iMX8MP ISP - How to disable WDR3
1,721 次查看
khang_letruong
Senior Contributor III
Dear Community,
I would like to know if there's a simple way to disable WDR3 feature without using vvext utility please ? My problem is that WDR3 is enabled by default when launching gstreamer and it makes the scene/images brighter but not natural (over-exposure).
Also, even-though I disabled it after first gst-launch (and it does keep it status as disabled), but second gst-launch would require a cycle of re-enable/re-disable to correctly disable it.
Thanks in advance and best regards,
Khang
1,712 次查看
joanxie
refer to the ISP Using V4L2 Interface User Guide,
maybe you can double check these control words to disable it
1,708 次查看
khang_letruong
Hi @joanxie ,
Thanks for your reply. Do you mean that I could use the v4l2-ctl command to control this WDR3's parameters? If yes, could you give an example of the syntax, please ?
Khang
1,699 次查看
artsiomstaliaro
Example you can find in source code of vvext tool
