iMX6 integrated LDO's
2,301 次查看
tarterkit_ru
If chip marked as 1GHz ability, how up frequency in Linux kernel to 1G?
As i understand, if put cpu_freq=1G to kernel komand line arguments, it is disable integrated LDO's and must be supply external МСС to ARM_CAP ...
标签 (2)
1,722 次查看
jimmychan
According to the Linux BSP Release Note, you can put the "arm_freq=1000" in the kernel command line. Basically,
1G CPU frequency is set by default and LDO bypass is enabled by default.
1,723 次查看
jimmychan
