ad2f9d
/bus@59000000/dma-controller@591f0000, 36432
/bus@59000000/dma-controller@599f0000, 37564
/bus@5a000000/dma-controller@5a1f0000, 54600
/bus@5a000000/dma-controller@5a9f0000, 55104
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd042]
[    0.000000][    T0] Linux version 6.12.23-android16-5-maybe-dirty-4k (kleaf@build-host) (Android (12833971, +pgo, +bolt, +lto, +mlgo, based on r536225) clang version 19.0.1 (https://android.googlesource.com/toolchain/llvm-project b3a530ec6537146650e42be89f1089e9a3588460), LLD 19.0.1) #1 SMP PREEMPT Thu Jan  1 00:00:00 UTC 1970
[    0.000000][    T0] KASLR enabled
[    0.000000][    T0] Machine model: Freescale i.MX8QXP MEK
[    0.000000][    T0] Malformed early option 'earlycon'
[    0.000000][    T0] Enabling dynamic shadow call stack
[    0.000000][    T0] efi: UEFI not found.
Zhiming
2,447 次查看
Ram2
Facing above issue while flashing , can help what could be the issue
2,316 次查看
Ram2
Hi @Zhiming_Liu
We are using same flashing command
sudo ./uuu_imx_android_flash.sh -f imx8qxp -a -u c0 -e -c0
Still I see below error
hwcrypto.c:94: ERROR hwcrypto_do_tipc: HWCRYPTO TIPC client not initialized
ramdisk @ fc000000 (23203479)
Starting kernel ...
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 03 2026 - 12:58:24 +0530)
Normal Boot
Load or verify bootloader_b fail, setting unbootable..
No bootable slots found, try to boot into recovery mode...
Error: -38
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
We have done pin muxing changes w.r.t to custom board
标记 (1)
2,261 次查看
Zhiming_Liu
Hi @Ram2
Did you finish the DDR calibration?
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8qxpc0mek%20Android15%20%E6%B1%BD%E8%BD%A6%E5%9C%A8%E9%97%AA%E5%AD%98%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9B%A2%E9%98%9F%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Android15%20Automotive%20%E5%9C%A8%20iMX8qxpC0mek%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%97%A2%E7%84%B6%E6%98%AF%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%EF%BC%8C%E4%B8%8D%E6%98%AF%20EVK%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EU-Boot%20SPL%202025.04-g1fb4ea4fd9e4-dirty%EF%BC%882026%20%E5%B9%B4%201%20%E6%9C%88%202%20%E6%97%A5-12%3A31%3A04%20%2B0530%EF%BC%89%3CBR%20%2F%3E%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E5%B0%9D%E8%AF%95%E4%BB%8E%20MMC1%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3EMMC%EF%BC%9A%E5%8C%BA%E5%9D%97%E5%8F%B7%200x4000%20%E8%B6%85%E8%BF%87%E6%9C%80%E5%A4%A7%E5%80%BC%20(0x2000)%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20rpmbkeyblob%E3%80%82%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%86%E9%92%A5%E5%B0%9A%E6%9C%AA%E7%BC%96%E7%A8%8B%3CBR%20%2F%3E%E4%BB%8E%20bootloader_a%20%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3EUU%3CBR%20%2F%3Eboot%20args%200x***%200x***%200x***%200x0%3CBR%20%2F%3ESCFW%EF%BC%9A00000***%3CBR%20%2F%3ESECO-FW%EF%BC%9A00000***%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%20trusty%EF%BC%88%E9%A1%B9%E7%9B%AE%EF%BC%9Aimx8qxp%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9Anxa16252%40lsv05559.swis.nl-cdc01.nxp.com-1%EF%BC%8C%E7%89%88%E6%9C%AC%EF%BC%9A13%3A48%3A55%EF%BC%882025%