i.mx28 ethernet - enhanced buffer descriptors
1,009 次查看
pierre286
Hello all,
I'd like to use the uDMA in enhanced mode to provide enhanced buffer descriptors with packages. So far I couldn't find any way to switch to enhanced mode. The only thing I found is that the default mode is the legacy mode. Does anyone know how to switch?
Thanks in advance,
Peter
标记 (1)
865 次查看
shefft
don't know if this will help you, but in the imx6 there's a 1588 enable bit in the ENET ECR register that will enable the enhanced descriptors.28
