i.MX8X power-up/down sequence guidelines
1,826 次查看
Kazuma_Sasaki
Senior Contributor I
Power-up/down sequence guidelines described in datasheet.
Please let me confirm three points here.
From latest datasheet. (IMX8DXAEC Rev. 1, 5/2019)
Q1. Regarding power-up sequence. datasheet defined "a stable voltage operating within the operating range".
It means that we only care timing which over the minimum defined operating range. Is it right? I draw a timing chart based on my understanding as below. is it okay?
Q2. Regarding power-down sequence. datasheet mentioned "Supply group 0 must be turned off last, after all other supplies".
What timing the group 0 is allow to turn off? I draw a timing chart based on my understanding as below. Is it okay?
if my understanding wrong, please elaborate more detail about turn off timing.
Q3. Regarding power-up sequence. datasheet mentioned group 0 must be powered first but, other groups are allowable to power simultaneously group 0. I draw a timing chart based on my understanding as below. Is it okay?
Kazuma Sasaki.
标记 (1)
1,690 次查看
Yuri
   Your understanding is correct and the waveforms are acceptable.
Yuri
1,691 次查看
Yuri
Yuri