20%E5%B9%B4%208%20%E6%9C%88%2012%20%E6%97%A5%EF%BC%89%3CBR%20%2F%3Ehsecure%EF%BC%9A22%EF%BC%9Ahsecure%20%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3EINFO%3A%20trusty%2Fuser%2Fapp%2Fsecretkeeper%2Flib.rs%3A258Secretkeeper%20TA%20startup%2C%20on%EF%BC%9Acom.android.trusty.secretkeeper.authgraph%22%E3%80%81com.android.trusty.secretkeeper%22%E3%80%81com.android.trusty.secretkeeper.bootloader%3CBR%20%2F%3E%E9%85%B7%E7%9D%BF%EF%BC%9A248%20%E5%8F%B0%E8%AE%BE%E5%A4%87%E3%80%8127%20%E4%B8%AA%20uclass%E3%80%81%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%9A%E5%8D%95%E7%8B%AC%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8C%85%E5%90%AB%E6%97%A7%E7%9A%84%20%E2%80%9Cu-boot%2Cdm-%E2%80%9D%20%E6%A0%87%E7%AD%BE%EF%BC%9A%E8%AF%B7%E5%9C%A8%202023.07%20%E5%B9%B4%E4%B9%8B%E5%89%8D%E4%BF%AE%E5%A4%8D%EF%BC%81%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E%E4%BB%8E%20MMC%20%E5%8A%A0%E8%BD%BD%E7%8E%AF%E5%A2%83...%20%E6%AD%A3%E5%9C%A8%E8%AF%BB%E5%8F%96%20MMC(0)...%20***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%5B*%5D-Video%20Link%200dc0_power_domain%20%5B32%5D%20not%20owned%20by%20curr%20partition%3CBR%20%2F%3Esc_pm_set_resource_power_mode%3A%20resource%3A32%20mode%3A3%3A%20res%3A4%3CBR%20%2F%3EError%3A%20dc0_power_domain%20Power%20up%20failed%EF%BC%81%EF%BC%88%E9%94%99%E8%AF%AF%20%3D%20-13%EF%BC%89%3CBR%20%2F%3E%E6%8E%A2%E6%B5%8B%E8%A7%86%E9%A2%91%E8%AE%BE%E5%A4%87%E5%A4%B1%E8%B4%A5%EF%BC%8Cret%20-5%3C%2FP%3E%3CP%3E%5B0%5D%20dpu%4056180000%EF%BC%8C%E8%A7%86%E9%A2%91%3CBR%20%2F%3E%5B1%5D%20lvds-channel%400%EF%BC%8C%E6%98%BE%E7%A4%BA%3CBR%20%2F%3E%5B2%5D%20panel%EF%BC%8C%E9%9D%A2%E6%9D%BF%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EBuildInfo%EF%BC%9A%3CBR%20%2F%3E-SCFW%20654907b6%E3%80%81SECO-FW%20c9de51c0%E3%80%81IMX-MKIMAGE%204c2e5b25%E3%80%81ATF%20automot-U-%E5%90%AF%E5%8A%A8%202025.04-g1fb4ea4fd9e4-dirty%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E7%9B%AE%E6%A0%87%E4%B8%BA%20MMC%3A0%3CBR%20%2F%3ENet%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E4%BB%A5%E5%A4%AA%E7%BD%91%E3%80%82%3CBR%20%2F%3EINFO%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%8F%AF%E4%BF%A1%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%E9%80%89%E5%AE%9A%E7%9A%84%E5%8F%AF%E9%9D%A0%20API%20%E7%89%88%E6%9C%AC%EF%BC%9A3%EF%BC%88%E5%B7%B2%E8%AF%B7%E6%B1%82%203%EF%BC%89%E4%BF%A1%E6%81%AF%E5%88%9D%E5%A7%8B%E5%8C%96%E5%8F%AF%E4%BF%A1%E8%B5%96%E7%9A%84%20IPC%20%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%E5%88%9D%E5%A7%8B%E5%8C%96%E5%8F%AF%E4%BF%A1%E7%A1%AC%E4%BB%B6%E5%8A%A0%E5%AF%86%E5%AE%A2%E6%88%B7%E7%AB%AF%3CBR%20%2F%3E%E4%BF%A1%E6%81%AF%E5%88%9D%E5%A7%8B%E5%8C%96%20RPMB%20%E5%AD%98%E5%82%A8%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%86%E9%92%A5%E5%B0%9A%E6%9C%AA%E7%BC%96%E7%A8%8B%20rpmb_proxy.c%3A%20279%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%EF%BC%9AERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Erpmb_proxy.c%3A279%EF%BC%9AERROR%20proxy_handle_rpmb%3A%20rpmb_storage_send%20failed%3A%207%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%20rpmb%20%E5%86%99%E8%AE%A1%E6%95%B0%E5%99%A8%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%86%E9%92%A5%E