Hi All,
I would like to ask about IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE_RGMII register of i.MX6DQ.
Should one set 11b into the DDR_SEL field in the case of using 1.8V/2.5V PHY?
Or, can DDR_SEL be default value(10b) regardless of the IO voltage of PHY?
Please give your answer to the above, and the explanation about this DDR_SEL setting as well.
BR,
Miyamoto
Solved! Go to Solution.
DDR_SEL should be set as 11 for RGMII interface (for signals ranging from 1.3V to 2.5V).
