Dear Community,
I would like to know if there's a simple way to disable WDR3 feature without using vvext utility please ? My problem is that WDR3 is enabled by default when launching gstreamer and it makes the scene/images brighter but not natural (over-exposure).
Also, even-though I disabled it after first gst-launch (and it does keep it status as disabled), but second gst-launch would require a cycle of re-enable/re-disable to correctly disable it.
Thanks in advance and best regards,
Khang
Hi @joanxie ,
Thanks for your reply. Do you mean that I could use the v4l2-ctl command to control this WDR3's parameters? If yes, could you give an example of the syntax, please ?
Khang
Example you can find in source code of vvext tool