5%B0%9A%E6%9C%AA%E7%BC%96%E7%A8%8B%3CBR%20%2F%3Erpmb_proxy.c%3A279%EF%BC%9A%E9%94%99%E8%AF%AF%20proxy_handle_rpmb%EF%BC%9Arpmb_storage_send%20%E5%A4%B1%E8%B4%A5%EF%BC%9A7%20%3CBR%20%2F%3E%20ss%EF%BC%9Ainit_rpmb_fs%EF%BC%9A%E9%9D%99%E6%80%81%20rpmb%20%E5%A4%A7%E5%B0%8F%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C2048%20%3CBR%20%2F%3E%20ss%EF%BC%9Astorage_service_init%EF%BC%9Ablock_device_tipc_init%20%E5%A4%B1%E8%B4%A5%20(-1)%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%86%E9%92%A5%E5%B0%9A%E6%9C%AA%E7%BC%96%E7%A8%8B%20Fastboot%EF%BC%9A%E6%AD%A3%E5%B8%B8%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%20avb.c%3A%2086%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EVerifying%20slot%20_a%20...%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_do_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Efsl_validate_vbmeta_public_key_rpmb%EF%BC%9A%E8%AF%BB%E5%8F%96%E5%85%AC%E9%92%A5%E9%94%99%E8%AF%AF%3CBR%20%2F%3Eavb_slot_verify.c%3A902%EF%BC%9AERROR%3A%20vbmeta_a%EF%BC%9A%E7%94%A8%E4%BA%8E%E7%AD%BE%E7%BD%B2%E6%95%B0%E6%8D%AE%E7%9A%84%E5%85%AC%E9%92%A5%E8%A2%AB%E6%8B%92%E7%BB%9D%E3%80%82%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Efsl_read_rollback_index_rpmb%3A%20read%20rollback%20from%20Trusty%20error!%3CBR%20%2F%3EAuthentication%20key%20not%20yet%20programmed%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9A%E9%94%99%E8%AF%AF%20avb_do_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E5%A4%B1%E8%B4%A5%EF%BC%8C%E7%8A%B6%E6%80%81%EF%BC%9A%E8%A7%A3%E9%94%81%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20'boot_a'%20%E4%BB%8D%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E5%9C%B0%E5%9D%80%200x80280000%20%E5%A4%A7%E5%B0%8F%2038883%20KiB%20avb.c%3A%2086%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_doo_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EERROR%20-%20failed%20to%20read%20public%20key%20for%20keymaster%3CBR%20%2F%3Ekeymaster.c%3A318%EF%BC%9A%E9%94%99%E8%AF%AF%20Keymaster%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%81%3CBR%20%2F%3Ekeymaster.c%3A684%EF%BC%9A%E9%94%99%E8%AF%AF%20Keymaster%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%81%3CBR%20%2F%3Eboota%EF%BC%9A%E8%AE%BE%E7%BD%AE%E5%90%AF%E5%8A%A8%E8%A1%A5%E4%B8%81%E7%BA%A7%E5%88%AB%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3Eavb.c%3A86%EF%BC%9AERROR%20avb_do_tipc%EF%BC%9AAVB%20TIPC%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Esecretkeeper.c%3A58%EF%BC%9AERROR%20send_header_only_request%EF%BC%9ASecretKeeper%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Esecretkeeper.c%3A121%EF%BC%9AERROR%20%E5%9C%A8%20secretkeeper_get_identity%EF%BC%9A%E5%90%91%20Secretkeeper%20%E5%8F%91%E9%80%81%E8%AF%B7%E6%B1%82%E5%A4%B1%E8%B4%A5%20(-1)%E3%80%82%3CBR%20%2F%3Esecretkeeper.c%3A150%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20secretkeeper%20%E5%AF%86%E9%92%A5%EF%BC%88err%20%3D%20-1%EF%BC%89%EF%BC%81%3CBR%20%2F%3Ekernel%20%40%2080280000%20(40566784)%20%3CBR%20%2F%3E%20ramdisk%20%40%20fc000000%20(23203478)%20fdt%20%40%2082ab0400%20(145053)%20%E5%B0%86%E5%9B%BE%E5%83%8F%E4%BB%8E%200x80280000%20%3CBR%20%2F%3E%20%E7%A7%BB%E5%8A%A8%E5%88%B0%200x80400000%EF%BC%8Cend%3