iMX8qxpc0mek Android15 Automotive facing issue while flashing
Ram2
Hi NXP Team,
We are trying to use Android15 Automotive bring up in iMX8qxpC0mek
Since its custom board , not an EVK
================ Boot logs============
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 02 2026 - 12:31:04 +0530)
Normal Boot
Trying to boot from MMC1
MMC: block number 0x4000 exceeds max(0x2000)
Failed to read rpmbkeyblob.Authentication key not yet programmed
Booting from bootloader_a...
UU
boot args 0x*** 0x*** 0x*** 0x0
SCFW: 00000***
SECO-FW: 00000***
initializing trusty (Project: imx8qxp, Build: [email protected], Built: 13:48:55 Aug 12 2025)
hwsecure: 22: hwsecure init.
INFO: trusty/user/app/secretkeeper/lib.rs:258 Secretkeeper TA startup, on: 'com.android.trusty.secretkeeper.authgraph', 'com.android.trusty.secretkeeper', 'com.android.trusty.secretkeeper.bootloader'
Core: 248 devices, 27 uclasses, devicetree: separate
Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07!
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
[*]-Video Link 0dc0_power_domain [32] not owned by curr partition
sc_pm_set_resource_power_mode: resource:32 mode:3: res:4
Error: dc0_power_domain Power up failed! (error = -13)
probe video device failed, ret -5
[0] dpu@56180000, video
[1] lvds-channel@0, display
[2] panel, panel
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW 654907b6, SECO-FW c9de51c0, IMX-MKIMAGE 4c2e5b25, ATF automot
- U-Boot 2025.04-g1fb4ea4fd9e4-dirty
flash target is MMC:0
Net: No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
INFO Initializing Trusty IPC device
INFO Initializing Trusty Hardware Crypto client
INFO Initializing RPMB storage proxy service
rpmb_proxy.c:279: ERROR proxy_handle_rpmb: rpmb_storage_send failed: 7
failed to read rpmb write counter
ss: init_rpmb_fs: bad static rpmb size, 2048
ss: storage_service_init: block_device_tipc_init failed (-1)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
Verifying slot _a ...
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:902: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
verify FAIL, state: UNLOCK
boot 'boot_a' still
Kernel load addr 0x80280000 size 38883 KiB
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
keymaster.c:684: ERROR Keymaster TIPC client not initialized!
boota: set boot patch level failed.
secretkeeper.c:58: ERROR send_header_only_request: SecretKeeper client not initialized
secretkeeper.c:121: ERROR In secretkeeper_get_identity: failed (-1) to send request to Secretkeeper.
secretkeeper.c:150: ERROR Failed to get secretkeeper key (err = -1)!
kernel @ 80280000 (40566784)
ramdisk @ fc000000 (23203478)
fdt @ 82ab0400 (145053)
Moving Image from 0x80280000 to 0x80400000, end=0x82ab0000
## Flattened Device Tree blob at 82ab0400
Booting using the fdt blob at 0x82ab0400
Working FDT set to 82ab0400
Using Device Tree in place at 0000000082ab0400, end 0000000082ad6a9c
/bus@59000000/dma-controller@591f0000, 41740
/bus@59000000/dma-controller@599f0000, 42872
/bus@5a000000/dma-controller@5a1f0000, 62280
/bus@5a000000/dma-controller@5a9f0000, 62784
Starting kernel ...
Ram2
Hi @Zhiming_Liu
We didnt finish the DDR calibration , Can you please help with steps for DDR calibration
Is there any generic steps or tool is required
Zhiming_Liu
Hi @Ram2
Please refer this knowledge base. Need to get new timing.c from tool and then replace it in uboot.
i.MX 8/8X Family DDR Tools Release
Zhiming
Zhiming_Liu
Hi @Ram2
If you are using custom board, did you modify the source code referring the difference?
Here is bootlog on MEK board with flash command: .\uuu_imx_android_flash.bat -f imx8qxp -e -u c0
U-Boot SPL 2025.04-g6bf602d3b5ab (Sep 16 2025 - 19:00:07 +0200)
Normal Boot
Magic is incorrect.
Error validating A/B metadata from disk.
Resetting and writing new A/B metadata to disk.
UU
SCFW: 00000***
SECO-FW: 00000***
Core:  262 devices, 31 uclasses, devicetree: separate
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - U-Boot 2025.04-g6bf602d3b5ab
Net:   eth0: ethernet@5b040000 [PRIME]Could not get PHY for FEC1: addr 1
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
ramdisk  @ fc000000 (23201967)
fdt      @ 82ab0400 (129950)
   Using Device Tree in place at 0000000082ab0400, end 0000000082ad2f9d
/bus@59000000/dma-controller@591f0000, 36432
/bus@59000000/dma-controller@599f0000, 37564
/bus@5a000000/dma-controller@5a1f0000, 54600
/bus@5a000000/dma-controller@5a9f0000, 55104
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd042]
[    0.000000][    T0] Linux version 6.12.23-android16-5-maybe-dirty-4k (kleaf@build-host) (Android (12833971, +pgo, +bolt, +lto, +mlgo, based on r536225) clang version 19.0.1 (https://android.googlesource.com/toolchain/llvm-project b3a530ec6537146650e42be89f1089e9a3588460), LLD 19.0.1) #1 SMP PREEMPT Thu Jan  1 00:00:00 UTC 1970
[    0.000000][    T0] KASLR enabled
[    0.000000][    T0] Machine model: Freescale i.MX8QXP MEK
[    0.000000][    T0] Malformed early option 'earlycon'
[    0.000000][    T0] Enabling dynamic shadow call stack
[    0.000000][    T0] efi: UEFI not found.
Zhiming
Ram2
Facing above issue while flashing , can help what could be the issue
Ram2
Hi @Zhiming_Liu
We are using same flashing command
sudo ./uuu_imx_android_flash.sh -f imx8qxp -a -u c0 -e -c0
Still I see below error
hwcrypto.c:94: ERROR hwcrypto_do_tipc: HWCRYPTO TIPC client not initialized
ramdisk @ fc000000 (23203479)
Starting kernel ...
U-Boot SPL 2025.04-g1fb4ea4fd9e4-dirty (Jan 03 2026 - 12:58:24 +0530)
Normal Boot
Load or verify bootloader_b fail, setting unbootable..
No bootable slots found, try to boot into recovery mode...
Error: -38
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
We have done pin muxing changes w.r.t to custom board
Zhiming_Liu
Hi @Ram2
Did you finish the DDR calibration?
Zhiming