D0x82ab0000%20%3CBR%20%2F%3E%20%23%23%20%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%20%E5%9C%A8%200x82ab0400%20%E5%A4%84%E4%BD%BF%E7%94%A8%20fdt%20blob%20%3CBR%20%2F%3E%20%E5%90%AF%E5%8A%A8%20%3CBR%20%2F%3E%20FDT%20%E5%B7%A5%E4%BD%9C%20FDT%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2082ab0400%20%E5%9C%A8%200000000082ab0400%20%E5%A4%84%E4%BD%BF%E7%94%A8%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%200000000082ad6a9c%20%E5%B7%A5%E4%BD%9C%20FDT%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%2082ab0400%20%2Fbus%20%4059000000%20%2Fdma-%E6%8E%A7%E5%88%B6%E5%99%A8%20%40591f0000%EF%BC%8C41740%20%2Fbus%20%4059000000%20%2Fdma%E6%8E%A7%E5%88%B6%E5%99%A8%20%40599f0000%EF%BC%8C42872%20%2Fbus%20%405a000000%20%2Fdma%E6%8E%A7%E5%88%B6%E5%99%A8%20%405a1f0000%EF%BC%8C62280%20%2Fbus%20%405a000000%20%2Fdma-%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%99%A8%20%405a1f0000%EF%BC%8C62280%20%3CBR%20%2F%3E%20%2Fbus%20%405a000000%20%2Fdma-controller%20%405a9f0000%EF%BC%8C62784%20dc0_power_doma%20%3CBR%20%2F%3E%20in%20%5B32%5D%20%E4%B8%8D%E5%BD%92%20curr%20%E5%88%86%E5%8C%BA%3CBR%20%2F%3E%E6%89%80%E6%9C%89%20sc_pm_set_resource_power_mode%EF%BC%9A%E8%B5%84%E6%BA%90%EF%BC%9A32%20%E6%A8%A1%E5%BC%8F%EF%BC%9A3%EF%BC%9Ares%3A%204%20%E9%94%99%E8%AF%AF%EF%BC%9Adc0_power_domain%20%E5%BC%80%E6%9C%BA%E5%A4%B1%E8%B4%A5%EF%BC%81%3CBR%20%2F%3E%EF%BC%88%E9%94%99%E8%AF%AF%20%3D%20-13%EF%BC%89%3CBR%20%2F%3E%E6%8E%A2%E6%B5%8B%E8%A7%86%E9%A2%91%E8%AE%BE%E5%A4%87%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%EF%BC%8Cret%20-5%20%3CBR%20%2F%3E%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%86%E9%92%A5%E5%B0%9A%E6%9C%AA%E7%BC%96%E7%A8%8B%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E9%97%AA%E5%AD%98%E6%97%B6%E9%81%87%E5%88%B0%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%97%AE%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%20%3CBR%20%2F%3E%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E6%9C%AC%E7%9F%A5%E8%AF%86%E5%BA%93%E3%80%82%E9%9C%80%E8%A6%81%E8%8E%B7%E5%8F%96%E6%96%B0%E7%9A%84%20Timing.c%E7%84%B6%E5%90%8E%E5%9C%A8%20uboot%20%E4%B8%AD%E6%9B%BF%E6%8D%A2%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-8-8X-Family-DDR-Tools-Release%2Fta-p%2F1121519%22%20target%3D%22_blank%22%3Ei.MX%208%2F8X%20Family%20DDR%20%E5%B7%A5%E5%85%B7%E7%89%88%E6%9C%AC%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%E5%BF%97%E6%98%8E%20%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228214%22%20target%3D%22_blank%22%3E%40Ram2%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E5%AE%8C%E6%88%90%20DDR%20%E6%A0%A1%E5%87%86%E4%BA%86%E5%90%97%EF%BC%9F%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8qxpc0mek%20%20Android15%20Automotive%20facing%20issue%20while%20flashing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2281664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%B2%A1%E6%9C%89%E5%AE%8C%E6%88%90%20DDR%20%E6%A0%A1%E5%87%86%EF%BC%8C%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%20DDR%20%E6%A0%A1%E5%87%86%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E9%80%9A%E7%94%A8%E6%AD%A5%E9%AA%A4%E6%88%96%E5%B7%A5%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E
